Windows WIFI SHARING
Discussion in 'Software' started by nichos, 28 Mar 2014.
  1. nichos
    nichos Minimodder
    17 Feb 2006
    Hi,
    if a granny annex next to a cotage is let & the tenant allowed to use the owner's broad band can he access the owner's PC/Laptop, interfere with it, read files e.t.c.?
  2. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    In simple terms, unfortunately, yes. A VLAN will go some way to adding security, but is not impenetrable.
  3. GeorgeStorm
    16 Dec 2008
    I the owner doesn't have any sharing enabled then I think the tenant won't be able to easily access anything the owner doesn't want him to.
  4. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I'd also be concerned about what content the tenant might be downloading from the net??
    It's your line so I'd imagine the buck would stop with you if he/she was doing something they shouldn't.
  5. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    What I would do if I was to make available a connection to someone else 'untrusted' is make a separate AP running something like ipcop that supports forcing a VPN connection service like private internet access and stick it on a different subnet to my personal network. This way it is both isolated from your personal systems and is using a vpn tunnel which theoretically your ISP can't monitor traffic on.
  6. TheStockBroker
    19 Nov 2009
    +1
    This also give you plausible deniability should anything happen re external sources
  7. nichos
    nichos Minimodder
    17 Feb 2006
    SOLVED
    Thanx all, all these are beyond me so tenant will have to get his own B.Band.
