Hardware Asus P5K Pro
Discussion in 'Article Discussion' started by CardJoe, 2 Apr 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. kenco_uk
    28 Nov 2003
    Certainly is a strange layout. The sata port placement on recent boards really needs sorting out.
    Good to see there is a pot of gold at the end of it though :)
  3. naokaji
    naokaji whatever
    8 Dec 2006
    The layout basically kills it, I mean there are plenty of P35 boards avalaible so I can't really see a reason to buy a board with a flawed layout.
  4. badders
    badders Neuken in de Keuken
    4 Dec 2007
    It also only has the ALC883 Audio Codec, Which disables 5.1 Audio over SPDIF - Stereo only.
    Also, there's no line-in passthrough on it. :(
  5. Guest-16
    Guest-16 Guest
    Like I said - for "basic" audio, it suffices, but otherwise just get a cheap audio card.
    Nao - fair play mate - there are a LOT of good P35 boards worth buying.
  6. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    That 24-pin position... :rolleyes:
  7. Vode
    Vode What's a Dremel?
    2 Apr 2008
    Spelling, page two: "mosphets"
  8. Guest-23315
    Guest-23315 Guest
    Can you guys please get a DFI DK P35 to compare it too?
    Apart from the layout, its a good looking board :D
  9. Guest-16
    Guest-16 Guest
    British spelling ;) I'm insistent on the ph - just like Sulphur.
  10. p3n
    p3n What's a Dremel?
    31 Jan 2002
    I kinda assumed when they created SATA that the size of the connectors intended people to place the ports on the 'underside' of the mobo in a line, you'd still have a few mm clearance from the case standoffs and you'd have 6+ uncomprimised ports!
  11. naokaji
    naokaji whatever
    8 Dec 2006
    Yep, thats what I meant, my point was the P5K pro loosing ground due to that, I'll admit I should have worded it better.
  12. Guest-16
    Guest-16 Guest
    I won't deny it was certainly a poignant consideration, but it's a recommended product (it works very well and we would use one ourselves) and not an excellence (obviously) partly due to these two reasons. Inevitably there are people who want different things from a board :)
  13. prosser13
    prosser13 Hasn't got a Dremel!
    29 Mar 2008
    MOSFETs is an acronym, not a word ;)
  14. Guest-16
    Guest-16 Guest
    LOL Fair point. I just thought it was Americanisation of the English language (as usual).
    Go on clever-cloggs - what does it stand for then? ;)
  15. phuzz
    phuzz This is a title
    28 May 2004
    hmm, thought I might read this and regret buying a P5KC last month, but that ATX connector alone is enough to put me off. (tho the P5KC still has the slightly daft SATA positioning, and the same rubbish floppy port location, although that's not much of an issue).
  16. kenco_uk
    28 Nov 2003
    Well, blimey. I must admit, I thought mosfet was the given way of spelling it.
  17. Guest-16
    Guest-16 Guest
    I shall capitalise it in future too! Every day's a school day. ^_^
  18. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Metal
    Oxide
    Silicon
    Field
    Effect
    Transistor.
    Reading the review took this mobo off my shortlist for my next upgrade. That layout sucks like a Dyson!
    Edit: Oops. Didn't see the linky in Kenco's post! :blush:
  19. Jojii
    Jojii hardware freak
    12 Dec 2007
    what about the 3870 x2, does that fall under the no crossfire umbrella?
  20. Guest-16
    Guest-16 Guest
    No that's fine - any "single PCB" (even dual slot) will fit.
Tags: Add Tags
