Case Mod - Complete L3p - Parvum - Mod Of The Year 2013 Nominee.
Discussion in 'Project Logs' started by l3p, 9 Feb 2013.
  1. l3p
    l3p www.^.nl
    1 Nov 2010
    In December 2012 Justin from Parvum systems asked me if I wanted to do a small build in their new acrylic m-ATX case.
    Since I was kinda busy with 2 other projects I helped him with 2 other casemodders (Kier & K.enny) who wanted to do a new build.
    Justin still sent me a case for the help also on some adjustments to the design.... and in my favourite color scheme :)
    At the same time I won an awesome prize in the CooledPC contest.
    So made a deal with EKWB I could trade the prize package for products that fit the Parvum case.
    Another small build was born.
    So decided to make some buildlogs, I just loved the case!
    Won't be a huge casemod, more a watercooled build with lots small mods and lots of pics :)
    Hardware
    Intel Core i5 2550K
    ASUS Maximus V GENE
    ASUS GTX690
    Corsair Dominator Platinum 32GB 2133Mhz
    Corsair Neutron 240GB 2X
    Cooler Master Silent Pro Hybrid 1300W
  2. l3p
    l3p www.^.nl
    1 Nov 2010
    Parvum had some cool teasers before we got them :)
    (Top one is for K.3nny)
    In the meantime ordered some fans.
    And the mainboard.
    Was able to buy nice gpu second hand. (partly trade/buy)
    In my opinion the best looking reference cooler ever.
    Also probably going to use a Pci-e extender in this build.
    Ordered UV and blue ledstrips.
    And some extension cables.
  3. tekonivel
    tekonivel Minimodder
    14 Jul 2012
    Looks promising. i will be following this one.
  4. faxiij
    faxiij Minimodder
    25 Jan 2011
    thats a neat logo - looks sweet. i love that hue, when it's just between yellow and green - that aggressive lime-ish hue...sexy.
    pci-e extender...you got me there. well, actually, you got me before that. i saw there was a new log from l3p..that is almost an automatic sub these days ;)
  5. KidMod-Southpaw
    28 Sep 2010
    Looks very nice!
  6. Primum Agmen
    Primum Agmen What's a Dremel?
    21 Sep 2012
    Is this build going to be air cooled or water cooled? :) The 690 is bloody gorgeous, shame about the price. :D
    If you're laying the GPU flat, what are you going to do with the extra space?
  7. Yaka
    Yaka Multimodder
    26 Jun 2005
    Subbed can't wait for the updates:)
  8. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks guys! Hope all the green will be appreciated :hehe:
    It's going to be a watercooled build. The reason why it's such a shame to remove that lovely reference cooler :)
    The update with what I'm going to do with the extender will be up in a few days :dremel:
  9. l3p
    l3p www.^.nl
    1 Nov 2010
    Unpacking!
    Always fun :)
    Here a huge post with the first impression about the Parvum case.
    Justin also sent some extra's, something he wanted to try :)
    Something that really made me crazy :p
    The case was protected with styrofoam, the case and I were super static loaded....
    The inlayed logo
    Just had to see those fans running :)
    Nice way to find your led board to make some UV shots.
    So soldered it the next day.
    Personally I like this case a lot cause of the placement for the parts.
    Can't wait :)
  10. Azariel
    Azariel Minimodder
    23 Oct 2008
    That inlayed logo in the side panel looks awesome! Is the in and outside both cut and match perfectly? Or is it a foil or something?
  11. l3p
    l3p www.^.nl
    1 Nov 2010
    It's indeed a perfect match, there's like 0.2-0.4mm between it, he had to get it in place with a rubber hammer. :)
  12. Sheiken
    Sheiken Wat?
    9 Jan 2005
    I will be following this one for sure!
  13. l3p
    l3p www.^.nl
    1 Nov 2010
    Here the CooledPC unpacking.
    Was able to arrange with Eddy to change the original prizes for products I was able to use in this Parvum build.
    Better for both of us :)
    The cpu that will be used for this build was also in the package.
    And some extra aluminum CSQ logo's.
    And the watercooling products.
    Thanks Eddy & Niko!
  14. Baguette
    Baguette What's a Dremel?
    6 Aug 2010
    Wow. Dem Blocks. I just love that circle esthetic, combined with that slightly smoked plastic. Just so damn lovely. Looking forward to seeing your assembly of all of this :D
  15. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Love how your logo turned out - Very effective indeed. Pretty looking case too - for some reason it reminds me of bioshock, but it's not obvious to me why....
  16. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks guys! :thumb:
    Another update with lots of pics.
    First fitting the hardware.
    The idea to have the GPU in sight.
    By using a PCI-e extender.
    Lovely evening of 'blocking' by candlelight.
    Glad I had such a small mini torx.
    Chip nice and clean.
    Total view.
    (To bad the mosfet block isn't available in acrylic)
    And a nice package from Cooler Master Benelux.
    Bedankt Marco!
    First thing to do ... I thought ..
    Ordered the wrong size fan. :)
    Still want to see the effect.
    Comes in handy with cases like these.
    Fans mounted.
    And found out the standard EK rad isn't going to fit in the top, had to use a thinner one, even that was close.
    Top fans and radiator mounted too.
    And front.
    Next day the 140mm fan for PSU also arrived.
    Re-drilled the holes cause the standard fan is 135mm.
    White Lamptron replaced with a green Bulgin.
    Heatshrink and sleeve to hide it inside.
    Test with UV/blue leds.
    And hardware inside to see how it looks.
    Also started with a first setup for the loop.
    All still temporary.
    Black instead of blue tape around the extender. (Will be out of sight)
    Next update more sawing and sanding.
  17. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    This is reeeeeaaaally nice!
    I really love it!
    By the way: What LED's are you using for the UV effect?
    I have a regular UV strip that looks really purple (typical UV) and in your pictures the light looks perfectly blue. That's more what I want :)
  18. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    I'd be more than happy to take that ref. Cooler off your hands... ;)
    Anyway looking lovely. Nice idea for angling the card. Gives me an option other than an angled mobo for my build.
  19. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Can't just be me right?
    Loving the unique nature of these Parvum builds, and of course an L3P build is not to be missed. Interesting choice on the angle for the 690 though. I imagine it's for the simplicity on the fittings? Just seems like it's a tad shallow, almost as if your card's falling off the motherboard? Looking forward to seeing how it progresses, if past projects are a hint, then it's going to be a treat.
  20. Evenge
    Evenge Minimodder
    16 Sep 2006
    Nice case! I like a lot your previous work so it's interesting to see what you create this time. :thumb:
