Tubing?
Discussion in 'Watercooling' started by Craig_T, 19 Mar 2015.
  1. Craig_T
    Craig_T What's a Dremel?
    2 Aug 2014
    I haven't bought tubing in a while, but have had a complete memory blank...
    What is the common size that everyone uses now? I remember when I bought it last time, there was two sizes one I think very thin with an OD about a fingers width and the other with an ID about a fingers width (The size I bought)... But reading the sizes on shops I am getting very confused now!
    So.. As noob a question as it is, which size am I looking for?
  2. The_Crapman
    5 Dec 2011
    The most common is 10/13mm (3/8"-1/2") as far as I'm aware. It's what I use anyway.
  3. Big Elf
    23 Apr 2009
    3/8"ID, 5/8"OD or 1/2"ID, 3/4"OD are common. I prefer the first.
  4. Craig_T
    2 Aug 2014
    I think the 10/13 is the one I used, it sounds about right. The option Big Elf has said, sounds to me like it has a very thick wall in the tube and therefore would not be very flexible?
    10/13 has a nice size for the barb, tube is not too big and the diameter of the tube wall is only 3mm so it gives you some flexibility?
  5. Big Elf
    23 Apr 2009
    3/8"ID, 5/8" is probably the best compromise between thickness and flexibility as it can bend quite a bit before kinking.
    1/2"ID, 3/8"OD is prone to kinks unless the tubing is pretty much in straight runs.
    This is 3/8"ID, 5/8"OD and the couple of sharp bends wouldn't be possible with the 1/2"ID, 3/8" unless using anti-kink coils
  6. Craig_T
    2 Aug 2014
    This is an old picture of my setup, can you work out what tubing this is from the picture?
  7. Big Elf
    23 Apr 2009
    I think that might be 1/2"ID, 3/4"OD
  8. Craig_T
    2 Aug 2014
    Ok great, I think I am getting a bit better idea of them now. Thank you
