New mod inspired by the film "Suicide Squad" The case for this mod is the Bitfenix Aurora with Tempered Glass Side Panels The sleeving will be done with the cables Alchemy2.0 individual individual wires The Specs are: Motherboard: Asrock 990FX EXTREME3 Graphics Card: soon Ram:16 Gb AVEXIR Blitz1.1 Series - DDR3 (4x4Gb) Power supply: Thermaltake Toughpower Grand 850W Fans: Bitfenix Spectre Xtreme LED Fans (Green) CPU: AMD FX-8320 Box Processore AM3+ SSD: Kingston HyperX SHSS37A/120G Savage SSD HDD: WD SCORPION BLACK 320 GB 2.5" and for the water cooling: MAGICOOL G2 Slim Radiator Phobya Balancer 250 Silver Nickel EK00041 EK-Supremacy EVO Alphacool VPP655 PWM Top Plexy another photo of the case Bitfenix Aurora and the fans that I will use and the spectre extreme led and the RAM: 16 Gb AVEXIR Blitz1.1 Series - DDR3 (4x4Gb)
Your first post must show work in progress, not just a heap of parts and some rough sketches. If you have no physical modding to show, wait until you do or start your log in the 'Modding' forum. In this case, once you do start physical work, request that the project be moved to the project log forum by contacting a mod or emailing modding@bit-tech.net. The general idea here is to maintain the high quality content we’re all used to.
First I describe the mod and components and then work in progress... my other threads does not go well? http://forums.bit-tech.net/search.php?searchid=30685570
The case BitFenix Aurora is designed to support up to two 280 mm radiators on the top and front and a radiator 120 mm at the rear and includes a bracket to mount the tank. I'll have the same slightly modify the chassis to put a radiator 360 on the front .... Let us mark the cut and with the new trusted friend for trimming and with a little patience, a dozen discs, a 15 minutes to cutting and I can mount the 360 mm radiator stuffed with 3 BitFenix specter led extreme!
before placing the hardware, I have dedicated myself to the sleeving, which is very simple result thanks to the Alchemy 2.0 individual sleeve cables and for the SATA and power cables use these
Taking a look at the slot for SSD Chroma connected to the RGB controller also interfaced with Asus motherboards occurs to me to use it to illuminate the CPU water block Later I will show the effects with RGB Led BitFenix Alchemy 2.0 Magnetic and with their controller The tank will be mounted in the top of the case ..
Now few customization inside of the case to Stay on theme. Some details inspired by the Joker and Harley Quinn gun
and continuously mounting the tubes in acrylic and a preview of the effect of the BitFenix Alchemy LED RGB 2.0 https://www.youtube.com/watch?v=2URyONPk_nk
I chose the video card that currently remain air-cooled Xfx RX 480 Core Edition 8GB In addition the two "actionfigures" who will occupy the case and some color for the exterior of homes
