News Samsung releases 840 Evo performance fix tool
Discussion in 'Article Discussion' started by Gareth Halfacree, 22 Oct 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    I ran this when I heard about the fix last week and my read benchmark (within Samsung's own utility) went up from 990 to ~4000
  3. Assassin8or
    Assassin8or Minimodder
    24 Apr 2009
    Bah, ntfs partitions only even for the dos bad boot tool.
  4. monkiboi
    monkiboi Minimodder
    5 Feb 2012
    so this is safe to run then?
  5. Nexxo
    23 Oct 2001
    Seems to be; Anandtech and others have tested it. Back up your data, as it has to rewrite them as part of the refreshing process (following the firmware update). You shouldn't lose any data and the process is said to be smooth (if taking a long time) but it's best to be sure.
  6. monkiboi
    monkiboi Minimodder
    5 Feb 2012
    Thanks
  7. ChaosDefinesOrder
    6 Feb 2008
    Can personally confirm this; both the long time it takes and the otherwise smoothness of the process!
  8. pbryanw
    pbryanw Minimodder
    22 Jul 2009
    +1 - Took about an hour and a half with my EVO 250GB and everything went smoothly.
  9. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Ditto, Evo 500gb took awhile but everything is fine.
  10. ChaosDefinesOrder
    6 Feb 2008
    Interestingly in my case, I first ran the performance benchmark pretty much as soon as I had installed and cloned to my EVO, so the low ~900 read result (multiple tests on multiple days) was with data written well within the supposed 30-day window and I still saw the massive increase in performance after running this tool...
  11. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    i thought the issue affected 840 basic's as well, ive just tried to use the tool with my 840 basic and it wont work. in your previous article it said that it DOES affect the 840 basic but not pro, does this leave us basic users not fixed?
  12. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    MY 35gb used space went really quickly... does seem faster though.
  13. acitodg
    acitodg What's a Dremel?
    21 Oct 2014
    Awesome, I have this drive in my gaming rig. I will have to try this utility and see how it helps.
  14. Locknload
    Locknload Jolly Good Egg
    28 Jun 2009
    I just got to be the first one to spot today's Garethism.
    In the article authors name header..
    Lol. Come on GH.
    The evo 840 bug fix is 100% fixed my poor performance.
  15. Gareth Halfacree
    4 Dec 2007
    Huh? If there's something to fix - and I'm sure there is - you'll have to be a little less oblique. The header with me name in it reads "Published on 22nd October 2014 by Gareth Halfacree" from here, which appears to be right t'me...
  16. Bungletron
    Bungletron Minimodder
    25 May 2010
    Just run the application on my lappy and my rig, both Windows 7, 500gb and 1tb respective, took about 2 hours and everything seems fine now (not that I had any issues before). I noted that after the first restart windows detected the drives as new hardware and put up a restart option which I ignored since the restore app was already running, I would suggest it is not a good idea to restart while the app is running as it does complete fine if you do not.
    The Magician disk manager did not suggest this update you must go looking for it on the support website, it requires a minimum 10% free disk space so I reckon do it sooner rather than later.
    Just the EVO models for the app, not the old 840, its a confusing quirk of the samsung naming choice but the 840 and 840 EVO are actually different drives and the app specifically says it is for EVO models only. Have no idea if the issue is present on the old 840s.
  17. Locknload
    28 Jun 2009
    Oh my bad GH, all this these years i always thought it was Mr Halfacre....My sincere apologies Man. lol
    Off to Specsavers.
  18. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    Yeah, seems non evo drives ARE affected but haven't been fixed yet. Just read this on another source
    "Samsung said its firmware upgrade addresses only the EVO line and not non-EVO 840 SSDs.
    Some users on technical blog sites, such as Overclock.net, said Samsung is ignoring the issue on the 840 (non-EVO) SSD. Others were concerned that the firmware fix covers up the bug by simply moving data around the SSD.
    That, said one user, means the drive "still is affected with the issue of slowing down when the system is off for weeks or out of the system for a weeks.."
    Sent from my GT-I9505 using Tapatalk
  19. Gareth Halfacree
    4 Dec 2007
    Hah! Well, that'd explain why I couldn't find the mistake, at least!
  20. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Halfacree...
    Half acree...
    Half a cree.
    Half a what?
    My brain has lead me here:
    So sorry.
