Hardware Corsair H80 Review
Discussion in 'Article Discussion' started by arcticstoat, 15 Dec 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
    Siwini likes this.
  2. Ratchet219
    Ratchet219 What's a Dremel?
    9 Aug 2011
    Wow, finally some useful info from bit-tech! Well done guys. Keep up good work!
  3. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    If as quoted 'For Socket AM3+ and LGA1155 owners, Antec's Kühler H20 920 costs and performs the same and has the benefit of software fan control making it the better buy.' How do you justify the Corsair's score of 83% against Antec's score of 81%?
    Siwini likes this.
  4. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    fyi this fits in a silverstone ft03 and can be run as intake fan with low ram blocks... barely :D
  5. Zombie
    Zombie What's a Dremel?
    17 Dec 2003
    Because percentage points at the end of a review are an arbitrary idea that really have no comparative value. Summarising a 3 page review with one (or even 3) numbers makes little to no sense but us consumers demand it.
    I'm sure the reviewers find that the most pointless part of the reviews and it only causes trouble with cross comparisons. After all, they're journalists not accountants.
  6. mikewd
    mikewd What's a Dremel?
    9 Dec 2010
    So it beats an arbitrary single air cooler? Why not test it against the best air cooler? These cheap pre-built water coolers seem to do a very good job of covering up the fact that they are a very mediocre price/performance competitor against top range air coolers.
    2nd point: These new intel ads are enough to make me start using other websites for reviews.
  7. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Honestly, I think that the WC is part of the past...
    I had it when I had a Q6600(B3)@3.2Ghz and a HD4870 (that was toasty)...
    SB's don't need that much of a cooling, and the new gpu's come with great coolers or are "fresh" by them selves.
    Maybe Ivy's are the market for these coolers, but even then u have great air coolers that are cheaper than these and totally silent (I have a friend that complains his water pump is noisy with one of these new WC systems, Corsair and Kuhler)
  8. RobJapan
    RobJapan What's a Dremel?
    29 Mar 2011
    Adblock should be your new best friend.
  9. Combatus
    16 Feb 2009
    We've re-built all our test rigs since we tested the Kühler H20 920, as mentioned on the performance page - as such, the results and conclusions in the H80 review are more up to date and are based on different systems than those we used in the Kühler review which went live in July.
  10. SchizoFrog
    5 May 2009
    So the Antec would score higher now in the new systems? That seems odd. Still doesn't add up to your recommendation that the Antec is a better option than the Corsair.
  11. Combatus
    16 Feb 2009
    We're using different tests on our systems so cooling scores and value scores are affected. In addition, the Antec's score is based upon a combined score for both the test systems we used at the time, while with the Corsair H80, we've extrapolated individual scores for each CPU socket, so you can't really compare the two.
  12. jon
    jon Chief Phrenologist
    26 Aug 2009
    I fail to see the cost / performance value of WC setups on modern SB chips. Perhaps on AMD's, as I'm not up to date on their heat generation. But it's almost as if the SB design is so heat efficient that WC setups are no longer necessary (for the CPU). Still plenty of heat on high-end GPU's ...
    -J
  13. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Currently my H80 is sat in it's box not getting used because my air cooler perform's better.
    It was good until I overclocked my old I7 920 or I7 950 which on either machine and overheated at 1.25v with 2 high cfm fans on it.
    I honestly cannot recommend it to anyone and instead recommend either a good air cooler or a custom water loop.
    I'll stick to my Akasa Venom Pro on my 2500K as it get's to 70c per core but with the H80 hit's 60c not worth the hassle and noise.
  14. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    My old H50 is keeping my i7 920 stable @ 4.3GHz, not had any issue with it. Maybe because my 840 case has 2 mahoosive exhaust fans at the top.
  15. Diellur
    Diellur What's a Dremel?
    24 May 2011
    When will we see a review of the H100 and a comparison of closed-loop water-coolers?
  16. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Would have been nice to see how much difference it made fitting it as an exhaust.
    I'm considering buying this or the 920 and leaning towards the H80 being that the 920 seems like a noisy beast but I could only fit it as an exhaust in my case.
  17. OzThe2
    OzThe2 What's a Dremel?
    15 Dec 2011
    Awesome - Adblock is now my best friend. Thanks for that tip. The site is so much cleaner now I could eat my dinner off it!
  18. RedFlames
    23 Apr 2009
    If memory serves they tried the h60 both ways and while it did cool better as an intake the difference wasn't that great
  19. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Wow, nice one! Wasn't expecting H80 to be reviewed after all this time. Better later than never.
    While the review was nice, some things could have been added to make it really outstanding, such as:
    • comparative pictures of previous generation Corsair H-series coolers (H50 & H70), current generation (H60 & H100), similar products from competitors (Antec). Would have been nice to see the width the the radiators on all of these in a single picture, the size of the pumps, length of the tubes, etc.
    • your impressions on the build quality (has it improved over the previous generation or the competition?)
    • noise should be treated more in depth. fans and pump.
    Or are you guys preparing all of these aspects for a closed-loop-liquid-CPU-cooler roundup? That would be ... (as much as I hate using this word) awesome! :thumb:
    On another note, how did you guys get rid of two mounting brackets? (hope that's what they're called) The videos on the Corsair website show the H80 has four of them and angled at 45 degrees with the sides of the square pump. In your pictures, there can only be seen two of them and they are perpendicular to the sides.
  20. ssj12
    ssj12 Minimodder
    12 Sep 2007
    So how well will this cool my i7 950 since there was no tests on the socket? I have a thermaltake frio currently.
Tags: Add Tags
