Really wish that the manufacturers would set a standard. Either way thiswont fit this will it? and if that is the case does that mean alphacool doesn't do a clamp for that size tubing?
Technical specifications: Material: PVC Tubing colour: clear Outer diameter: 13mm (1/2") Inner diameter: 10mm (3/8") Maximum operating pressure: 30psi (~2,07bar) Operating temperature range: -42.8°C to 73.9°C Technical specifications: Material: Brass Color: shiny copper Spring band inner diameter: 14-17mm Outer dimensions (L x H): 19-21 x 8mm
