Scratch Build – In Progress Capsaicin 3.0
Discussion in 'Project Logs' started by BIRD_Customs, 19 May 2017.
  1. BIRD_Customs
    BIRD_Customs What's a Dremel?
    27 Mar 2017
    Hey Guys,
    I have already started a project called Capsaicin 3.0. It’s the 3rd scratch build in my Capsaicin line.
    This project is supported by :
    AMD, ASUS, Alphacool, Noiseblocker, Seasonic, Ballistix and Crucial
    The plan is to create a frame that looks organic – just like the first Capsaicin.
    Specs :
    CPU Ryzen 5 1500x
    MB: Asus Crosshair x370
    GPU: Asus Strix OC RX580
    DRAM: Crucial Ballistix DDR4 32 Gb 2666Mhz White
    PSU: Seasonic Prime Gold 850
    Watercooling stuff Eis Line from Alphacool.
    here some pictures :D
    i think that will be good :D or i hope it :D
  2. BIRD_Customs
    27 Mar 2017
    small update
  3. BIRD_Customs
    27 Mar 2017
    Hey Guys,
    here another Update :D
    Place for the Eispumpe
    First try with all components
    Now its time for the covers
    first painting tests
    Ghostflames or Snakeskin? The people in FB said Ghostflames :D.
    The Alphacool Radiators with a leather Cover
    Now the Tubing, Alphacool Eisrohr Satin
    ok thats all for this moment
  4. Cheapskate
    13 May 2007
    You've certainly taken 'organic' to it's extreme end of the spectrum. It looks like you need real blood for coolant.
  5. BIRD_Customs
    27 Mar 2017
    I take the nanoxia blood red coolant :)
