Scratch Build – In Progress [Projetc] Nautilus - Laying down some carbon...
Discussion in 'Project Logs' started by lenne0815, 4 Jul 2010.
  1. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    curious ?
  2. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Yes, yes I am. Looking forward to seeing more. The case design pics of this were awesome, so seeing it fleshed out is something to look forward to!
    Mod on!
  3. lenne0815
    4 Jul 2009
    cheers naloc, maybe i get the carbon molds done today...
  4. [ZiiP] NaloaC
    9 May 2008
    As with many, the best I can do is some sleeving. Would never be able to do something like this. Best of luck, look forward to updates.
  5. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    this will be good
    and i hope that you use your CNC in the log :D
  6. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    Yum. Carbon Fiber Cheesecake!
  7. nebun
    nebun Midnight Modder
    7 Jun 2010
    ooooooooooooh, this is gonna be good, I think my curiosity level is peaked :thumb:
  8. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Thats a thing of beauty, you'll need big desk so you can display it well ( so sad that so many great cases get plonked on the floor or under a desk where they are difficult to appreciate ). Will be watching for sure :)
  9. Cheapskate
    13 May 2007
    Is it going to open up like the contest version?:eeek:
    I'm really looking forward to this. You guys keep level-upping here.
  10. lenne0815
    4 Jul 2009
    its my plan to build it that way :)
  11. Cheapskate
    13 May 2007
    SSSSSSSWWWWWWWWEEEEEEEEEEEET!
  12. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    interesting!
  13. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    I thought the steampunk version you entered into the sketchup competition was good, but this takes it to another level. Loving the material choices, if you pull this off it will almost certainly be a MOTY contender!!!
  14. Metric
    Metric has a bazooka
    1 Jun 2009
    w00t! Go lenne! :rock:
  15. motas
    motas What's a Dremel?
    7 Dec 2009
    That looks awesome cant wait to see it.
  16. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Hey stop it - I'm planning to go for MOTY ><
    Looks awesome !
  17. shah
    shah Minimodder
    29 Jan 2010
    This is one hell of a design... :D
  18. lenne0815
    4 Jul 2009
    Cheers guys !
    I started making the molds today, expect a big update later on..
  19. Cheapskate
    13 May 2007
  20. lenne0815
    4 Jul 2009
    Ok, lets start :)
    Cutting styrodur boards ( 60 mm thick )
    Gluing them the parts together with double sided tape ( on styrodur it sticks really strong, propably rather the styrodur would break that the tape would come loose )
    Cutting the Base boards out of 4mm Multiplex
    Giving them a quick sand and some air to get rid of the dust
    Sticking the styrodur to the baseplates
    Getting a bit of pressure on it :D
    Finished !
    ok, lets chuck them on the router :)
    routing routing....
    getting the mood right :)
    Thats it for now, ill finish routing them today...
