Networks Basic NAS recommendations?
Discussion in 'Hardware' started by bawjaws, 13 Jun 2014.
  1. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Hi all,
    I've decided that I really need to get myself some form of NAS box, but I am utterly clueless about this sort of thing :D
    It doesn't need to be anything fancy at all. I'm basically looking for an external HDD that connects to the network, if that makes sense? I don't need any fancy pants features, I just need something that I can use to share files between laptop and desktop and connect to my TV for streaming. I don't anticipate a heavy load on the NAS as it's unlikely that more than a couple of devices are going to be accessing it simultaneously.
    What would you guys recommend? Budget is about £100 at the most, and that needs to include an HDD (probably not more than 1TB will be needed in the first instance). Go easy on me if this is horribly basic or stupid stuff, I have less than no clue about this stuff :D
    Cheers in advance.
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    For such a small budget I would be looking in the used market for a cheap atom net top or something like this. Those make a good htpc/nas, but you will be limited to a single 2.5" hdd.
  3. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Cheers IvanIvanovich, will give that some consideration.
    Now I'm home, I've remembered that I've got a spare 3.5" HDD sitting in a box :D Budget is £100 tops, no HDD required.
  4. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
    One of the HP Microservers could serve you well if you find one to suite you.
    EDIT: Doesn't seem like they've been on a £100 deal recently, perhaps try the marketplace for one?
  5. TobletDanillio
    TobletDanillio Minimodder
    7 Jan 2012
    second the HP microservers they are good for the price (£100 off)
    fuus likes this.
  6. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    For about £100 you could get a Thecus N2310. I read a review on pcper.com and it looked like a decent bit of kit for the price. I have been very tempted.
  7. Sheiken
    Sheiken Wat?
    9 Jan 2005
    I've got a Zyxel NSA325v2 and I can't fault it at all, works without a hitch on our windows and os x systems!
  8. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    What broadband router do you have? A lot of them now come with the ability to plug in an external HD and share it.
  9. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I've got a VM Superhub so I think that's a no-go, Fingers66.
    By happy coincidence, the latest issue of Custom PC landed on my doormat today and the Labs Test is... NAS Boxes! Will read up and see what the score is.
  10. Toka
    Toka Minimodder
    19 Nov 2006
    If you are happy doing a bit of configuring, and also happy using external hard drives then you could look at a raspberry pi.
    Your only issue here would be the spindown of the disk and figuring out how to back up your data (copying to other areas of the network will be slow as it is over usb. Plenty fast enough for streaming a 1080p/high bit rate film though).
    By backup I mean having more than 1 copy of the data so that you are resilient to the loss of a HDD, not something that would be resistant to power cuts / house fire etc. Plenty of step by step guides out there to set something like this up, even simple ones that I can follow!
    It's worth you having a quick google and whilst the downside is file transfer speed the upside is that you can get the Pi to do a couple of other tasks for you as well (web server, remote access to network / files etc)
  11. Cei
    Cei pew pew pew
    22 Mar 2008
    A second hand single bay Synology box would be ideal.
  12. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    +1 for this
  13. Fingers66
    30 Apr 2010
  14. meandmymouth
    15 Sep 2009
