Scratch Build – In Progress Project: Ec-SYNCDESK Evo - The Three Versions - Finish
Discussion in 'Project Logs' started by sangyzan, 27 Aug 2014.
  1. sangyzan
    sangyzan What's a Dremel?
    17 Aug 2014
    Hello everyone, I would like to start this new project, I have seen on the net and in this forum that there are already many (all fantastic and crazy) but I'd like to have something that occurrence can be closed to make space for another place and maybe even in the wall of the living room where the TV is.
    Let's start with these pictures, they are not very good at drawing, this is only a draft, during the phase of the project `'ll decide how to proceed.
    The fixed points are: folding desk fixed to the wall with support for keyboard and mouse attachment.
    A big thank to all my sponsors who are helping me with this project
    Specs:
    Cpu: Intel i7-4790
    Motherbord: Asus Maximus VII Impact
    Vga: ASUS GeForce GTX 750 Ti OC
    Ram: Kingston HyperX Fury memory 8gb
    SSD: HyperX 3K SSD 120gb
    SSD: Samsung 840 Evo 1Tb
    Psu: Enermax Revolution XT 730W Gold 80 plus
    Keyboard: Corsair K70 Red
    Mouse Rapoo
    Monitor: Samsung F6400 FHD 3D 40"
    Watercooling:
    EK-HDC Fitting 12mm G1/4 - Black Nickel
    EK-HD Adapter 10/12mm - Nickel
    EK-AF Angled 45° G1/4 Nickel
    EK-AF Angled 90° G1/4 Nickel
    EK-Supremacy EVO Copper Plexi
    EK-D5 Vario (12V DC Pump)
    TUBE PrimoChill PrimoFlex™ Advanced LRT™ 12,7 / 9,5mm - Crystal Clear RETAIL 3m
    EK-HD Tube 10/12mm 500mm (2 pcs)
    EK-Ekoolant UV Lime GREEN (premix 1000mL)
    EK-RES X3 250
    EK-XTOP D5 PWM Plexi
    EK-D5 Cover Kit (Nikel)
    Cooler Master Nepton 280L Radiatore
    Cooler Master JetFlow 140mm 2
    Enermax T.B Apollish Blue 6 ventole
    tips are welcome, thanks
  2. GeorgeK
    18 Sep 2010
    Hello and welcome to the forums :)
    I've moved your thread to Modding - Planning for the minute as, unless you have pictures of work in progress, you don't have a project log.
    Also, for your information, your first 10 posts will require moderation so they won't appear instantly.
    GK
  3. sangyzan
    17 Aug 2014
    Hello George, thanks for the welcome
    in reality I already have a work log and on with the job but I wanted to share it here as well if you do not mind ;-)
    Hello everyone, today I took the chipboard panels and I cut the most important parts.
    These will be the supports of the desk....
    This panel will set the side fan ...... 3 will be on one side and 3 on the other side
    this is how it goes on the bottom panel and placed the hardware
    stay tuned ;)
  4. GeorgeK
    18 Sep 2010
    In that case I'll move it back! Nice neat work too :)
  5. sangyzan
    17 Aug 2014
    thank you very much ;-)
  6. sangyzan
    17 Aug 2014
    work continues ........ I cut the holes in the side panels where they will attach the 120mm fans and "probable" radiators
    this is the magazine of the keyboard and mouse
  7. sangyzan
    17 Aug 2014
    cutting the front panel for keyboard compartment
    Stay tuned ;-) ;-)
  8. sangyzan
    17 Aug 2014
    I proceed with the slots dimension 5.25 DVD writer and the other ......
  9. sangyzan
    17 Aug 2014
    Hello everyone, I cut the rear panel to support the motherboard and power supply ......
    the screws will change ......
    temporary power supply
    Stay Tuned ;-)
  10. sangyzan
    17 Aug 2014
    hello to all, work continues......sorry if some pictures are not visible but the phone sometimes does not work well ;-)
  11. sangyzan
    17 Aug 2014
  12. sangyzan
    17 Aug 2014
    stay tuned ;-)
  13. sangyzan
    17 Aug 2014
    Cut the top panel to glass
    mesh for cooling fans
    and here it is attached to the wall
    ok guys what do you think? are in half the work. there still so much to do .....
  14. sangyzan
    17 Aug 2014
    Hi guys, a little upgrade ..... I built support for the keybinding and mouse. there is still some finishing and the bottom cap
    Stay Tuned ;-)
  15. sangyzan
    17 Aug 2014
    continues with the work, I have finished the top panel. now only missing the glass that comes to me next week.
  16. sangyzan
    17 Aug 2014
    I built the bottom plug for the keyboard compartment
    gas pistons to lift the top cover
    soon with new works ;-)
  17. sangyzan
    17 Aug 2014
    hello guys, today I built the front panel power button, reset and ignition lights
    I also added 3 blue LEDs that illuminate the panel at night
    I created the cover for the wires from the front panel of an old radio
    ok guys, it's all for the moment .... I hope you enjoy it ;-)
  18. sangyzan
    17 Aug 2014
    ok guys, some up. I got the double glass is 8mm, and I have siliconized. I inserted the led lights and to test to see what effect it had, the hardware you see is temporary, slowly will buy everything and I will insert ... hope you like it
  19. sangyzan
    17 Aug 2014
  20. sangyzan
    17 Aug 2014
