Other Screen Cleaner?
Discussion in 'Hardware' started by modd1uk, 19 Oct 2015.
  1. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    What do you guys use ? My el cheapo stuff has run out and it's annoying shooting at snot on Arma 3.
  2. theshadow2001
    3 May 2012
    Swabs for sterilizing your arm before an injection. Once you have a box of them you'll find many cleaning uses.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Don't you have to be careful of those swabs though?
    I thought the alcohol in them can remove small amounts of anti-glare coating (is that still a thing), personally i use one of those cloths mean for cleaning glasses with plain old tap water.
  4. theshadow2001
    3 May 2012
    My monitor is fine. I don't use them regularly though. I'm not at it every week with the swabs. When grime builds up on the monitor its about the only thing that will shift it.
    Edit: Just to add it leaves zero residue on the screen which is great
  5. bartiszon
    bartiszon Minimodder
    25 Aug 2010
    I just use a simple spray monitor cleaning fluid with a soft glasses cloth.
  6. mrbungle
    20 Sep 2004
  7. spolsh
    spolsh Multimodder
    4 Feb 2012
    I use water to dampen a piece of tissue paper (not toilet paper, kitchen type paper). Then wipe the screen. After about a week, it's clean. (No, honestly, it may take longer than window cleaner/screen cleaner stuff, but it does give a better finish).
    A microfiber cloth works too, but actually seems harder to use than tissue paper. Be careful not to soak the cloth or paper, you want it damp not dripping. Always do the screen when the monitor has been switched off for a little while.
    Doubt it'd be great on anything with a touch screen.
  8. creative
    creative 500rwhp
    23 May 2014
    I use the spray and cloth for my glasses. if its good enough to help me see its good enough for my screen, and my tablet screen and my phone screen...
  9. Vault-Tec
    30 Aug 2015
    + for Windolene.
  10. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Microfiber cloth + distilled water, or 50/50 with household white vinegar.
    Avoid alcohol / ammonia based products (Windolene) as they are too abrasive and can damage anti-gloss coatings on matte displays.
  11. Shirty
    18 Apr 1982
    FTFY
  12. Digerati
    Digerati Minimodder
    19 Feb 2011
    Most eyeglass cleaner is isopropyl alcohol based, but it is a very low concentration. The swaps/pads used to clean/sterilize skin before injections is a much higher concentration, typically around 70% or higher. Alcohol is a solvent and as such, in high concentrations may damage the plastic screen, or the anti-glare coating on it. Not all monitors (or TVs) are the same. So if tempted, test it in a small spot in a corner first.
    I don't want to risk it myself, so I use lens cleaner and a soft microfiber cloth.
  13. thom804
    thom804 Minimodder
    22 Oct 2009
    You can pick up glasses wipes from B&M for next to nothing (I think £1 for about 50 off) and they do the job bloody well!
  14. techmonster
    techmonster What's a Dremel?
    24 Sep 2015
    You don't need to buy a special cleaning tools for a screen. just a soft microfiber cloth and water will do. However i doubt using alcohol or other strong solvents on LED screens.
  15. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    Personally I use a mixture of distilled water and a 'white' vinegar; which I spray from an old cleaning product bottle.
    Dirt cheap to make and works a treat.
  16. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    This stuff and a microfibre cloth - Beats everything with no damage to screen(s) use on my TV's, tablets, phone, everything :)
  17. wolfticket
    19 Apr 2008
    For the record, I have tried many many different sure fire recommendations and combinations thereof, and I have never found a solution that doesn't smear on a matt TFT screen :(
    My current tactic is to keep it as clean as possible for as long as possible, then give up :)
  18. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    I missed this, made me Lol. <3
