Other Free wysiwyg HTML editor and FTP uploader
Discussion in 'Software' started by M7ck, 18 Oct 2010.
  1. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    As per title, can anyone reccomend any free products.
  2. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
  3. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Any others? That one doesn't work
  4. suenstar
    suenstar Collector of Things
    13 Sep 2009
    Amaya is a fairly popular open source WYSIWYG editor. -link-
    KompoZer is another, never tried it myself and it looks pretty basic but it might be worth a try. -link-
    Quanta Plus is another fairly simplistic style editor, it was my preferred editor before I learnt proper coding though. -link-
    If you want a really beefy bit of software enriched with a mixture of features then I'd recommend taking a look into Microsoft Visual Web Developer 2008 Express (the express editions of their software are free for non-commercial use). -link-
  5. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    was going to say this
  6. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    For uploading I use FireFTP addon for Firefox. But I only code in notepad, so can't help you there.
  7. Edwards
    Edwards Minimodder
    8 Oct 2010
  8. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    Yep, KompoZer, Notepad and FileZilla.
    Learning to do it all in Notepad will give you the cleanest results as WYSIWYG editors tend to freak and dump unnecessary code into a page. I'll sometimes use KompoZer at the start of a project to see what all the elements are doing before moving to notepad and adding PHP specific stuff.
  9. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    For html you can use Kompozer and for FTP.
    But if you want to get serious with html invest in Dreamweaver. Its not that expensive and really really good
    edit: Silver beat me to it :)
  10. EvelynStar
    EvelynStar What's a Dremel?
    18 Oct 2010
    My favorite editor is Bluefish, But Linux is my thing
    This is a good context editor and can be used for all sorts of editing, HTML, PHP, SQL, C etc.
    Can even cope with linked HTML CSS files and links into Firefox and possibly other browsers to view output
    May even do a windows version but that doesn't interest me.
