Windows online FTP server
Discussion in 'Tech Support' started by phinix, 22 Jul 2015.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Guys I need to find a good secured way to exchange files between clients and best way would be do it online, not proper dedicated ftp server.
    I would need to be able to create many user accounts etc.
    Could you please recommend me some good and secure ftp sites that maybe you use or know?
  2. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    How big are the files?
  3. phinix
    28 Apr 2006
    Up to 2GB
  4. bionicgeekgrrl
    bionicgeekgrrl Minimodder
    1 Oct 2009
    If you have a decent Internet connection you could tunnel sftp to a Linux machine, that'd work well enough to some extent (I know its not what you want however) and is free software wise.
    OTherwise not sure theres much that is ftp that meets your needs without being costly or limited.
    Perhaps OneDrive, GoogleDrive or Dropbox with a shared folder might be a better option? Though you might hit file size limits with those, but there exists free software that can split files into chunks to get around that (WinRAR/WinZip can do it without needing any extra software the other end potentially).
  5. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
