News Linux blamed for Samsung laptop deaths
Discussion in 'Article Discussion' started by Gareth Halfacree, 31 Jan 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. derviansoul
    derviansoul What's a Dremel?
    23 Dec 2011
    I think samsung should just have tested the laptops appropriately to ensure that this won't happen, since there is a big minority of users that like linux in their laptops.
    Doesn't matter how bigger are the profits for some of these companies, they are always cutting corners...
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    at first i thought that people were killed by samsung laptops and it was linux's fault
    lp rob1 likes this.
  4. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Kudos to Samsung for not saying "Meh, it's your fault for trying to use it differently than we intended", but rather supporting the product with a different OS. If only the other tech manufacturers were this responsive to the needs of the community.
  5. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    Bring back the death penalty
  6. bowman
    bowman Minimodder
    7 Apr 2008
    It's not really Samsung's fault, it's UEFI. It was supposed to be a step forward in technology and security. Instead, they've abused and twisted it for 'trusted computing'.
    It's basically Anakin Skywalker that's become Darth Vader.
    azrael- likes this.
  7. Icy EyeG
    Icy EyeG Controlled by Eyebrow Powers™
    23 Jul 2007
    Isn't the title a bit contradictory when compared to the rest of the article? I mean:
    It's clearly on Linux fault and it only happens with a handful of Samsung laptops. It's not that all Samsung laptops were affected.
  8. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Clearly Samsungs fault for shipping hardware that could so easily be bricked through software.
  9. yuusou
    yuusou Multimodder
    5 Nov 2006
    "Samsung Laptops with faulty UEFI killed by Linux"
    Seems a more appropriate title.
  10. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Does Samsung even bother to test there own laptops, it not like Linux is a unknown OS
  11. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    If it's sold as a windows machine, while it's the end users choice to install penguin of any flavour, it's not possible for them to test every permutation. It's not like they sold it as supporting Linux when it didn't - They sold the machines as windows machines, the user wanted something Samsung haven't (reasonably) tested, and it broke.
    I think the take away from this is, sure it didn't work, but Samsung didn't fob the user off, and are instead working on a fix.
  12. Tangster
    23 May 2009
    I don't see why people think samsung is to blame here. The laptops aren't advertised as supporting linux. If anything samsung should be praised for acknowledging and working to fix the problem. It's just like people don't expect a mac to support every os under the sun.
  13. faugusztin
    11 Aug 2008
    Actually, the original code was provided by ... Samsung. And if you can fatally damage a board just by executing a code it didn't expect, then it is the failure on the side of the manufacturer. Just imagine a virus doing the same thing as this module does. Mass Samsung laptop suicide.
    https://plus.google.com/111049168280159033135/posts/h7FjkQKZHKT
  14. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    I thought it would come down to this.
    You can kill all kinds of modern electronics by running bad code on them. It's certainly possible to brick most hard disks by sending them the right commands. Anything with firmware - which is effectively everything - can be destroyed in this way.
    Much as the bug appears to be Samsung's, I just love the way the Linux people argue about how much they can be bothered to care. At some point in the Launchpad thread for this, someone called Kate Stewart apparently decides that it's "invalid" and of "undecided" importance.
    Welcome to Linux! We will destroy your laptop, and then we'll claim it isn't really a problem after all, and we can't even work out whether we care or not.
  15. faugusztin
    11 Aug 2008
    So you say it's fine Samsung laptops have a bug which can easily kill your laptop with any OS ? Just because it is Linux where it has been found doesn't mean you won't have a virus later which will try to do exactly this thing.
  16. Tangster
    23 May 2009
    There's a difference between a technically unsupported OS and malicious code.
  17. Corky42
    30 Oct 2012
    But i cant find anything on the Samsung web site saying there laptops are only suitable for Windows.
  18. The Bodger
    The Bodger What's a Dremel?
    26 Dec 2003
    Personally, I've never understood why computers can't all have a small mechanical switch on them which, if not depressed prevents fundamental BIOS firmware from being altered. This could possibly, for example, act directly on the 'read only' pin of the BIOS memory. It would guarantee that changes which could terminally brick a system were a conscious decision by the user, rather than either a mistake by bad software / drivers or malicious in nature.
    As others on the forum have said, bad coding should not be allowed to kill the hardware upon which the OS is running; regardless of whether the OS is supported by the supplier of the computer or not.
  19. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    A big minority? I don't think Samsung is to blame, as with most laptop manufacturers it recommends Windows. If loading Win8 bricked it then fair enough, but part of the risk with Linux is that you are relying on an open source community which doesn't provide the same support/warranty as Windows for example.
  20. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    I really don't see to much of a difference between this and me running a custom linux os on my andriod tablet and phone.
    If it was to brick them (ie kill the hardware) I would not be able to get samsung or any other manufacturer to fix it. They would tell me I loaded a custom OS they did not.
    Well done for samsung at least looking to address the issue.
    Sent on my CM10 JB powered i9100 by TapaTalk 2
