News MSI announces Cubi 2 Plus 5x5 mini-PC range
Discussion in 'Article Discussion' started by Gareth Halfacree, 25 Feb 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. GiantKiwi
    GiantKiwi What's a Dremel?
    6 Jan 2011
    Is that supposed to be "supports up to 32GB of DDR4" ? ;)
  3. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    It is indeed DDR4 :)
  4. TheMadDutchDude
    23 Aug 2013
    That thing is AWESOME! I want one have a play with! I'll be contacting someone in the morning... :D
  5. GiantKiwi
    6 Jan 2011
    It was listed as 32B of DDR4 when I posted that original comment :p
  6. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    If someone was to release one of these babies with a discrete graphics card in it (GTX970 mini), I would bite their hand off.
  7. Gareth Halfacree
    4 Dec 2007
    I can confirm: I sneakily fixed it in the middle of writing a piece elsewhere and didn't 'fess up in the thread. Naughty!
  8. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    These mini PC makers miss a trick on these with the cooling. The Gigabyte Brix with the 760 in it would have been epic if it was about 50% bigger and used to the space for a super beefy heat sink and a single 120mm fan to push air through it.
    It still would have been tiny, but would have been cool and relatively quiet, instead of hot and noisy. I get the impression this would be the same outcome if MSI brought them out.
