Equipment 18-55mm lens or similar for canon 60d
Discussion in 'Photography, Art & Design' started by Thaifood, 14 Nov 2013.
  1. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    So recently purchasing a 60d witha 70-200mm f4 l usm lens, I have taken a few photos and am loving the quality and sharpness of the camera/lens.
    I do have a old kit 18-55mm is lens that came with my old 450d, but I am looking for something that gives that better quality in the photos..
    Can anyone recommend any lens that won't break the bank? It doesn't have to be canon..
    Oh and it doesn't have to be f1.8 either.. Anything above that will be fine,
    Thanks
  2. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Whats your budget? 24-105l f4 is around £480 - £500 2nd hand and is a cracking lens.
    Also look at the canon 50mm 2.8 prime (nifty fifty) its about £70 -80 new and itls great quality glass
    Sent from my GT-I9505 using Tapatalk
  3. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    I was hoping around the £300 mark.. Can always go a little higher, but not the £500 mark I am afraid.
    Canon 50mm 2.8? I've seen a 1.8 or 1.4.. Did you mean that?
  4. bdigital
    10 Aug 2010
    Typo should be 1.8
  5. wyx087
    15 Aug 2007
    Try Canon 15-85 mm? But you'd struggle to beat 70-200 f4 L in image quality with any walk-about lens.
    Problem with 24-105 is that it's a full frame lens, not wide enough on crop at short end. 17-40 f4 L is also a full frame lens, designed to be ultra wide angle.
  6. veato
    veato I should be working
    15 Jan 2010
    If you get a good copy the Tamron 17-50 f/2.8 is excellent value for money.
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    I have the non-IS version it's a great lens, the non-IS version is normally sharper than IS version.
  8. wyx087
    15 Aug 2007
    For off brand, my housemate has the Sigma 17-70mm f2.8-4. It's sharp, not very big and has great range. It's a great lens.
  9. whisperwolf
    whisperwolf What's a Dremel?
    1 Sep 2004
    I'd go for either my a 2nd hand of my current lens the old sigma 18-50 the newer os version
    or a tamron 17-50 non IS , but I'm not loving the tamron brand right now due to the faff of my 70-300 lens.
    shots with my sigma can be seen here
    Or find a canon 35mm f2 if you fancy a prime on top of your current kit lens
  10. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    Another shout for the 17-50 non IS Tamron here. It's not as sharp as my 70-200 2.8IS, but it lives on my camera more and for the price I'm not sure I could beat it.
  11. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    Cheers for the ideas.. Will read up a bit about them.. Seems like the tamron and sigma seem to both pretty good
  12. Thaifood
    Thaifood Minimodder
    24 Apr 2009
  13. RinSewand
    11 Sep 2006
