Windows Metro: Last Light DLC lags.
Discussion in 'Gaming' started by Kronos, 21 Aug 2014.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    Bought a season pass (£1.74) for Metro: Last Light and obtained the DLC. Spiders Lair and the lag, when it gets busy is horrendous.
    Now I have not played the main game for a while but I certainly did not get any lag issues with. Googled the issue and thought I had solved it with installing the latest PhysX but a short time later framesrates dropped again.
    Any one any suggestions? Spec in signature.
  2. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    An i5 @ 4.3mhz, probably the problem there
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Care to elaborate?
    Edit and I have just noticed that my signature is wrong in relation to my CPU it should read stock speed 3.3GHz not 4.3.
  4. jinq-sea
    15 Oct 2012
    It's a bit of a snide joke 'cos you've put MHz not GHz (and therefore an unhelpful suggestion)!
    Have you completely wiped out all graphics drivers and reinstalled them, Glenn?
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    I thought as much when I also noted the MHz. lol.
    It is a relatively fresh install of Windows and hence the GPU drivers Sam. But for some odd reason when I removed the Asus 670 from the SLI set up about a week ago I had to install the latest drivers for the remaining Evga. No Idea why that should have necessary but there you go.
  6. jinq-sea
    15 Oct 2012
    I might be minded to uninstall all the nVidia package and then do a reinstall and select the 'force clean install' option (it is called that, isn't it? I can't remember OTOH).
    You might find that things have got a bit upset since you SLi'd and then non-SLi'd - if that doesn't work, give DDU (Display Driver Uninstaller) a crack!
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    Cheers mate will look into that.
  8. Parge
    16 Jul 2010
    You sure PhysX isn't on? That'll absolutely murder your framerate.
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    I am sure I have had it on and off with little difference but will check again as I have just completed a clean install of the Nvidia drivers.
