Has anyone folded on the new GTX 680, if so, what sort of PPD is it doing, temped to get one Thanks Adam
I couldn't get mine to work. Maybe I need to use the new V7 client but I don't like it. It won't fold under the GPU3 client though. Very strange.
http://foldingforum.org/viewtopic.php?f=38&t=21049&hilit=680&sid=2e5e84144d00c29997fe77e5b08d0511 Read the last page.
how odd, i might give it a month then, before i think about buying it, hopefully they will have a working client for it. anyways need aprils pay check to buy it anyways
I read over on overclockers: You have to use the v7 Client and you need to add the command: "client-type:beta" to the gpu slot See: http://forums.overclockers.co.uk/showthread.php?t=18391807 Does that help? I'm still on 480's so I can't test it...
Yes that works and my 680 can fold however it is dog slow so will wait until they get their app re-written to take advantage of the extra grunt the 680 has.
How many PPD are you getting? I read somewhere that the 6xx cards have been tweaked to be better for gaming at the expense of GPGPU ability compared to the 5xx series cards.
