Scratch Build – Complete Project BlackSilent
Discussion in 'Project Logs' started by 501, 14 Dec 2013.
  1. 501
    501 What's a Dremel?
    16 Nov 2013
    Hello !
    I would like to present you my new project ! The idea is to create a case with a full passive watercooling.
    Let place to the sponsors!
    Sponsors
    A big thanks to "Do It Yourself" for their help in my project : http://sleeve-modding.com
    Very good website !
    Thanks to BitsPower for supporting me : http://www.bitspower.com.
    Great thanks to Aquatuning France for their help : www.aquatuning.fr.
    Thanks to Asus !
    A big thanks to Cooler Master for their help.
    Renders
  2. KithKhan
    KithKhan A dremel is all you need.
    24 Feb 2012
    Great concept! I started a similar design years ago and still haven't finished it. Your looks much cleaner!
    What's the radiator size going on the back? A 480x480mm?
  3. 501
    16 Nov 2013
    Thanks !
    It's a cora cap 1042. It's around 500 - 600 mm.
  4. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Looks like a square version of my Inverted build, even the mobo is the same :)
    Don't forget to include the wiring inside the upright panel in your calculations, as my case could almost not be closed once all the wiring was installed.
    Going to keep an eye on this :)
  5. Cheapskate
    13 May 2007
    Looks Promising. :D
    I agree with Meelobee, since I just finished a rig that needed more room for wires. The SATA cables in particular gave me trouble. They insist on not laying flat, and you are stuck with set lengths.
  6. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    wow, those renders look super nice! Very nice idea too - what are you using to render it all?
  7. 501
    16 Nov 2013
    Thanks ! Yes I thought about the wirings ;)
    Thank you !
    Thanks ! I use SketchUp and Keyshot 4 for renders
    Photos
    Thanks again to "Do It Yourself"
    16 Nov 2013
    Happy new year !
    News !
    Reception of the BitsPower parcel. Thanks again for their help !
    Photos of Aquatuning France material. Thanks again !
  9. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Wow! Very nice project! :)
  10. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    Lovely. Are the MDF-and-Plexi sandwiches permanent now, or can you dismantle them for painting?
  11. Meelobee
    5 Nov 2003
    Looks like they're held together with a long threaded rod with nuts on it.
    Very cool project, can't wait to see how this will turn out :)
  12. Nexxo
    23 Oct 2001
    I'm really keen to find out how you get on with those passive radiators. I suspect that they are surprisingly effective, but I'm a bit worried that the push fittings are not very tight.
  13. 501
    16 Nov 2013
    Thanks ! Yes the sandwiches are removable for painting ;)
    I will see if the Cora Cap are efficient. Normally the ten radiators will be enough.
  14. bulldogjeff
    2 Mar 2010
    Looking good, will be keeping an eye on this one
  15. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    I would suggest that you build in a backup system in case those radiators are not good enough.
    I have build a build with the exact same radiator, and it could cool a phenom X4 965 cpu and a gtx 470, but at quite high water and component temperatures. The solution for the build was to put in a single 120 mm radiator.
    All in all, a thin 240 mm radiator with low rpm fans should be as effective as those passive radiators.
    I do like the design. Looks a bit like a Thermaltake level 10 case.
  16. 501
    16 Nov 2013
    Thanks !
    Yes I planed in my builld to add another rad but I hope I will not have to add one
  17. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Chances are that you will. So you might as well built it in from the start:)
    What you can also do, is to build in a system so that you can plug an external radiator to the build.
    I have a set of bitspower fittings at home where i plan to do just this. Will upload a picture when i get home:)
  18. Ygd3n
    Ygd3n What's a Dremel?
    21 Jan 2012
    OOOH! This gonna be so great :D
  19. 501
    16 Nov 2013
    Yes I also thought about this solution :)
    Thank you !
  20. Pirra
    Pirra What's a Dremel?
    7 Nov 2009
    This project really caught my attention!!
    Definitely i'll stay tunned to this thread!!
