hi everyone my name is jojoharalds and I am 28 years old, (new to this forum) í recently started my Casemod and thought I should share it with you. THIS WILL BE SPONSORED BY. Sent from my LG-E975
Welcome to the forum. Just to let you know that I will be deleting your thread once you've had a chance to read this - I cannot PM you until you have more posts on here. The reason for me deleting it is that you need to have actual pictures of work in progress for a Build Log thread. GK
I do have alot of pictures of progress, but since I'm doing it through my phone I didn't get a chance to upload them all, if you could give me some time that would be great, Sent from my LG-E975
well here is the journey of this mod so far, first stripping the case down to the frame. custom from panel, custom top panel, custom back panel, custom motherboard tray, custom midplate/psu cover, test fitting the radiator s test fitting the powersupply wich coolermaster were kind enough to sponsor me with, (HUGE THX TO COOLERMASTER) now to the custom midplate(made out of 2mm aluminium, like the rest of it) stay tuned for more. Sent from my LG-E975
Very nice Just so you know, your first 10 posts might take a while to show up as they have to be moderated Keep up the good work!
Frozencpu order fittings and more. everything you might need for acrylic tubing, saw, heat gun, Monsoon bending kit, silicon tube, acrylic polish, and some more awsome stuff, this is my set so far(STILL EXPANDING) Alphacool Vpp655 assembly (ek dual pumptop) And the pumps fit perfectly into the psu cover/midplate(for a clean and satisfying look) And some pci-e extensions from holland/geldfabriek.nu awsome stuff. stay tuned for more. Sent from my LG-E975
EK SPONSORSHIP. Huge thanke you to ek water blocks, they were so kind to provide me with: 360MM Coolstream PE (new edition of radiators from them) 240MM CoolStream PE Ek csq pump top 2x Ek nickel pump cover 2x 5L Ek uv blue liquid Thank you very much. Sent from my LG-E975
custom backplate, making the cutout for 3 radiator(240mm ek) And here comes the preparation for mounting the GPU's, with extenders. And í also made the reservoir mount on top of the ssd's (didn't want to put them behind the motherboard tray, makes Cablemanagement easier and cleaner looking) Sent from my LG-E975
and now to the painting (powdercoat) and overhaul, first the white paint(even painted the screws And the blue(I think it turned out great) like the colour ombination, same colour as on my car;-) received my sleeves and some led, From ICEMODZ.COM big thanks for awsome sleeving, and fantastic led work. now putting installing 3pin adapters for more fan connectors. and putting u channel on the fan cutouts(for anticvibration and clean looks) Reservoir mount will be made out of 3mm thick acrylic, with some led behind. and white screws. also put led under the psu cover to light up the silver pump covers through the the blue acrylic Window. And since I will be using extenders, I will not be needing the triple slot ridge, and will tberefore exchange it for a dual slot bridge(save space and cleaner look) and also had to make a stability bracket for the GPU's since they are a little bit heavy on the back end. (made out of blue acrylic. Polishing the cpu block(EK SUPREMACY with smoked acrylic top) before. And after. That's all for now, keep u posted as soon I will continue, waiting on some stuff to arrive. Stay tuned. Sent from my LG-E975
Thank you for the updates - looks like you've made some great progress. Looking forward to see where you go from here. Just wondering... will you be installing any dust filters on the intake/radiator fans?
yes there will be dust filters on top and the front(since I am having some dustproblems on my THOR D3SK) Sent from my LG-E975
