got a problem, i havent added any new hardware etc etc. everything is up to date (drivers etc), but all of a sudden my games ranging from bf4 to diablo 3 are stuttering.. the ping is fine, the fps is fine.. i will have about 20 seconds or more of game play, then it seems to jump around a bit then fine for a bit then jumps around and this goes on and on.. any ideas?
Do you use MSI afterburner at all? I had this when the Riva tuner server part of it was running, stopped it from starting with afterburner and been fine ever since.
Spyware? Run spybot and have it clear your temp files too. Also check task manager and see that nothing is running in the background that shouldn't be, and also check your ram usage.
No done a spyware scan, anti virus as well. Going to try a network cable instead to see if it is that. Not sure why I have tried it before
