Case Mod - In Progress Nice Soil [Finished]
Discussion in 'Project Logs' started by ProAce, 5 May 2014.
  1. ProAce
    ProAce What's a Dremel?
    13 Jan 2014
    Now my first project is almost finished(Server Case 2.0) I'm starting with my new build: Nice Soil.
    The hardware I will be using is the hardware from my main pc with some nice sponsoring of Cooler Master:
    Rest of the HW:
    - q6600 @ 3.3Ghz
    - Gigabyte GA-P35-DS3R
    - XFX HD6870 Black Edition
    - Icidu Wi-Fi kaartje
    - Cooler Master V8
    - Cooler Master V450s
    - Cooler Master Silencio 652
    And 2 3.5" HDD's and 1 2.5" HDD.
    I got this case from Cooler Master to mod it, which is without any doubt going to happen. I already have a lot ideas for the case, some I will explain here.
    For this build I chose for a Black-White color schedule and as goal to create a nice and clean looking, silent daily used game pc.
    As you can see the motherboard is very colorfull, which doesn't even come near black nor white. For this I/m going to make a white cover with some black strips on it, but I'm not sure about the material for this cover, I think it's going to be plexiglass
    I have ordered some nice black, white and grey paracord for all the visible powercables, and I think I will order some of the lutro0 cablecombs for the cablemanagement
    This laptop was useless after the hole windows xp madness. So I took it apart and thought about a way to re-use it. After a little while it got to me, why not make it in the sidepanel! I will get some plexi and make it in the side panel so it can serve as extra screen!
    If I have gotten a plexi plate I will also finish the Server Case 2.0 build.
    Last but not least, I have a controller of the CM Cosmos II case. I will place this into the silencio and use it as fan controller and the on/off button for the laptop.
    I also make led strips for sales, and I will put a couple in this case too.
    This is the start of a long running project because I will only have time in the weekends. This aren't all my ideas and I will work some out later. There isn't any sketch or render because I will do everything on-the-go.
    I hope you will like this build and untill the next time!
  2. Impatience
    Impatience Minimodder
    6 Apr 2014
    Subbed! I'm intrigued as to how the screen will work out! :clap:
  3. TheViscountGodrich
    TheViscountGodrich Wannabe modder.
    12 Apr 2014
    I just toke apart 2 of those dell laptops, if your looking for more so-dimm ram, wifi modual, or screens let me know.
    Also, do you know how to convert one of the screen attachment cables that they use to dvi, vga, or something usefull?
  4. ProAce
    13 Jan 2014
    There are controller boards for sertain LCD screens. Just google the productcode which is on the back of your lcd panel with 'controller' behind it. You will probably find some ebay things ;)
    There's only one sodimm slot so I have 768 mb ramm, if you're willing to send me 1 gb ddr sodimm i might be able to run windows 7 on it, otherwise it will become a linux distro nevermind, dutch/us
  5. TheViscountGodrich
    12 Apr 2014
    I have a 2 gb stick if your interested in owe-ing me one.
  6. ProAce
    13 Jan 2014
    Don't think we want to have that kind of shipping cost :p
    Just a little update for now:
    I cut everything of the cosmos controller.
    This lasted:
    This will come in the top of the case between the front and the usb connectors.
    That's it for today.
    Next update will be around next week I hope.
  7. ProAce
    13 Jan 2014
    Got a nice package today :)
    Will mount them later this day :)
    Thanx Jasper!
  8. ProAce
    13 Jan 2014
    And I’m back after a time of silence.
    First my apologies about that.
    I have been very busy behind the screens with school, building my site, rebuilding my chamber and several electronic projects.
    Because of that I didn’t have much time for modding.
    Luckily most of the projects have been finished.
    Like my own site:
    ProAce.org
    Here I keep track of my mod and review work and run my own little webshop.
    But for now, Modding time! :)
    My last message was about the 6 JetFlo’s that I got from CM.
    I have put those in the case and they are very good coolers!
    I got them on a BitFenix Recon fan controller and it works like a charm.
    Unfortunately I don’t have a picture of the JetFlo’s in the Silencio because I had to take my sytem apart because of the modding and a little hardware problem.
    First I started with the laptop hardware, looking and fitting how it should be placed.
    The conclusion was; NOT!
    It was too big.
    After a little brainstorm I got the idea of getting a tft monitor and build that into the side-panel.
    So I did and got a nice looking tft monitor (resolution and size unknown).
    The original housing wasn’t perfect fitting so I started making a custom housing.
    I had the luck that school wanted to help me with plexiglass for free!
    I don’t have much pictures of the building process itself so I will define it in words.
    First I cut a dark tinted plexi plate to the right size.
    Then bend it piece by piece till it had the right form.
    After 2 prototypes the cover was born!
    Here is the bend piece of plexiglass for the housing of the monitor, it has the VGA driver and the powerboard sticked to it.
    For the sides I used the same kind of plexiglass to cut a protection plate.
    Then you notice that good tools are half of the job so I made everything at school.
    Mounted the side plexi, other side will come later because of the on/off switch.
    While I was already busy with plexiglas, I was able to cut some other plexiglass plates at school.
    It should be 5 plates but 1 is already installed.
    These plates are meant for a little cover between my power supply and the HDD casing and for the motherboard cover.
    Plate 5 in the case, this is to hide al the wires of the fan controller.
    If you ask yourself why my hardware lies there like that.
    Well that is because something was broken and I had to find out what.
    Apparently it was the motherboard :(
    So I ordered a EVGA 680i (secondhand)
    And I worked out some new ideas.
    The side-panel of the case will be hinged.
    Why? Because I won’t have a window and then you can look into the case easily.
    After a bike little ride I got a piano hinge and some spray cans so I could get started.
    Action paint (cheap store in Holland)!
    Drilled some holes
    And mounted it with 3mm rivets, looks clean
    And the next day I finished the housing of the side monitor:
    That’s it for now, I hope you guys like it and I’ll be back soon with another update! :)
  9. ProAce
    13 Jan 2014
    Update time!
    Before I start I would like to thank my sponsors one more time!
    And I would like to show the url to my site one more time so everyone knows that you can also read everything there:
    Http://www.ProAce.org
    Sorry for the bad pictures, there is something wrong with my camera, next pictures will be better!
    I did a little hardware change due to some broken and oversized parts.
    The Gigabyte Motherboard has been switched with a EVGA 680i SLI.
    And the Cooler Master V8 has been replaced with a Cooler Master GeminII M4, due to the screen in the side the V8 wouldn't fit.
    Now for the real modding.
    At the beginning of this project I designed some stickers for on my powers supply, and they finally arrived. Thanx Esed Soest for the great quality stickers.
    So my Power Supply went from this:
    To:
    And I think it looks awesome. :)
    Then I went on with the side panel.
    In my enthusiasm I haven't taken any pics during the cutting of the panel.
    But it went pretty well, it only took a lot of dremel cutting disks.
    I cut away most of the panel, like the hole for the screen.
    After the cutting I started a bit to fast with drilling the holes for the hinge in the panel.
    That went wrong, I drilled the holes wrong so that the panel wouldn't fit anymore.
    After a little thinking I got a strip of aluminium and put that over the wrong holes.
    And after measuring it a triple times I drilled again, and it was right!
    Little bit of painting
    And done:
    Because of the Black-White color scheme I sprayed all the PCI bay covers white
    Because the VGA Card wasn't white I took it apart, cleaned the heat pipes with some brasso, and sprayed the cover and put some of the white stickers on it.
    I think it looks great.
    Because my mom got crazy over all the pc mess over the tabel I build all the hardware back in the case which looks like this
    This is a fast build up, so not everything is ready or placed.
    Thats it for now, next update will come as soon as possible :)
    Ps. If you have any tips for me about how to do stuff or about my photos/writing, tell me! Here or in a PM so that I can get better in this kind of stuff :)
  10. ProAce
    13 Jan 2014
    It's time for an update again!
    After a long pause in which I had a nice vacation, there comes some progress in this project.
    Nice Soil is standing in his new natural habitat.
    After my vacation my father and I build a desk, its 4 meters long and now I have a good place to mod and get on with my electronics projects. :)
    I put the screen in the place where I wanted it, but that gave some problems.
    The screen could loosse his heat, and it got in the case. My components got 30c hotter then before!
    After a little testing I came to the conclusion that with a fan and some air holes this wouldn't give any problem anymore.
    I changed the casing some more so it would match the rest of the case, its now mat black.
    The screen is hooked on to the side panel with some doublesided tape, which is really strong. When it sits you almost cant take it off.
    And offcourse in my own case I have to use my Led strips!
    You can order them here: Shop.proace.org (still working on multiple languages)
    Almost finished, one on/off switched and that part is ready.
    That was it for today!
    A little teaser for tomorrow:
  11. ProAce
    13 Jan 2014
    And a speedrecord for me, in one day a big update :)
    I have been busy the whole day with modding, and so I have almost finished the case
    Still a couple finishing touches needed and then the final pics will come soon.
    But first the progress of today.
    Where I left you with a little teaser yesterday, I have finished it today.
    This was to solve a problem of this case, the top 2 fan positions can't get or loosse their air. So I made a fan hole.
    And I think that the result is stunning, very clean and it helps for the airflow!
    For the cable management I made a cover next to the power supply, I left it half finished and today I finished it. I got the on/off button of the led strip in this cover.
    Made all the holes for fitting it in the case, never known that a figure saw is so handy!
    And this is how it looks like when it's placed.
    This gets a better cablemanagement.
    And also solved the problem with the heat that was coming off the monitor, by making some airholes the upper fans could pull the air out of the casing, problem solved!
    Same style as the holes above.
    And made a little movie of the monitor.
    https://www.youtube.com/watch?v=uGUV1njshdQ
    On the planning is the mounting of the magnets for closing the side.
    I desided to keep the cables like this, think it looks fine so.
    This was it for now, till the final pics!
  12. ProAce
    13 Jan 2014
    Final Update! :rock:
    The project is finished and here are the final pics.
    For the people who want it I have a little videotour around the system.
    And for the photo's
    This will be the end of this project
    I hope you all enjoyed this build and I will soon be back with a new build :clap:
    Goodbye for now.
  13. Cheapskate
    13 May 2007
    HEY! You can't leave the top cutouts all rough and gnarly! Who are you, Thegreatsatan?:lol:
    If you think that's done, you stumbled into the wrong forum, Mister.
  14. ProAce
    13 Jan 2014
    Don't know what you're talking about :naughty:
    Just kidding, I got that same message a couple more times and changed it yesterday already.
    But till now I didn't have any time to make and post the new pic.
    Looks a lot better now.
