Scratch Build – Complete ⭐ The Tiny
Discussion in 'Project Logs' started by dangthaison, 21 May 2017.
  1. dangthaison
    dangthaison What's a Dremel?
    3 Apr 2009
    Hi everyone . I have a new scratchbuild and today i would like to introduce to you .
    I want to talk briefly about ideas. First I want it as compact as possible. Therefore, I chose an ITX motherboard , a SFX PSU ... And because of the bit greedy, I would be watercooling for it .
    Spec hardware :
    - MB: Gigabyte Z270N Wifi
    - CPU : Intel I5 6400
    - VGA: Gigabyte GTX 1050Ti G1 4GB
    - Ram : Corsair Vengeance RGB 16GB Bus 2666
    - SSD : Plextor S1C M2 SSD 128GB
    - PSU : FSP Dagger 500W 80Plus Gold
    Some picture :
    - CPU and Bitspower waterblock :
    - Mainboard :
    - VGA :
    Install waterblock :
    - PSU : I replaced with shorter cable
    - SSD :
    - Ram :
    Ok . First I will try the acrylic sheets :
    This size seems okay : 270 x 220 x 165 ( mm ) . And aluminum ( 5mm) is used as the main material
    The cnc process is complete :
    After folding and mounting test :
    And test everything to see if it fits :
    DDC-LT Pump :
    Compared to a cup of coffee :
  2. dangthaison
    3 Apr 2009
    After sand blasting and anodizing :
    [​IMG][
  3. Cheapskate
    13 May 2007
  4. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Very nice and small too. I'm actually planning a build with the same exterior shape and very similar in size.
  5. Arboreal
    21 Jan 2011
    Holy Anodising Batman! That IS a little stunner:rock:
    Amazing work, and small too. Just how I like 'em
  6. dangthaison
    3 Apr 2009
  7. mal
    mal What's a Dremel?
    20 Nov 2012
    Awesome! :thumb:
    What size/thickness is the radiator? It looks 140mm/65mm.
    mal
  8. Cheapskate
    13 May 2007
    Awesome job. :thumb: -The back of the motherboard needs insulation, though. One clumsy guest, or a dropped penny and zap! :worried:
  9. dangthaison
    3 Apr 2009
    Its 120 45mm bro
    I will make an acrylic cover :D
  10. Hunterbait
    Hunterbait That's how you change it!
    18 Jun 2016
    Mod of the month simply for that fastening design, don't be put out if you see that in one of my future builds :p
    Awesome work
  11. neilhart
    neilhart What's a Dremel?
    2 Feb 2011
    I am very impressed with your design and the cnc work done. The cuts to support your folds at the ends produced near perfect parts and your threaded bar stock concept is one that I had not seen before.
    Thank you for sharing your project.
  12. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    Very nice build!
  13. ChrisHowell
    ChrisHowell What's a Dremel?
    29 Aug 2015
    This is really cool man. Good work on the ITX sizing. In a bunch of ways, you can actually make a smaller build by specifically using liquid cooling, right!? I see that your power supply sits where a traditional air cooler would go for the CPU and your case doesn't need to be as tall to accommodate the usual hefty GPU cooling setup.
    Above that, I'm jealous of your sandblasting and metal finishing facilities, the finish looks awesome and that finish on a commercial product is usually quite expensive.
  14. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Cleverly Simple.
