So I pretty much finished my "Armor Revo Spartan Edition"(link in sig). I am gonna be waiting a long time till I can afford to start the wifes build so as a result I created a craigslist post asking for unwanted pc parts. I ended up getting a few old computers(P4 old) and one of them was in a little shuttle type case(under an inch of dust/cigarette tar). So I thought I would give a go at making a decent looking mod out of it. I play a lot of League of Legends, and my main champion is Leona. Her play style in my opinion is best represented in her "defender" skin. It should also look really cool with the budget i'm gonna be willing to put into this. I spent the first day just taking it all apart and washing everything REALLY good. Pics of everything taken apart Then I decided to remove some of the unnecessary parts/brackets. After that I sanded and primed the skeleton. Then I plasti dipped the mobo and painted the ram and cpu cooler. will try to post more soon.
update skeleton cut down to size this is the front panel before i started cutting.. I didn't like the handle so I removed it. Still got some smoothing of tabs and what not to do obviously but i got a few of the bars cut also and am starting to be able to get an idea of what it will look like. well the front panel anyway. I have pretty much decided I want to put Leona's defender shield on the top of the case. I am still debating on how to make it though and whether or not to lay her sword down the middle of the shield or on the front.
update MODDERS MESH PROVIDED BY MNPCTECH. THANK YOU MNPCTECH! I absolutely love working with the mesh. It looks amazing and is easy to work with!
got the shield done! and the shell itself as well just need to put the feet on it, do cable management, and cleanly install the lights.
