Food & Drink Spec me some broccoli
Discussion in 'General' started by Shirty, 4 Jun 2015.
  1. Shirty
    18 Apr 1982
    I'm far too lazy to do any research of my own, so I'm throwing this out there: I need some broccoli in my life.
    I'd prefer it to be green and/or purple, and it needs to taste a bit like farts whilst I'm steaming it, but not so much that I wouldn't want to eat it.
    I understand that a simple Google search would suffice and provide far more information than I could possibly expect from a group of largely male geeks, but I refer you back to the first four words of my post.
    Thanks in advance.
    Comrade Woody likes this.
  2. Mister_Tad
    27 Dec 2002
    Budget?
    There are a few good ones out there, just depends on what you want to spend really.
    The tenderstem broccoli spears from Waitrose are very tasty, but the sainsbury's ones are more purple if thats a preference.
    I've just had a word with my rabbit, and he enjoys the meatier stems from the standard broccoli crowns, with a preference for Waitrose first, then Sainsbury's, and he won't eat Morrisons or Tesco broccoli. He has those raw, so not sure what they're like when steamed.
  3. jinq-sea
    15 Oct 2012
    How do you taste it whilst it's steaming? Sounds impressive.
  4. GeorgeK
    18 Sep 2010
    I've heard that purple sprouting broccoli is where it's at
  5. jinq-sea
    15 Oct 2012
    I particularly like broccoli stir-fried with soy sauce, ginger and garlic. The broccoli from my local greengrocer's is particularly good for that. He's not local to you, mind, so I'd echo the advice about Waitrose.
    Tad - what's your rabbit's take on ASDA :jawdrop: broccoli?
  6. Shirty
    18 Apr 1982
    I'm willing to go as high as £3/kg for good quality stuff, but I'd prefer to keep it under £2.25/kg if at all possible. I won't settle for pre-packaged produce either, it's got to be loose (should have mentioned this in the OP - apologies).
    I like the steam to smell so rancid that I can taste it, à la air biscuit.
    Me too, but I've never understood why purple = better.
  7. Mister_Tad
    27 Dec 2002
  8. GeorgeK
    18 Sep 2010
    Purple's definitely better - especially when it comes to those meaty stems M_T was on about.
  9. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Just completely out of the blue, but have you thought about eating sausages instead?
    I used to eat broccoli, but I ate some sausages once and found they were much better than broccoli (sausages don't taste of fart) and I haven't looked back since.
    EDIT: You'll probably get a better overclock from sausages as well...
  10. Shirty
    18 Apr 1982
    What do you think the mods do with members when we've banned them?
    They pass them to me and I eat them.
    Case in point.
    Ergo, I've already eaten sausages. he didn't taste of fart but produces a good many in the several weeks I spent devouring him.
    Next!
  11. Mister_Tad
    27 Dec 2002
    Do you get a better overclock with the casings on or off? And for the highest speeds is it good to go for a low or high meat content?
  12. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Freshly picked out the garden and straight into the steamer, spot on.
    Boy o boy does it make you fart! :D
  13. jewelie
    jewelie Ancient geek, newbie to BT
    3 Jun 2015
    Has to be Romanesco Broccoli, because Fractals!
    Also, tastes divine, like a cross between Brocolli and Cauliflower but with butter added - yet without butter added.
    But, yeah... the fractals man, the fractals!
    B1GBUD, GeorgeK and Shirty like this.
  14. samkiller42
    25 Apr 2006
    This thread is much win :thumb:
    Sam
  15. Shirty
    18 Apr 1982
    Now this is a second ever post that I like - have some meaningless green pips under your avatar :D
  16. jinq-sea
    15 Oct 2012
    Like little edamame beans? ;)
  17. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    I can get you broccoli
  18. Scroome
    Scroome Modder
    26 Apr 2011
    Well, thanks to this thread I'm now going to be making stir fry for din dins......
  19. Mister_Tad
    27 Dec 2002
    Whoah there! What do you think this is, Silk Road?
  20. GeorgeK
    18 Sep 2010
    Many tonnes of broccoli apparently...
