SteamPlanet I present to you the new project, is a kind of steampunk I show you some pictures of how it should be Although honestly I like the work I did for the other site, based on this, but with more details as it was only designs. So I start the project "SteamPlanet" as any new project shall begin showing the case received and the dismantled the same Luckily I do not do to review, and that someone would go wrong Comparison between the old and new foot, so the case will raise more than 5mm. Presentation of the chimneys I have the handle that is the same design and create the new screw to the side (with a butterfly nut and a screw), but according to the tematic. For now is all, little by little there will be more progress.
oh yeah i was really inspired by Retromod and now creating (or gluing ) my own indestructible cardboard case... "seagull" for now...
thanks Vetalar and good luck with your work log. I begin with the creation of steam chimneys, these I will make with a 110mm PVC pipe, and these were placed on a 4mm fibrofacil wood, to which I will cut off for the placement of them. To perform the chimneys decorated with the same pipe. I continue to design the paper real size to show how they will be different elements, there will be slight changes to the original design because of the measures of various elements such as the dome is larger than the drawing, but will allow a better view interior.
[OT]IMHO my "work" didn't deserve a WL... i make it from trash and all i can pick up from my "workshop"... i think my cardboard boxes, pieces of PVC after bathroom repair, mobile phone chargers as PSUs didn't achieve the level for posting here... i can see really brilliant logs here and i just don't have enough goodness[/OT] *watching Your log for more steam*
heh steampunk is the way ...forwards?...hmmm anyway, subed steampunk builds always have a personality, its good to watch them come 'alive' as more gears hands n cogs get added
I´m always a bit concerned when it comes to steampunk buids. There´s so much crap out there IMO. But this one looks really interesting... And I just love domes!!!
Thank you I'm half disappeared but working, the problem that each piece takes several hours, cutting, sanding, caulking, painting, sanding, painting, etc.. I cut the two side panels, one for the dome and the door and the other for SteamPlanet logo. SteamPlanet's Logo door and dome
