Finaly some decent PPD :)
Discussion in 'bit-tech Folding Team' started by Votick, 22 Jun 2009.
  1. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
  2. IwantAbetterPC
    IwantAbetterPC What's a Dremel?
    27 Apr 2009
    Hi mate,
    Sorry to be a pooper, but your SMP client looks like it's going to miss the deadline - I'm not sure if you get no points or reduced points for not hitting the deadlines? Anybody else advise?
    Craig...
  3. Vince_Kinslow
    Vince_Kinslow Folding Millionaire
    25 Apr 2009
    Yep I think your right IwantAbetterPC I would suggest the normal client if its not getting them done on time
  4. saspro
    saspro IT monkey
    23 Apr 2009
    SMP really needs the PC to be on 24/7 to be effective.
    You're going to miss that deadline methinks
  5. IwantAbetterPC
    27 Apr 2009
    Votick - were you using Notfred/VMWare or Windows SMP client? If Notfred, then it appears to have the same "preferred" and "final" deadline times (which seems harsh!). Windows SMP clients usually have an extra day until the "final" deadlines - see my webpage for examples of two Windows SMP clients - maybe this would get you in before the deadline and so you'll still get points. From what I can gather on the forums, if you miss the preferred, but beat the final, you get points. If you miss both, you get zip.:eeek:
    Craig...
  6. IwantAbetterPC
    27 Apr 2009
    Just noticed that mine will come in at about the same time as the CPChimps are due to finish - Saspro - if I change the config now to set the username back to IwantAbetterPC, will these WUs go to the Chimps or not? I don't want to start two new SMP WUs on 24th for the Chimps if I don't need to :) - sliding down the ranking table! I'll leave the two GPUs chimping until Wednesday night (unless we finish earlier!)
  7. saspro
    saspro IT monkey
    23 Apr 2009
    If you change username part way through a WU it doesn't change until you start a new one.
    You should be fine.
  8. Votick
    21 May 2009
    hmm yeah its tought keeping up :(
    think i mite switch back to the normal client.
    Was good to test it out though and learn a bit more :)
  9. Votick
    21 May 2009
    its a dual core.
    so could i run 2 single cores?
  10. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Correct - when the preferred deadline passes, that work unit is flagged up to be allocated to another machine. If you finish after the preferred deadline but before the final deadline, you still get the points, but the work will be duplicated. The Pande group request that if you are experimenting with SMP, you should monitor your speeds, and go back to classic clients if you frequently miss deadlines. Duplicated work is considered wasteful, rather than useful.
    I have 'old' AMD Athlon X2 CPUs which miss most deadlines running Windows SMP, even when running 24 hours a day. So I run two instances of the normal client, which mostly finish within a few days. It all helps.
  11. Votick
    21 May 2009
    how to do you set up 2 normal clients?
  12. Christopher N. Lew
    23 Apr 2009
    Basically it's the same as setting up two GPU clients. You'll need two folders in 'Application Data' (Windows XP) and appropriate short cuts. Do you need more detailed instructions? I can email you copies of the files and shortcuts that I use if it would help - PM me.
  13. Votick
    21 May 2009
    cool PM'd you :)
  14. Votick
    21 May 2009
    I think I have done it.
    I downloaded the CPU Console Client.
    Dropped one in each CPU folder.
    Made a shortcut to desktop with the -local flag attached.
    Set up each CPU.
    Downloaded Prifinitty.
    Set CPU1 to Core 0 & the folding core.
    Set CPU2 to Core 1 & the folding core.
    Will Prifinitty remember which core to put what program on?
  15. Votick
    21 May 2009
    Hope that looks right :)
  16. docodine
    docodine killed a guy once
    10 Feb 2007
    How are you getting the client to display info like that?
  17. Votick
    21 May 2009
    its the console client.
  18. Votick
    21 May 2009
    CPU1 seems to keep "hung" 'ing.
    But CPU2 seems ok.
    Any advice?
  19. Votick
    21 May 2009
    hmm seems ok now
    found out a f@h service was running so killed that.
    One stat viewer says its "hung" but as soon as it went up to 4% its back online again.
    Could just be it's slow
    700+ pointer as well :(
  20. Unicorn
    25 Jul 2006
    768 pointers aren't nearly as bad as the 611 ones. Really though, it's all about getting the work done ;)
