Hardware Akasa Tesla H Review
Discussion in 'Article Discussion' started by Meanmotion, 20 Mar 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. jrs77
    jrs77 Modder
    17 Feb 2006
    2x 2.5" drivebays...
    ...while the NUC only has a single SATA-connector :confused:
  3. Revil0
    Revil0 99% lurking
    21 Jan 2011
    I quite like the idea!
  4. kent thomsen
    kent thomsen What's a Dremel?
    9 Jul 2011
    Under my desk, I have an Antec P182, containing an i7 3770 on an Intel "Skull" P67 mobo and a GTX650 GPU. And a 120 GB SSD and 16 GB ram. A fairly potent system, except for gaming.
    It´s cladded with both bitumen mats for anti-resonance, and foam pads for noiseblocking. It´s got 4 Antec True Quiet 120mm fans and a Coolermaster EVO CPU cooler.
    The whole thing is very quiet, during daytime you won´t hear it at all, in the dead silence of night you´ll just be able to hear it.
    But it also weighs close to 20 kg, and you all know how much space a P182 will take up...
    And here comes these new NUC´s and cabinets to match. And it´s got everything: It´s near-silent, ultralightweight and about the size of a DVD-drive. And pretty strong performance already.
    When I look at the performance numbers, of course there´s a long way yet, before they reach the performance of my present system.
    But I´m sure it will come before you know it, and then you can count me in for one or more around the house. This is definitely the future for "desktops" as far as I see it.
    Looking forward to the next generations and reviews.
    Thnx.
  5. Cheapskate
    13 May 2007
    Does the Msata adapter sell separately? That little guy would come in handy...
    -Ah, nevermind. Morning sleepy brain.
  6. Combatus
    16 Feb 2009
    Kent - you should also check out this - Akasa's mini-ITX fanless case. Couple that with a 35W desktop Core i5 CPU and a thin motherboard and you'll have something that's way more powerful than a NUC!
    Tyinsar likes this.
  7. kent thomsen
    9 Jul 2011
    "Kent - you should also check out this - Akasa's mini-ITX fanless case. Couple that with a 35W desktop Core i5 CPU and a thin motherboard and you'll have something that's way more powerful than a NUC![/QUOTE]
    That looks unteresting as well! And I wouldn´t be afraid to drill a few holes in it and place a quite 140mm fan right on top of it and let that blow slowly downwards or something, it would still be whisper quiet...
    It´s not more than six monyhs since I put my system together, so it´l be a little while before I splash out again.
    But at that time, these little machines will be even stronger. A bit sad for the old Antec, but this is the way things go.
  8. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    @ Antony Leather: Thank you.
  9. Anneon
    Anneon What's a Dremel?
    30 Sep 2010
    nice review......ads are too much now....
  10. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I'm extremely tempted to go down the NUC route, but now I'm swithering as to whether a thin mini ITX might be a better bet, per Meanmotion's suggestion. Can someone give me a quick rundown of pros and cons between NUC and thin mITX?
    Also, is it viable to mount either a Euler or an NUC behind my monitor (a Dell 2412M)? I assume that I'd have to swap the standard Dell stand for a VESA one, but can anyone clarify?
    Cheers dudes!
  11. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    Loving my HP Microserver - the move to small makes so much sense...
  12. pbryanw
    pbryanw Minimodder
    22 Jul 2009
    Thanks for the review bit-tech. I wonder if you'd consider placing a ten pence piece (or a can) next to one of these NUC cases, as I'm finding it hard to get a sense of scale from the pictures. Otherwise, I'm hoping NUCs will come down in price, and in the near future I'll be able to install the release version of Steam OS on one and do some game streaming with it.
  13. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    My new server is running on a mini-ITX mono I got from Bindi, but it's in a 4u rackmount case, which kind of defeats the purpose of small. It looks so lonely in there :lol:
  14. tonyd223
    12 Nov 2009
    My missus told me no racks! I bought the Microserver because of recommendations on Bit-Tech - you guys rock :)
  15. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    i'd like to see one with an mxm3.0a connector.
Tags: Add Tags
