Graphics AMD's Mantle Comes To Sniper Elite 3
Discussion in 'Hardware' started by AMDMatt, 2 Oct 2014.
  1. AMDMatt
    AMDMatt AMD Rep
    9 Sep 2014
    Exciting news folks, Sniper Elite V3 now has Mantle support and the performance uplift is nice. :rock:
    Full Article
    http://www.rebellion.co.uk/blog/2014/10/2/mantle-comes-to-sniper-elite-3
  2. Parge
    16 Jul 2010
    Just read this. Really awesome!
    For me, if Mantle is compatible with Star Citizen when I come to buy a GPU, an AMD card will probably be a no brainer for me.
  3. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Why are the other graphs shown in the Overclockers thread also not shown here? You know the ones that show the Mantle improvement to be basically non existant at 1080p with AA.
    http://forums.overclockers.co.uk/showthread.php?t=18627606
    Also the graphs shown above are somewhat useless as a Mantle comparison as they don't include DX11 performance numbers for the AMD cards...
  4. AMDMatt
    AMDMatt AMD Rep
    9 Sep 2014
    Hi Xaser,
    Those graphs are included in the url i linked to at the bottom of the opening post. Sometimes i will mix images up a little from forum to forum to keep things fresh. Rest assured though everything is in that link.
    Here are my results
    3970X@4.9Ghz
    290X@1000/1250
    14.9 WHQL
    1080P - Mantle
    Sniper Elite 3 Benchmark Report (Mantle)
    Created: 2014-10-02 at 16:29:22
    Version 1.11 Build Version: 2014.10.02.001
    Average FPS: 59.0
    Minimum FPS: 22.7
    Maximum FPS: 74.4
    Number Of Frames: 4503
    Average Frame: 16.938ms
    Minimum Frame: 13.432ms
    Maximum Frame: 44.037ms
    Machine Name: MATT
    Monitors: 1
    Operating System: Windows 8 Professional (build 9200), 64-bit
    System RAM: 16316MB
    CPU: Intel(R) Core(TM) i7-3970X CPU @ 3.50GHz
    Number of Cores: 12
    GPU Name: AMD Radeon R9 200 Series
    Feature Level: Mantle
    Dedicated VRAM: 4096MB
    Resolution Width: 1920
    Resolution Height: 1080
    Texture Detail: ULTRA
    Shadows Detail: ULTRA
    Draw Distance: ULTRA
    Anti-aliasing: HIGH
    Supersampling: OFF
    Anisotropic Level: 16
    Obscurance Fields: ON
    Tessellation: ON
    Ambient Occlusion: ON
    Motion Blur: ON
    Vertical Sync: OFF
    Reduce Mouse Lag: OFF
    Stereo 3D: OFF
    1080P - DX
    Sniper Elite 3 Benchmark Report (DirectX)
    Created: 2014-10-02 at 16:35:42
    Version 1.11 Build Version: 2014.09.30.004
    Average FPS: 56.0
    Minimum FPS: 21.0
    Maximum FPS: 71.6
    Number Of Frames: 4274
    Average Frame: 17.852ms
    Minimum Frame: 13.966ms
    Maximum Frame: 47.618ms
    Machine Name: MATT
    Monitors: 1
    System RAM: 16316MB
    Number of Cores: 12
    Feature Level: DX11.0
    Dedicated VRAM: 3072MB
    Anti-aliasing: HIGH
    Supersampling: 4.0x
    Tessellation: ON
    Motion Blur: ON
    Vertical Sync: OFF
    Stereo 3D: OFF
    1440P - Mantle
    Created: 2014-10-02 at 17:11:56
    Average FPS: 36.1
    Minimum FPS: 11.1
    Maximum FPS: 46.3
    Number Of Frames: 2766
    Average Frame: 27.674ms
    Minimum Frame: 21.613ms
    Maximum Frame: 89.870ms
    Machine Name: MATT
    Monitors: 1
    System RAM: 16316MB
    Number of Cores: 12
    Resolution Width: 2560
    Resolution Height: 1440
    Anti-aliasing: HIGH
    Supersampling: OFF
    Tessellation: ON
    Motion Blur: ON
    Vertical Sync: OFF
    Stereo 3D: OFF
    1440P - DX
    Created: 2014-10-02 at 17:00:23
    Average FPS: 34.7
    Minimum FPS: 11.5
    Maximum FPS: 120.7
    Number Of Frames: 2664
    Average Frame: 28.796ms
    Minimum Frame: 8.286ms
    Maximum Frame: 86.603ms
    Machine Name: MATT
    Monitors: 1
    System RAM: 16316MB
    Number of Cores: 12
    Anti-aliasing: HIGH
    Supersampling: 4.0x
    Tessellation: ON
    Motion Blur: ON
    Vertical Sync: OFF
    Stereo 3D: OFF
    4K - Mantle
    Created: 2014-10-02 at 16:53:56
    Average FPS: 17.3
    Minimum FPS: 5.7
    Maximum FPS: 21.3
    Number Of Frames: 1339
    Average Frame: 57.711ms
    Minimum Frame: 47.012ms
    Maximum Frame: 176.372ms
    Machine Name: MATT
    Monitors: 1
    System RAM: 16316MB
    Number of Cores: 12
    Resolution Width: 3840
    Resolution Height: 2160
    Anti-aliasing: HIGH
    Supersampling: OFF
    Tessellation: ON
    Motion Blur: ON
    Vertical Sync: OFF
    Stereo 3D: OFF
    4K - DX
    Created: 2014-10-02 at 17:03:06
    Average FPS: 16.6
    Minimum FPS: 6.1
    Maximum FPS: 41.0
    Number Of Frames: 1287
    Average Frame: 60.247ms
    Minimum Frame: 24.386ms
    Maximum Frame: 164.733ms
    Machine Name: MATT
    Monitors: 1
    System RAM: 16316MB
    Number of Cores: 12
    Anti-aliasing: HIGH
    Supersampling: 4.0x
    Tessellation: ON
    Motion Blur: ON
    Vertical Sync: OFF
    Stereo 3D: OFF
  5. Parge
    16 Jul 2010
    I don't think you've understood what Mantle does. You only see small performance gains at the top end because its GPU limited there. In simple terms, Mantle helps balance load over cores, and removes CPU bottleneck.
  6. AMDMatt
    AMDMatt AMD Rep
    9 Sep 2014
    This is true, however it can also help even at higher resolution. Depends on the game really. You're right in what you say though Parge, Mantle has a bigger impact at lower resolutions and when cpu limited scenarios present themselves.
    Looking at my results above i got a 3fps increase at 1080P with a 6 core 12 threaded cpu. That's not bad at all.
    I would expect to see big gains all round once crossfire is implemented. Certainly i see that in every Mantle enabled game with crossfire support when i use my setup.
  7. rollo
    rollo Modder
    16 May 2008
    Your own 4k mantle test does not really show it as been great for it either. Your own results are behind direct x in both min and max fps. Even the Average is only 0.6fps better.
    I have a question do you think Mantle or tech like it will eventually make gaming at 4k possible on lower end cards? As removing the CPU limitations at high end will not really assist in this surely as the games will require high end CPUs anyway to game at 4k?
    You have the highest rated single card gpu by AMD and your results would indicate its unplayable in direct x or mantle. How many generations of gpu tech are we from a single gpu setup at 4k as the r295 is not the best option for many due to drivers / cost.
  8. Parge
    16 Jul 2010
    No, higher resolutions almost always = GPU limited.
  9. AMDMatt
    AMDMatt AMD Rep
    9 Sep 2014
    This is the first pass of Mantle in Sniper Elite V3, so more improvements will come over time. However the biggest gains will always be in multi gpu setups and cpu limited scenarios. There is more to it than just fps averages though, frame times also play an important role. Good, consistent frame times are responsible for a smooth gaming experience and this one area Mantle excels in under crossfire.
    We're probably a long way off a single gpu having enough grunt to run games at 4K maxed out. Not even Mantle magic can solve that I'm afraid. For 4k at high details you need to be looking at two cards minimum ideally. Three is the sweet spot currently.
    It's true what you say though, the need for a top end cpu certainly diminishes somewhat the higher resolution you go as you become gpu limited.
    Just remember in my tests I'm only running one card. I posted some results elsewhere and i used 2x290 in crossfire in DirectX. I will post my results so you can look at them.
    3970X@4.9Ghz
    14.9 WHQL
    2x290X@1000/1250
    1440P
    Created: 2014-10-03 at 07:56:57
    Average FPS: 67.9
    Minimum FPS: 9.5
    Maximum FPS: 895.9
    Number Of Frames: 5141
    Average Frame: 14.720ms
    Minimum Frame: 1.116ms
    Maximum Frame: 105.419ms
    Machine Name: MATT
    Monitors: 1
    System RAM: 16316MB
    Number of Cores: 12
    Anti-aliasing: HIGH
    Supersampling: 4.0x
    Tessellation: ON
    Motion Blur: ON
    Vertical Sync: OFF
    Stereo 3D: OFF
    2x290X@1000/1250
    4K
    Created: 2014-10-03 at 07:51:53
    Average FPS: 32.5
    Minimum FPS: 5.4
    Maximum FPS: 856.8
    Number Of Frames: 2462
    Average Frame: 30.783ms
    Minimum Frame: 1.167ms
    Maximum Frame: 185.781ms
    Machine Name: MATT
    Monitors: 1
    System RAM: 16316MB
    Number of Cores: 12
    Anti-aliasing: HIGH
    Supersampling: 4.0x
    Tessellation: ON
    Motion Blur: ON
    Vertical Sync: OFF
    Stereo 3D: OFF
    96% scaling at 4K
    95% scaling at 1440P
    Crossfire doing its thing.
