Scratch Build – In Progress (FINISHED) "Dark Matter" by Envious Mods •3D Printed Parts•
Discussion in 'Project Logs' started by EnviousMods, 7 Jan 2016.
  1. EnviousMods
    EnviousMods Minimodder
    13 Apr 2015
    Dark Matter Scratch Build:
    Who am I?
    A bit about me; a few years ago I suffered a traumatic brain injury that caused my brain to hemorrhage. After spending a long time in intensive care I kept thinking about case modding. Before long, its all I could think about. After recovering from my injury I was left with epilepsy and brain that no longer functioned like before.
    I started to look at things differently. Inspiration for mods began to pop up in the oddest places. I eventually became overthrown with modding ideas and designs. Soon I decided it was time to start. Theres nothing quite like being in the grocery store and yelling, “thats it, 45 degree angles” and then running out of the store like a mad man. No matter what I was doing, it all kept coming back to case modding. Today case modding is my life and it allows me to be truly happy. For some case modding is a hobby but, for me its a lifestyle.
    And So It Begins:
    Why:
    I decided to do this scratch build, “Dark Matter” for several reasons. I was tired of limiting my mods to the confines of a mass manufactured case. There are a ton of great cases out there but, I wanted to do something my style from the ground up. The design phase began once I started getting close to completing the StarCraft Day Zero case. However, a lot of the main features for this build have been planned over the last year.
    During the scratch build I will be using new modding techniques as well as using materials that aren't always associated with case modding. If you like seeing original creations and have a love for the truest form of modding; you're in the right place.
    Design Screen Shots:
    I would also like to thank the Sponsors that believe in the Dark Matter Scratch Build
    • Quad vertical PCI-e slots added
    • Modded the stock 80mm rear fan into a 120mm
    • Tons of custom metal fabrication found throughout the build.
    • Almost every piece is hand fabricated (freestyle modding)
    • Aluminum triple SSD rack
    • Custom built PSU mount w/acrylic center plate (backlit)
    • Hand made aluminum grill (top of the case)
    • Modded an Xbox 360 power ring to fit the front of the case and added individually addressable LEDs
    • Hand built acrylic dual voltmeter mount
    • 12mm thick acrylic honeycomb floor
    • Acrylic 240 fan grill (custom made)
    • Cable shroud door mounted next to the motherboard
    • Hand built aluminum brackets for Lexan water-path & EK 480 radiator
    • 90 degree brackets for the frame of the case
    • Snap in color matched rings for the 120mm PureWings 2 PWM fans
    • Gskill logo badge with backlit letters
    • EK logo with plate on the top grill insert
    • Extensive cable management setup and cable combs
    • Case for Arduino Mega and mini TFT touch screen for the animated case badge
    • Hinges for all side panels
    • Mounts for the aluminum grill (top of the case)
    • Custom countersunk washers
    • SSD mount extension
    • GPU cable combs
    • Cable passthrough bezel
    • Switch panel for Xbox 360 power ring and 2 Vandal switches
    • Supermicro C7 Z170–OCE motherboard
    • Gigabyte GTX 960 Extreme SLI GPUs (4-gig each)
    • Intel i7 Skylake CPU
    • Gskill Trident DDR 4 (4 sticks of ram)
    • 3 X OCZ Vector 180 SSDs
    • Full custom sleeved Ensourced cable set
    • 1,200 watt DarkPower 11 Pro BeQuiet Modular PSU
    • 7 X 120mm PWM PureWings 2 case fans
    • 16mm angel eye Vandal switch (blue)
    • 5050 RGB LED strips with wireless remote
    • Arduino Mega with mini TFT touch screen (animated case badge)
    • Printrbot various filaments (3D printed plastics)
    • 4 X Gas struts for gullwing doors
    • Large custom lexan water-path behind the motherboard tray
    • Combination of nickel plated and PETG hardline tubing
    • Custom built acrylic & nickel reservoir mount w/custom smart LEDs
    • Water-cooling passthrough for motherboard tray
    • EKWB X3 250 reservoir
    • EKWB Supremacy Evo CPU block
    • Coolstream XE 480mm radiator (quad BeQuiet 120mm fans)
    • EKWB Revo pump
    • 12mm fittings, hardline, bend kit and coolant (lime green)
    Main Sponsors:
    Gigabyte: (SLI GPUs)
    • 2 x Gigabyte GTX 960 Extreme 4 gig SLI GPUs (8–gig total)
    Supermicro: (Motherboard)
    • Supermicro C7–Z170–OCE motherboard
    G.Skill: (DDR4 Ram)
    • Gskill Trident DDR4 black & white edition (4 sticks of DDR4)
    OCZ: (Solid State Drives)
    • 3 X OCZ Vector 180 SSDs (almost a terabyte Total)
    BeQuiet: (Power Supply & Fans)
    Ensourced: (Custom Sleeved PSU Extensions)
    • Custom length cables, sleeving design and cable combs
    Printrbot: (Filament & Hotend)
    • 7 rolls of filament and an experimental hotend with a 1mm nozzle
    EMI Design (lasercut work)
    • Honeycomb floor panel, 240 grill and bottom door
    EKWB: (Water-Cooling)
    • 480mm radiator (quad BeQuiet 120mm fans)
    • EKWB Revo pump w/plexi top
    • Fittings Including:
    - 12mm HDC hardline fittings
    - 90 degree adaptors
    - 50mm spacers
    - M to M adaptors
    - 10 & 12mm hardline bending kit
    - 12mm tubing
    - Passthrough fittings
  2. HCP
    HCP Minimodder
    19 May 2012
    This looks awsome! I want moore ;)
  3. EnviousMods
    13 Apr 2015
    •••Reserved for final pics•••
  4. eucalyptus
    eucalyptus I am 19 and Swedish!
    29 Sep 2015
    I LOVE green! Fantastic color, hope you even add more green details. Looking forward to follow this :) Seems very interesting!
  5. EnviousMods
    13 Apr 2015
    Cutting The Frame:
    I started to build the frame for the build by cutting metal stock that I've been saving for this build. Some of it is steel and the rest is aluminum to help shave of any weight that I can. I also designed and 3D printed all of the brackets needed to put the frame together.
    I would have rather used a more aggressive tool but, my Dremel and a hand full of cut off disks have made quick work of the first few pieces.
    The Frame:
    3D Printed Brackets:
    Tomorrow the plan is to cut the rest of the pieces needed to complete the basic frame shape and start work on the triple SSD mount.
  6. EnviousMods
    13 Apr 2015
    Thanks HCP!! I've started the first update but, I'll have more progress tomorrow.
    I appreciate it Eucalyptus. There will be a lot more green details found inside as well. I'm glad to have you join along with the build!
  7. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Subbed, this looks pretty cool!
  8. EnviousMods
    13 Apr 2015
    I'm glad to have you along for the journey! Are you the same Bart from OCN?
  9. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Yup, unless there's another Bart, and I seriously hope there aren't TWO sets of parents in the world dumb enough to name a kid something that rhymes with fart. :)
  10. EnviousMods
    13 Apr 2015
    Awesome! I'm known by Reaper N1 over there. If I have the right guy than you've followed a couple of my builds. It's good to see you buddy and I'm happy you get to see this build. :thumb:
  11. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Reaper?!?!?! Where the heck did you vanish to in your OCN thread??!?! I thought something bad might have happened to you!
  12. EnviousMods
    13 Apr 2015
    :rock: After finishing up the StarCraft Day Zero case I started planning and designing this scratch build. I finally get to do a complete build my way; from the ground up. I'm happy to see you here.
  13. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    I'm happy to see you aren't dead, and might finish up that skull case on OCN someday. ;)
  14. EnviousMods
    13 Apr 2015
    Finishing The Frame:
    Today I was able to finish cutting the frames square tubing. I knew this case was going to be a beast but, wow. I can now tell how big of a beast it will be. Mock-ups of the frame have been started as well.
    I also wrapped up a couple replacement 3D printed brackets. I designed these brackets specifically for this build. That way everything fits perfectly. I printed them with 100% infill using a new experimental hotend called the UBIS 13S. Printrbot also sent an experimental 1mm nozzle that makes quick work of any solid or larger pieces I need to print. This saved me a ton of time in printing. It heats up a lot quicker and it can handle the added volume of filament put through it.
    Triple Monitor Mount:
    I decided to convert a single flat screen mount into a triple monitor mount using a few 3D printed parts. This allowed me to mount several of my old flat screens so that I could monitor system information from the 3D printer and desktop CNC. It saves time so I can mod and easily look up to see what's happening in realtime.
    My goal for tomorrow is to finish assembling the frame and start mocking up the custom feet that will be mounted soon.
  15. EnviousMods
    13 Apr 2015
    I wish I had the resources to finish the skull case but, one of these days I'll be able to complete it. I'm happy to see that I'm not dead also. :lol: I'm doing well and excited to make more progress on this build.
  16. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I like the renders a lot. Nice design.
    Do you also have more renders with the sides off?
  17. EnviousMods
    13 Apr 2015
    Thank you Hukkel! I've done a decent amount of design on the inside but, I've recently decided to change a few things. Once I have them updated I will post pics of the inside. Thanks again for checking out the build log.
  18. EnviousMods
    13 Apr 2015
    I managed to get the basic parts of the frame together. It took a little bit longer than anticipated but, thats ok with me. I used washers that are made from thick pieces of nylon. This helps to insulate the bolts and the frame. I also added lock rings to every bolt used which will keep the bolts from loosening over time.
    Mounting The Custom Feet:
    I was lucky enough to be able to re-purpose the feet that will be used for this case. I think the feet of a case serve a good purpose other than aesthetics. Getting the bottom of the case up off the floor a bit helps with cooling.
    I have decided to look into adding 2X200mm fans to the bottom of the case. This will help pull air in through the bottom and out through the top+back. Smoke testing will be done to figure out the best settings/arrangements for the fans throughout the case. I do this with the majority of my builds. Please don't try this unless you know what your doing. You could damage hardware. The test results will be posted after they are done and I might do a short video.
    The Triple SSD mount:
    I designed a triple SSD mount to go on the right side of the case. It will have a see through piece of lexan on the outer panel. The SSD mounts were originally designed to be parallel to the side panel but, when I started cutting everything I decided it would look much better if they had a slight tilt. I made a couple of bends on each end, which allows them to be slightly tilted. I finished all the rough work with these mounts and I will do the aesthetic work after I get the rest of the side panels cut and formed.
  19. eucalyptus
    29 Sep 2015
    What are you going to paint it with? :)
  20. EnviousMods
    13 Apr 2015
    I will be painting most of the case with automotive paint using a combination of airbrush for detailed work and a paint sprayer for the bigger pieces. I've found automotive paint with a good clear coat looks better as well as lasts a lot longer.
