Hardware EVGA GeForce GTX 650 1GB review
Discussion in 'Article Discussion' started by brumgrunt, 4 Oct 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. blackworx
    blackworx Cable Wrangler
    31 Jan 2008
    How could you give only 60% to something so cute, you heartless old meanie!
  3. Combatus
    16 Feb 2009
    I have to admit it's one of the cutest things I've seen in our lab for a while!
  4. rollo
    rollo Modder
    16 May 2008
    that card looks tiny compared to some of the big cards out there.
  5. Paul2011
    Paul2011 Minimodder
    20 Jul 2010
    Wish cards like these didn't see the light of day, its no use at all to anyone thinking about gaming at or over 1080p. 60% is far too high a mark since most new games simply will be a slideshow, let alone the big titles of next year. Nvidia can do a lot better im sure, i just can't see the point of it.
  6. David
    7 Apr 2009
    It is cute, but largely pointless. Also, why does such a low power card need a dual slot cooler?
    The third graph on the Witcher 2 page needs the resolution changing - it's showing the same as graph 2.
  7. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Again, not everyone plays the last big title @ ultra setting. This card is small, easy on the power cord and do not heat a lot. For people willing to play games with less "high end" graphics, it's perfect.
    This the heat level is low, even under load, it could perfectly sit inside a very small case. It's enough to play some CS:S or TF2.
    I agree it's no use for BF3 or Crysis, but it's not the targeted market. I'm glad there's affordable little card for people willing to play a little. That appart, the HD7770 is one of the best bang for buck right now (but it is 15° hotter under load and consume 20 more watts).
    It's all about what you want to use ut for.
    EDIT:
    @BT staff: Again, why did you only test with BF3, Skyrim, Crysis @ ultra setting ? I know you're gonna say "It's part of our standard test procedure and it's been like that for years now". But nobody will be supprized that the frame rate is low and unplayable.
    Why didn't you try to show us the best compromise between perf and eye-candy ? Why no medium quality test ? Why no less-demanding games, like Street Fighter 4 for example ?
    Sorry to sound hard, but this review is useless and irrelevant to me. You should really focus the reviews depending on the targeted consumers. You do not review an high-end card the same way you review an entry level one.
  8. blacko
    blacko What's a Dremel?
    30 Jul 2012
    i want to take it home and give it a cuddle and tell it everything will be ok....
    Hopefully Nvidia will issue a TI version like the previous generation.
  9. Ripitup121
    Ripitup121 MMMMMMm watercooling....
    18 Aug 2010
    indie gaming rig material at best but DAM its MotherF**kin cute
  10. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    This would be perfect for a LAN rig, where really you can get away with not having Ultra settings and also it's abit better for the hosters electric.
    Could also be used in a Media pc that could be used for some light gaming as well.
  11. Shirty
    18 Apr 1982
    I think a Ti version priced half way between this and the 660 with performance to match will be a very desirable little card.
    Off topic slightly but what would be a good card for my mum's PC? She games fairly lightly at 1280 x 1024 using a 5450, but it does struggle with games like the Sims 3 :rolleyes: with the detail turned up. I assume the 650 would be overkill, but what would be a good compromise? I know nothing of low end cards.
  12. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
    Can't see the point? Why now you can run aero desktop in all it's wondrous glory!
    Some of the test results are odd, at idle the AMD Radeon HD 7870 runs at 6 degrees C and the GTX 650 runs at 14 degrees C but under load the GTX 650 runs at 29 degrees C and the HD 7870 runs at 40 degrees C, so either the GTX 650 cooling at idle is poor or the cooling under load is excellent, I guess it's better to have better cooling under load.
    It overclocked well but who's going to bother? It looks like the type of card some PC manufacturers would use and then call their PC an "Entry level gaming machine" It'll run Myst and Broken Sword games at max levels :rolleyes:
    Why did Nvidia bother releasing this when the HD 7770 which is a faster card all around for the same price is already on the market :confused:
    Graphics cards..can't live em, can't live without em :wallbash:
    Oh, and I'm not AMD biased, I've just bought a MSI N560GTX-Ti Twin Frozr ll :clap:
  13. Zurechial
    Zurechial Elitist
    21 Mar 2007
    The impression I'm getting is that this card (and cards like it) are a false economy for the average consumer in this day and age.
    Now that both AMD and Intel CPUs have built-in GPUs that can handle light gaming workloads (very light in the Intel case); why would anyone bother with a card like this?
    If crappy, low-resolution graphics in modern games or middling settings in older games are all you want; then an on-die GPU from AMD or Intel makes more sense and would work out cheaper in a new build, too.
    If you want anything approaching decent performance and visuals, buy a discrete gpu that doesn't suck.
    Or have I missed something here, some market segment that these cards are actually still useful for at this point?
    Surely the "my CPU is too old to have a decent GPU on-die and I can't afford to wait or spend more on upgrading for decent visuals so I'll drop 100 on a crappy, low-end graphics card" segment can't be that large?
  14. GuilleAcoustic
    26 Nov 2010
    The Zero Core technology from the HD7000 series is why the HD7870 runs cooler than the GTX650 at idle.
    For cases with length limited to 180mm for additional card (like many ITX case), this card is nice. Trinity IGP is nice, but still offer half the performance of an HD7750. Intel IGP can't event handle half decent fps with detailed Skecthup models. Both HD7750 and GTX650 are nice for small footprint rigs.
  15. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Did you not read the article?
    I think this cute and wubbly ickle card has done its mummy proud by being able to stand up and play tough like the big boys do.
    Sure it's not going to give you massive amounts of AA at 1080 or a high minimum FPS but it'll still play BF3 / Skyrim if you crank the settings down.
    27FPS in skyrim at 1080p in ultra mode isn't bad on a little pre-school card like this.
    Isn't this 650 a 'slightly' better spec than the 650M and even a bit better spec than the tweaked 650M apple use in the retina macbook? I play games quite happily on my rMBP and while I can't game at 2880x1800 or 2560x1440 will all the eye candy on, it's fine if you crank the res / settings down a little.
  16. Paradigm Shifter
    10 May 2006
    I agree with GuilleAcoustic, for the most part. I know you have a 'standard' benchmark suite, but all that review really showed is that a GTX650, the 'entry level' 600 series card, is useless at playing demanding games at demanding settings. What a shocker. :eyebrow:
    On the card itself, however... I'd be more interested in a single-slot GTX650, or possibly a dual-slot passive design if the TDP was low enough. It would also be interesting to see how useful it is at CUDA work, or as a pure PhysX processor if there was a single-slot version available.
  17. Hustler
    Hustler Minimodder
    8 Aug 2005
    There bringing out a 650Ti as well next week, apparently, with 768 Cuda cores and about 10% more bandwidth.
    Crazy...just too many cards these days.
  18. blackworx
    31 Jan 2008
    I'd go for Sapphire's passively cooled 7750 for that. Costs more but 100% silent and great temps.
    EDIT: And powered directly from the slot with no 6-pin power supply required.
  19. Adnoctum
    Adnoctum Kill_All_Humans
    27 Apr 2008
    I've been wanting to upgrade my mITX legacy gaming machine from the current 9800GT to something from this generation and have been waiting for this so I could make an informed choice. And waiting. Then some more waiting.
    I wish I hadn't because, for me, this is all kinds of fail:
    * It has a external PCIe power connector - with the kinds of low power draw I was expecting, this shouldn't have been an issue. The competition in the HD7750 doesn't need it.
    * Currently there is no passive option available - Once again, there is a passive HD7750 from Sapphire.
    * It is too expensive - the TWIMTBP program tax strikes again. For the third time, the passive Sapphire HD7750 Ultimate is either the same price (as a Galaxy GTX650) or cheaper (than Asus, Gigabyte, etc).
    The only thing that is stopping me pulling the trigger on the Sapphire is the thought that perhaps the HD87xx is just around the corner (within 4 months or so).
  20. mrbungle
    20 Sep 2004
    Would be far more use to test the card at lower settings to see if it could get a playable rate out of say BF3.
    Most cards would struggle with ultra settings.
Tags: Add Tags
