Case Mod - In Progress Project: Gearbox 2.0 - mini P180 Back to Basics
Discussion in 'Project Logs' started by THEkorean, 2 Jun 2007.
  1. THEkorean
    THEkorean 42
    10 Jun 2005
    Hi, I’m back, and with a second project. So… less words and more pictures
    Plans:
    Case - Lian Li v300b (completely stripped of internals):
    Hardware:
    Starting from left to right - 2x 120mm Noctua Fans, 2x 80mm Noctua fans, D-tek Fuzion, D-tek Db-1, Lian-Li v300b, 2x Black Ice Stealth 120mm radiators,
    On the motherboard tray:
    Intel e6700
    Abit Fatal1ty mATX mobo with HDMI out
    Evga 8800 GTS
    4gb Patriot extreme edition RAM
    2x Samsung T series 500gb Hard drives
    Materials/Tools:
    2 sheets clear plexi, 2 boxes of SAE screws+nuts, 4 plastic friction hinges
    New toy: Dremel Scroll saw
    Aluminum Angle and Strip (this is a picture of the packing tube it came in, ~9ft tall, took a jigsaw to open it)
    Goals for this project:
    -to have a full spec system
    -mATX form factor
    -aesthetically appealing
    -Water-cooled
    -T.I.R. (Total Internal Modularization): basically, I need to retain full use of the removable motherboard tray and have the system water-cooled, so I will modularize the tubing too
    -Must be upgradable
    So, that’s about it, not too much to ask for right? :dremel:
    I’ll have a 2nd post up by Sunday; SAT exams will keep me away for modding for a couple days
    Until next time!
  2. THEkorean
    THEkorean 42
    10 Jun 2005
    Case Feet installed
    for this project, i bought some chrome speaker spikes
    first i took off the stock feet, then drilled a larger hole to acomidate the new feet, and installed, here are the pics:
    closeup
    other side:
    3 out of the four nuts went in fine, but one was not going in because of the motherboard tray rail, so i filed it down to size and now it fits:
    tight fit
    final product looks nice
    the next update will come after i have finished all the metal work, stay tuned
  3. Guest-23315
    Guest-23315 Guest
    Those D-TeK pumps sure look tiny!
  4. fungry
    fungry What's a Dremel?
    14 May 2006
    is that a pump back there? looks small haha. Anyways! i like those feets. fashionable i tell you. Speaker feets are just great.
  5. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    love the feet!!
  6. wbdog206
    wbdog206 not me
    15 Jan 2007
    the feet are nifty looking
  7. Xlixen
    Xlixen What's a Dremel?
    16 Apr 2007
    Loving them feet, sexy!
  8. THEkorean
    THEkorean 42
    10 Jun 2005
    yes, that is a pump, the D-tek dB1 is not too small, it takes up about the same volume as the Laing DDC, i need to get metal work and motherboard tray in before i can find out if it is as quiet as it is advertised to be
    anyways...
    thanks for all the comments guys, new update, couldn't resist not modding after exams, so here we go!
    Got allot of metal work done today:
    started by mummifying the whole case
    cut up a cardboard template for the radiator placement
    drew it on, colored areas to be cut
    began cutting with this beasty dremel attachment
    first hole cut, not perfect, but pretty good, it will eventually be covered with a grill anyways
    filing rough edges
    both holes done
    mock mount
    next, PSU supports needed to be fabricated since the stock v300b has no where near enough support to hold a monster like the Enermax Infinity i have planned for it.
    fabricated this out of aluminum strips and rivets
    drilled the lower portion in order to attach it to the PSU lip
    taped up the lip and attached a drill bit to my dremel flex shaft
    holes drilled
    mounted, everything looks good right? WRONG! :wallbash:
    what i failed to realize is that now i cant even put the PSU in because there is no way to get it into the cage that i built for it..., so i had to improvise
    cut the excess off and made a new bar to attach
    [​IMG] rounded corners
    since the rivet gun and drill would definitely be unable to fit into the case,
    i brought out my JB weld and decided to chemical weld it on
    currently the case is sitting in my garage, clamped and drying, curing time is about 5 hours, so no more modding can go down until then :waah:
    Lesson for today: think before you act, you'll save ALOT of time :\
    Until next time!
    (PS, should i go back and resize the earlier pics or were they better?)
  9. TNash
    TNash What's a Dremel?
    12 Mar 2007
    sweet, I like the feet
  10. Teyber
    Teyber ******
    18 Mar 2007
    niice... whats the point of that dremel atttachment though?
  11. fungry
    14 May 2006
    yea, could you kindly explain what that dremel attachment does apart from cutting? like what does it do that the cutting disc can't?
    btw, i'm curious, can an 8800gts fit inside a lian li v300 without any modding? cause this case is becoming more appealing to me the more i look at it.
  12. Ultimate Gamer
    Ultimate Gamer What's a Dremel?
    3 Nov 2006
    looking great i like your new toy lol it looks cool is it fun to use? but looks great :D
  13. THEkorean
    THEkorean 42
    10 Jun 2005
    @Teyber and Fungry
    sorry if the picture is not clear, but that particular attachment is like any other dremel cutting wheel, but it is made of metal, its thin, and it has sharp teeth that cut into aluminum like butter and does not wear like standard cutting disks. Its also capable of cutting more accurate lines with less effort perfect for making long straight cuts in places where jigsaw wont fit. It also has a plastic guard so if the disk does shatter, the teeth wont hit you and cause serious injury (was that enough explanation? :D )
    @ultimate Gamer
    i like my new toy too, it is pretty nice, with the spiral blade attachment i can easily cut intricate designs into acrylic, got it for about 100$ refurbished pretty sweet deal. I will have it bolted down to a work bench and it will see a lot more action once school is out.
    tomorrow i will try to finish the rest of the metal work if i don't end up going out
    until next time!
  14. fungry
    14 May 2006
    haha, are cutting discs easy to shatter? also if you didn't read my post fully i'll just repeat myself.
    can an 8800gts fit in the v300 without any modifications?
  15. THEkorean
    THEkorean 42
    10 Jun 2005
    opps, sorry about that, cutting disks are not easy to shatter, but sometimes they do, but the real problem is that when you are cutting metal they wear VERY quickly, sometimes i go through 5 standard cutting disks per small cutting job, with the saw attachment the job is faster and more precise
    and no, its impossible without modding, due to the nature of the 5.25" drive bays, the 8800gts will not fit, that is why i had to fabricate my own bracket (i use an external CD drive so i don't need the 5.25" bays). Hope that helps
  16. fungry
    14 May 2006
    ooo, okay then. hmmm cause the v300 is rather appealing to me.
    looks like i'll keep an eye on your mod :), see how you approach things. plus your using an infinity, big stuff
  17. THEkorean
    THEkorean 42
    10 Jun 2005
    ok, time to take a little break from studying and post an update that i've had sitting for the past few days!
    unfortunately today i mourn the death of my trusty modding companion, Dremel Multi Pro :sigh:
    but the good news is, my mom had a spare one handy
    a 10 speed dremel, absolutely awesome to use
    so basically what i needed it for was to enlarge the hole that i previously drilled and forgot to enlarge before mounting
    once i drilled the hole, i was able to mount the hard drive rack
    did a mock fit of the reservoir and fan combo, fits perfectly, a tight fit, but its absolutely perfect! (don't you love it when things come out as planned?)
    view from above
    i also had to take care of one more thing before mounting more hardware, the key switch had to be mounted:
    front panel marked up and drilled, then....
    it dosn't fit yet.. so i got for the larger drill bit, but...
    my power drill only takes up to 1/2" drill bits! :waah:
    fortunately my dad has a larger drill somewhere at his store, so i have to wait for him to bring that home for me
    anyways, here's the idea
    it will be mounted above the power and reset switches and will be used to arm/disarm the power switch.
    anyways, on to more hardware moutning:
    i proceeded to mount the other hardware before continuing on to the next phase of the project
    clearance between the radiator and PSU is plenty to maintain use of the modular cables
    on to the planning for the next phase: Modular motherboard tray
    again, this tray has to be stylish, functional and must allow me to remove it easily even with water cooling
    my plan:
    pump and reservoir will be mounted unto the tray and the tubes will be attached to the radiators via:
    these things, they are quick disconnect tube fitting, all you have to do is press that button and water flow stops instantly and allows you to disconnect the tubing from the loop! awesome stuff
    the motherboard cover:
    it will end up looking something like this:
    that is cardboard version 1.0, i will need to make at least 2 more before i have one perfect for transfer unto Plexiglass
    here is how the gear will be mounted on the tray (sorry for the dark picture, ill take a better one after my final exams)
    some notes about the motherboard cover:
    -it will be attached to the removable tray via friction hinges, for easy access to the internals
    -it will act as the chassis for all modular cabling, including SATA, power, front panel, etc.
    well, stay tuned for more updates in the near future,
    until next time! :thumb:
  18. Dead Ghost
    Dead Ghost What's a Dremel?
    11 May 2007
    Where did you buy that particular key switch? It's nice. :D
  19. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    Ah! You use Noctuas! :thumb:
    H.B.
  20. Bas van der Werff
    Bas van der Werff What's a Dremel?
    18 Feb 2007
    Looking good with those feet and love the keyswitch, i never build a computer without one :D
    Keep up the good work :thumb:
