Case Mod - In Progress Corsair Graphite 490T bullet - update: 150811 - Final Pics before Gamescom
Discussion in 'Project Logs' started by thechoozen, 1 Mar 2011.
  1. thechoozen
    thechoozen Minimodder
    9 May 2006
    Last Sunday we decided to start a new project, the reason is easy to explain....we couldn´t make any progress on our Pirates Case, because it was already packed and ready for the cebit.
    We also had a few cases staying around us, so we thought why not create a new mini itx optimized version of one of them....so we finally picked a Corsair Graphite 600 T as our Base and started to disassemble it....
    Our Plan for this Mod is also easy to explain, we´re going to reduce the height of the case about 11 cm, so that we could still integrate a full size PSU, a big Graphic Card and a watercooling setup beside the mini Itx System....
    after disassembling all parts we cutted all parts into 3 parts so that we could take away approx. 11 cm in the height of the case....
    then...we started to rebuild the case...
  2. pyro1son
    pyro1son Linux User!
    18 Aug 2010
    going to be watching this one. looks great! :thumb:
  3. KidMod-Southpaw
    28 Sep 2010
    Agreed, subbed for something very new! For example, first time I've seen a 200mm intake an a mini ITX case!
  4. ThirtyQuidKid
    ThirtyQuidKid Minimodder
    11 Jun 2010
    Another interesting mod. Like to see the finished article here.
  5. Guest-23315
    Guest-23315 Guest
  6. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    Not even finished and I'm certain I want one! :p
  7. thechoozen
    9 May 2006
    :clap: thx m8´s!!! :clap:
    in the last days we made a lot of progress, but too sad...it´s not really visible....:wallbash:
    what we did is quick to explain....after cutting all parts into several pieces....we had to reconnect them.....
    So one of the first things we did, was to bend a few angles which should help us to reconnect all pieces and bring more stability to the cutted edges. After that we still had a few gaps and slits which had to be filled with a bit of filler/putty. While filling all gaps, we also filled this small designed by Corsair lettering which was embossed into the mainbase.
    Beside that we also changed the lighting color of the 2 x 200mm Fans from white to orange.
    And last but not least we sprayed a first coat of test laquer on the first parts, so that we could see which parts still needs some work......
  8. morkfromork
    morkfromork Minimodder
    2 May 2010
    Awesome mod. I don't like the look of the 490 case but it's starting to look good as an itx case.
    Have subbed and can not wait to see the finished job.
  9. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Whahah This looks awesome :D!
  10. KidMod-Southpaw
    28 Sep 2010
    Agreed, I want to see the whole thing with the panels and plastic on!
  11. ThirtyQuidKid
    11 Jun 2010
    The cut and shut PC is shaping up very well.
    Really good effort and results starting to show.
  12. thechoozen
    9 May 2006
    thx a lot m8´s!!!
    me too, but that will took a few days ...until all parts are ready .... :D(not to mention that we already tested if all parts can be assembled as they should :thumb:)
    in the last days we made a bit of progress....atm the inner case is nearly finished so that you can´t see where we made the cuts....the plastic parts still needs some work...but as soon as they´re finished you won´t find a scratch on them :D
    Beside that we also started to build a midplate / PSU Cover and an HDD tray which will be placed under the midplate....
  13. pyro1son
    18 Aug 2010
    Sweeeeeeeet! :thumb:
  14. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Ow my :D!
    Verry small and neat update :D!
  15. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    liking the direction this is heading
  16. MarcosLFV
    MarcosLFV What's a Dremel?
    7 Mar 2011
    Very nice! :thumb:
  17. MarcosLFV
    7 Mar 2011
    That shrink case are cool :thumb:
    Congratulations!
  18. Pulga DSTV
    Pulga DSTV What's a Dremel?
    7 Mar 2011
    Needless to say much
    Fine Design
  19. thechoozen
    9 May 2006
    thx!!:rock:
    yesterday we "finished" the cover for the bottom of the case, for that we add another piece of metal to the prepared cover and added the first coat of paint...beside that we drilled all holes in the hdd drive cage.
    We also prepared the side panel for the next cuts ...so that we can continue the work on it today...
  20. KidMod-Southpaw
    28 Sep 2010
    Yums! I love dinky builds!
