News Silverstone’s “Air Penetrator” fan not as kinky as it sounds
Discussion in 'Article Discussion' started by Sifter3000, 22 Apr 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. stonedsurd
    11 Mar 2009
    Surely one would need number before being interested in a fan? But for now, it certainly sounds promising. :thumb:
  3. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    interested. it looks cool. and it gives you street cred too! "yeah baby, my hardware is made to penetrate in a straight line. it'll keep your balloons floating... and with all the twists and my close-pitch aproach, you'll be blown away"
    knuck likes this.
  4. Sifter3000
    11 Jul 2006
    Someone needs to employ in marketing, that;s genius :D
  5. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Hmm I might get two of these for my RV01. I beed something to improve the airflow!
  6. amacieli
    amacieli What's a Dremel?
    14 Feb 2008
    need CFM and dB numbers
  7. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    This would do well for... what?
    Radiators don't really need linear airflow - the casing of the rad tunnels the airflow already. Case fans also don't really need linear airflow. They just need to get air in, and get air out.
    Seriously, I don't particularly see the point...?
  8. aron311
    aron311 What's a Dremel?
    14 Jul 2007
  9. Bloodburgers
    Bloodburgers Minimodder
    30 Apr 2009
    hmmm.... DP?
  10. dec
    dec [blank space]
    10 Jan 2009
    So are you saying you will have double penetration? :lol: 4 mintues and you stole it from me
    I agree with rickysio, when you want something to be air cooled turbulence is your friend so why would i want a linear (i dont think its good enough to say laminate) flow fan? The only time I can think of that being useful is if whatever you are cooling, the back of a GPU PCB for example, is at a right angle to the fan.
  11. Guest-16
    Guest-16 Guest
    Those shown are only prototypes and quoting company figures is like pulling a number out of the hat most of the time.
    If it's of any use, the one I saw was pretty damn quiet.
  12. memeroot
    memeroot aged and experianced
    31 Oct 2009
    turbulance is not a friend with cooling
  13. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    My thoughts exactly. I really want to think of a use for these, but other than having one in the roof and floating a balloon on top I can't come up with anything.
  14. Cyberpower-UK
    Cyberpower-UK Professional Overclocker
    6 May 2009
    Only spec I can see is 0.33A which means they'll be loudish but the design should make them good for radiators and tower cooler, especially in push-pull. I'm trying to persuade them that make decisions to do triple pentration kits.
  15. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    incorrect turbulent flow is much better than laminer flow for cooling
  16. Queelis
    Queelis What's a Dremel?
    16 Jul 2007
    If we're talking about case airflow - laminar is better (moves more air in given time period). If we're about heatsink airflow, then it's the other way around.
  17. wyx087
    15 Aug 2007
    :hehe: :lol: love the name.
    i think use of this is in cases that you want to direct where the air end up. with normal fans, the air spreads out too much. with these, you will be able to place one further away from the graphics card intake, trusting its directed wind to work its way into the graphics card.
  18. kenco_uk
    28 Nov 2003
    As there's normally a fan at the front and one at the rear.. Will there be a spitroast edition?
    Too far?
  19. rickysio
    6 Jun 2009
    So I've spent some time thinking about it, and honestly? Floating 3 balloons above your radiator should be a pretty cool party trick.
    Jokes aside, pretty much I think the only use is to direct focused air across passively cooled cards.
    But if you go for passive cards, you go for silence, not this type of 0.33A loud-ish fans.
    Besides, all one needs is a 120MM diameter tube, and any normal fan pumps out nearly laminar airflow!
  20. phuzz
    phuzz This is a title
    28 May 2004
    I used to have a 60mm delta fan with a similar angled grill on the other side (which made the entire fan almost a cube), and while it was pretty direct flow, that might have been due to the stupid rmps that that fan put out, truly a screamer.
    It eventually met its end when I managed to get a finger too close. Damn thing cut right to the bone before the blade snapped.
Tags: Add Tags
