Scratch Build – Complete ⭐ Mahogany Desk by Husky Bongs [Build of the Year 2018, FINISHED]
Discussion in 'Project Logs' started by Huskybongs, 21 Feb 2017.
  1. Huskybongs
    Huskybongs Minimodder
    11 Feb 2017
    Hello,
    I've been building this a while but wasn't confident enough to put it up on these forums before now.
    The idea is to take that grand piano feeling to a pc. We'll be using fairly nice materials for this such as teak, mahogany, oxygen resistans steel and a lot of chromed parts. The build has been in the works for about 2 years with an estimated finish this spring. (currently doing bespoke cables). With that being said let's go over the parts and into the actual buildlog.
    A massive shoutout to Mikael who's helped me with a lot of the woodwork. This build would not have been possible without your help
    PC parts:
    Motherboard: MSI BigBang Xpower 2, x 79 lga 2011¨
    CPU: Intel i7-3930k @ 4.6Ghz
    RAM: 32GB Corsair Dominator 1866Mhz
    PSU: Corsair ax1500i
    GPU(s): 2xGTX 980s overclocked to whatever I can reach:)
    HDD/SSD: 2xWD red 6tb+3xV-Samsung 500gb. 2 in raid and 1 as bootdrive
    Watercooling:
    Radiators: 2xmonstah 560mm,1xalphacool 360mm
    Pumps: Plexitop EKWB d5x2
    Piping: Iodized copper
    Reservoir: Custom Singularity Dual loop acrylic reservoir.
    Fans: Various Noiseblocker fans 25 in total.
    Sponsors:
    Lets start off then.
    Solid drawing
    Let's weld. Starting off with the basic shape. Table will be roughly 1800x780mm
    Radiator bay:
    Parts started to come in
    After a few more hours I have room for my legs and some placement for the fans
    http://i.imgur.com/UKIGtMkl.jpg
    Space for knees
    Gonna want some monitoring
    The wood was ordered like this. Huge chunks of birch. The will be shaped to be the outer panels of the chassi. It's a really dense wood and it's been dried for years properly before being used.
    Quite heavy actually. These 3 parts weigh about 50kgs or about 110 pounds
    After using different bits and sanding roughly down ending at about 320 grit paper I managed to shape them to the shape I desired.
    Playing around a bit with some of the parts. That's an ST8 Motherboard tray from a caselabs pc
  2. GeorgeK
    18 Sep 2010
    Can you resize your images please - the imgur large thumbnail option usually works best.
    Thanks
    GK
  3. Vault-Tec
    30 Aug 2015
    Aye, massive pics are massive.
  4. Huskybongs
    11 Feb 2017
    Will do as well as all the previous pictures. My apologies. Ill do it on friday
  5. kim
    kim hardware addict
    10 Jan 2016
    yeah, pics are just giants ones, i thought it was my turn....but lessening scale, i could see pics, and wahooo, i love what you've done...for many reasons, first one, your work on wood and metal is just great, it's gonna be a very beautifull and original compter desk, then, your running x79 chipset like me, and third, I am building a PC-desk myself for several weeks, waiting the right moment to start a thread here, so, I will follow your build with interest...good luck for the following
  6. Huskybongs
    11 Feb 2017
    Let's continue then with properly sized pictures:)
    So I contacted Singularity Computers and he luckily agreed to make my design of a dual loop reservoir come to life. The plan was something like this
    Then I needed some legs. Used 60mm hollow steel pipe and some 40x40mm steel for the upper bars.
    And the mounting for the screenstand was lathed by some shaft steel
    Got ze legs in place
    And this will be the placement for the screenstand. Mirroring the design of the legs
    A very professional way of planning:)
    Wouldn't be a proper desk build unless we had support for 3 screens
    We used some 12mm thick steel for this. It's incredibly overkill but it can handle whatever I decide to mount on it
    The legs are connected to the frame with 5 x 8 mm bolts (oxygen resistant)
    Trying to make the angles "talk to each other" if that makes sense:)
    Testmounting some stuff
  7. Huskybongs
    11 Feb 2017
    Thank you! I've resized the picture to the large thumbnail now as previously requested
  8. Huskybongs
    11 Feb 2017
    Continuation
    Had to play around with the parts to see if they fitted properly. They did:)
    Big radiators but they will be completely hidden:)
    Even though it's quite a tight fit
    All the major watercooling parts testfitted
    Playing around with the fan controller
    Got my reservoir back and Singularity Computers also made a video of it. Very very happy with result. It's just fantastic craftsmanship.
    Le Video
    And on to the interior wood. Now this is actually a pretty long process. But to roughly summarize it:
    I had lying around some teak and mahogany plywood and it had been drying up since the mid 1990s so it was just too good to not use for this. I'm just in love with this stuff
    Very tedious process of fitting each panel in individually as well as matching the lines perfectly
    After several hours all the panels fit.
    Had to rework the starboard side a bit
    Got a new cover plasmacut from the local workshop
    Looking decent
    Time to make the holes for the fans and PSU
    In order to cut this out a special tool had to be made.
    Lathed out room for the fans as well. Despite the desk being really big there's not any extra room to work with
    Happy with the result
    The starboard side
    Fused 3 panels on each side together to get them in and out of the table
    Custom PSU mount that also fits 3 ssd's and 2 hdd's
    Made a bottom plate for the Reservoir also to mount it more easily
    Slowly but surely getting progress
    Got some parts back from paint:)
  9. Huskybongs
    11 Feb 2017
    Time to mount the sidepanels. Had to make incredibly sturdy mounting for this since they weigh so much
    From the side
    The front:)
    Started with the varnish. Ended up redoing all this but you'll see soon enough:)
    Couldn't cut these at home due to the thickness so went to the local woodshop. They were rather confused when I said it's a pc:)
    Angles worked out fine
    Starting to look better
    Wanted to get a feel for how it will be to work at this thing
    DX racer for scale
    Got the hardened glass that I ordered
    Rounded corners same radius as the fans:)
    After some work with a CNC I got the sidepanels fixed to have openings for the fans and the fancontroller
    Liking the look now
    Was a bit worried before I testmounted this whether or not it would line up properly with the interior. Gladly it did
    This is not the actual fancovers but wanted to get a feel for how it will look before I drew them up in CAD for the waterjet
    From the inside
    The nightmare of the top part of the wood:) To get this to fit properly we had to get all the angles right and shave off half a millimeter at a time until it fit properly. This was a lot harder than I expected but it was worth it
    It fits!:)
    And now to the gluing. Using Marine glue here. Takes a long time to harden but it's incredibly strong. Also tapping her up so it doesn't move
    Gotta protect the painting
    Probably not the best method but it works:)
    After a bit of manhandling it it's finally glued and won't be touched for 2 weeks
    Just had to test with the glass on.
  10. Huskybongs
    11 Feb 2017
    The 2 weeks had passed and I put it back on the legs.
    Didn't mention it before but the outer shell is actually removable and will remain so if a fan breaks or something like that
    All alone in the corner:)
    Reinforced the on some points just to make sure
    Time to get those holes needed done
    1 Radiator ventiolation hole
    and 2 holes + the mountstand hole
    Getting closer
    That's not how the mountstand will sit. You'll see later
    And the glass hole:)
    Yeah, lets do key ignition. No real reason except it would be really cool:)
    Sits pretty well at it's place
    Trying to get some harmony with the design. Maybe you think that's jibberish but there's some thought put into this:)
    The glass is finally inside
    My friend testsitting it
    And the last cavity needed is for the USB, 6.3 mm audio and volume controls etc. Will be using a homemade potentiometer solution here and hiding the DAC/AMP inside the table
    Had to continue filling up the glue until there was enough to go sanding
    First round of sanding down to 320 grit paper. Will go down to about 2000 eventually
    Wasn't completely happy with the interior panels so I actually redid all of them with 8 layers of 2 component diamond mahogany varnish. It's resistant to heat and water so it will have a long life inside
    Looks a lot better now
  11. Huskybongs
    11 Feb 2017
    Had to make a solution for getting all of the pieces together so had some long screws that goes through the interior panel and the steel frame and end in the outer panel. These can't be seen unless you're actively looking for them
    Mounting solution for the back panel
    Back panel fitted
    Ordered some more watercooling parts from Highflow
    This is what I'll use for audio. The sennheiser hd 650s and and ODAC amp/dac solution from Mayflower Electronics
    Had to make custom hinges or we would never get the glass out easily. Will also install electric motors for this so you don't have to do anything else than push a button
    Might as well mention this is just prototyping. The actual hinges will be made out of 6mm steel
    Instagram filters:) jk
    Made a short video
    Started drawing out the design for the fansgrills. I'll get these chromed
    Made some longer videos where I go through the build
    Lathing out a volume knob
    Playing around with the stains
    And a video update again
    That's it for now will start cablework very soon!
    Dietec likes this.
  12. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Wow, that looks gorgeous!
    Looking forward to more progress
  13. Huskybongs
    11 Feb 2017
    Yeah I'm a huge fan of the riva's and bösch boats. :)
    Furthermore my next project after this table is probably a custom runabout boat in mahogany:) Not that suitable for this forum though
  14. voigts
    voigts What's a Dremel?
    26 Apr 2006
    I'm not really a huge fan of desk builds in general. Having said that, I have to say that this build is just completely awesome. I can appreciate the amount of time to get this thing looking and working this way. Absolutely excellent work with very appealing styling. I appreciate that your not just after bling, but really spending a lot of blood/sweat/tears on the styling.
  15. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I think I have seen photos of this online somewhere. Maybe social media.
    All I can say is that it doesn't even matter that much if someone shares you taste in design. You already have to respect the craftmanship in this. Very well done man. Big respect.
  16. Huskybongs
    11 Feb 2017
    Thank you that's very kind. Yeah I don't love the christmastree-e look of a lot of builds I'm more into the shapes and the less is more mentality. And I just love organic materials
  17. Huskybongs
    11 Feb 2017
    Thank you
  18. Cheapskate
    13 May 2007
    :jawdrop:Whoah!...DUDE!
    Are you kidding? We LOVE this kinda stuff. You could probably post the boat build in 'general' too. there's several car projects in there.
  19. mal
    mal What's a Dremel?
    20 Nov 2012
    What he said.
    The craftsmanship and attention to detail in the woodwork speaks volumes. Are you a cabinet maker by trade? Awesome job. I really like when PCs don't look like PCs. :clap::clap::clap:
    mal
  20. kim
    kim hardware addict
    10 Jan 2016
    :jawdrop: what a job, OMG, your so accurate...splendid really
