Case Mod - Complete Visible Contrast - Updated 18th, Nov 2013 - Completed Photos with Transparent LCD
Discussion in 'Project Logs' started by Mosquito, 1 Oct 2013.
  1. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    Hey, back at it again. Originally I was going to build a wooden computer case to house my new desktop build, including space a pair of 240mm radiators for a CPU, GPU, and motherboard loop. But then I ended up deciding on the Asus Gryphon motherboard instead of the Maximus VI Gene. This led me to drop the motherboard from the loop. Since I don’t game, or need a graphics card that has a full cover block, I decided to keep my 4GB 640GT for now, and just go with a CPU loop for my first custom water-cooling loop.
    The name:
    This mod is named Visible Contrast due to the fact that it will be a black and white build, stemming off of the color scheme of the NZXT H230 Silent Chassis that I will be modding, after reviewing it at The Mod Zoo. There will also be a surprise for the side panel window, which will shed light on the name as well.
    The Mods:
    The mods will include making space for mounting a 240mm radiator in the front, and a window (of sorts) in the side panel, and a few other things here or there. I am hoping to keep this project pretty straight forward, and relatively quick.
    The Stuff:
    Here's a list of some of the stuff that I'll be using in this mod
    NZXT HALE82 V2 550w White Power Supply
    XSPC AX240 Radiator
    MNPCTech Black Anodized Grooved Case Feet
    U-Channel molding
    Black pop-rivets
    3M Scotch 4010 Tape (Tape of the Gawds)
  2. Mosquito
    24 Mar 2011
    Update - Fitting the Radiator
    For this first update, I’ll be making room for the 240mm Rad up front.
    I’m starting with the stock NZXT H230 Chassis.
    The upper 3.5” drive cage is removable by thumb screws. The bottom cage is removable too…
    When I say “removable”, there is a little more work required...
    This is much better. Next up is the same treatment for the 5.25” bay.
    Both drive cages are now out, and there is plenty of space in the front.
    There were a few more rivets to drill out than I thought there would be.
    Now it’s time to make a little headroom for the radiator.
    I’ve marked out the bottom of the 5.25” bay for the cut out.
    Not too bad for just a dremel, I think.
    Radiator fitted to show the plan.
    You can see why this was required. Definitely not enough room otherwise.
    I decided I wanted to remove a little more; there just wasn’t enough clearance for me.
    That’ll do.
    This was the next issue that needed tackling.
    I’ve already drilled out the factory 6-32 threaded inserts with an 11/64” drill bit.
    The lower set of fan screw holes don’t line up quite right.
    Out with the small needle file to make some ovals.
    That is good enough for me.
    Now I’ll be able to fit both fans to the radiator :)
    That’s all the update for now, thanks for checking it out.
    -Mos
  3. Mosquito
    24 Mar 2011
    Back with another update to this project. Not a big one at this point, but a few more additions.
    Took a little field trip with the case, and bought some parts from MNPCTech.
    I bought some U-channel to install over the cut edges of the 5.25” bay.
    I figured the tubing would benefit from not having sharp edges around.
    Nice mitered corners
    I then used black pop rivets to reinstall the 5.25” bay.
    Next up are a set of MNPCTech black anodized “grooved” billet aluminum case feet.
    http://www.mnpctech.com/CaseFeetMachined.html
    These will help get the case off the floor a little bit more, and go well with the black and white theme.
    After installation, I ran across a small problem. This isn’t going to work for the rear feet, as they’ll hit the PSU.
    To lower the clearance on the inside of the case, I picked up some plastic barrel bolts.
    That should do the trick.
    Now there is just enough clearance for the PSU to sit on the rubber pads.
    I also put a few coats of white paint on my thermal armor.
    I want it to be primarily white on the inside. It should make it brighter on the inside, once I install some LEDs.
    I’m planning on leaving the PCI covers black. I like the contrast it adds to the mix, and I think it helps make the motherboard components not stand out as much, for not being painted white.
    That’s all for today :)
  4. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Nice clean work done so far. The armour in white is very striking, looking good Mos. :thumb:
  5. Mosquito
    24 Mar 2011
    Thanks Craig. :) I really do like the white armor. Would make for a nice factory option too :D
  6. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Another white armour mod! Very nice and welcome to the club :)
    Sent from my GT-I9505 using Tapatalk 4
  7. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    i would love to see some white camo :D!
  8. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    This is gonna be really nice when it's finished, Mos :thumb:
  9. Mosquito
    24 Mar 2011
    Thanks :) It does look pretty good
    That would quite fit my theme, but certainly would be a possibility.
    Thanks Bill. I'm hoping it turns out pretty sweet. Putting a bunch of work into this one, with some new ideas :)
  10. Mosquito
    24 Mar 2011
    Thanks for all the comments guys :)
    In this update, I’ll be installing the watercooling gear. I’m going to spare you the 90 shots of fittings, blocks, radiators, etc, and just dive in. This is what’s going to be going in it:
    XSPC AX240 Radiator (White)
    XSPC Raystorm CPU Block
    EK 140 Res top with a D5 Vario pump.
    Monsoon Fittings and angles with white accents
    PrimoChill Advanced LRT tubing, in white
    The EK res top kit includes a nice bracket for mounting the assembly to a vertical surface.
    I do not have a vertical surface, so I started with this sheet aluminum to make a bracket to mount it on the floor.
    I used my workmate, a block of wood, and some clamps to bend this up.
    I made a few cuts with tinsnips and drilled some mounting holes to screw into the pump top.
    A few test fittings to make sure it’ll work.
    I painted it with the same white paint that I used on the TUF armor.
    I lined it with some of the foam that I salvaged from the side panel.
    That should work, nice little contrast continuing on the black and white.
    I installed the pump on its new bracket at this point. I had already roughed in the plumbing earlier.
    The next thing I did was drill out and install for a drain port on the bottom of the front corner.
    At this point I painted the radiator housing, so it would match the case better. The stock XSPC white was not as bright as everything else.
    I also painted the top retainer plate from the Raystorm block white as well.
    I got everything installed, routed, and ready to leak test.
    With bibs ready, time to run the loop for a while…
    Now time for the motherboard install :)
    That’ll do :)
    At first I wasn’t sure whether or not I was going to like the white with black accents, but after seeing it, I must say that I quite like it. It’s a lot of white, but just enough black to break it up. What are your thoughts?
    Thanks for checking this one out, next up will be the window install process, which I’m looking forward to :)
  11. Comrade Woody
    Comrade Woody Obsolete
    14 Mar 2011
    This is looking really nice, I'm looking forward to seeing more :)
    Good work :thumb:
  12. Mosquito
    24 Mar 2011
    Thanks Comrade Woody. Finishing up some things this week, so hopefully I'll have another update again next week :)
  13. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    looking good Mosquito! I love white builds! keep up the great work
  14. Egami
    Egami Why is the dremel on fire?
    27 Aug 2013
    Looking way nice! Those monsoon fittings with the white cpu block faceplate really make the build *pop*.
  15. Mosquito
    24 Mar 2011
    Thanks Ace, the white certainly grew on me...
    Thanks Egami. I went back and forth on the CPU block faceplate, since it was black to start with, but I decided with the block and fittings already being black, it would look best with a white faceplate. I'm glad I decided on that. I'm quite pleased with the results :)
    Thanks for checking it out guys :thumb:
  16. mnpctech
    21 Apr 2003
    LOVE how clean everything looks so far, another great job Mosquito :dremel: :thumb:
  17. Mosquito
    24 Mar 2011
    Thanks Bill :)
    I'm going to try to get a video edited tonight, and get another update out tonight or tomorrow, keep an eye out for it :dremel:
  18. craig - toyoracer
    1 Mar 2011
    Nicely made res/pump mount, fits the case look very well. :thumb:
    I too like the white face plate, great overall look. :)
  19. Mosquito
    24 Mar 2011
    Thanks Craig!
    Little tidbit before I hopefully get an update in the next day
    I used the computer in an unfinished state this weekend, so I installed the mesh on the bottom.
    those MNPCTech Grooved Feet fit perfectly with the stock fan filter
  20. Mosquito
    24 Mar 2011
    Things were moving right along with this build, and this was actually one of the first things I did to this case, but in the interest of flow, I’ve held off on posting it until this update.
    This puppy needs a window!
    First I pulled off the sound dampening foam on the condemned side panel.
    The tape was annoying to remove. I ended up spraying it down with goof off, letting it soak, and then peeling it off with the help of a razor blade paint scraper.
    After getting the tape off, I used goof off, followed by mineral spirits to get the remaining residue off.
    (Note, I tried denatured alcohol, and it did not work, mineral spirits, however, did.)
    I started in the bottom left corner… I got better as I went along
    I masked off the panel with some low tack tape, and then used a monitor bezel to trace out the window.
    I didn’t take many pictures of this process, as most of it was in video.
    I removed the masking, and was pretty happy with the results.
    I had one minor miss with the dremel, but that will be covered up by the u-channel.
    Looking much better already.
    Next up was some MNPCTech U-Channel for the window.
    Since I cut the corners square, I did more mitered corners here.
    Here we have the cutout for the window completed.
    That’s all for this update. Next time I’ll be installing the custom window in the side panel, and getting some shots of it before I wrap up the few details that are left after that.
    As always, thanks for checking it out, and commenting :)
