Me and my friend started to plan on an as bit portable server as possible. We had to make it big cuz there had to be enough space for 4 computers. The "Victim" the powersuplys Erik drilling the rails the arrangement of the motherboards the first mobo on place two mobos on place Another Update will come up shortly If you have any comment or idéas sp please share them
You might want to edit your image tags to show the .jpg portion at the end of the link, for ease of viewing. Here's what you've got:
You might want to try using Imageshack or Tinypic. That way there's a larger limit to what you can host. Here's the url's: www.imageshack.us http://tinypic.com
NEW UPDATE! 3 motherboard on place me soldering the powersuplys the powersuplys the last motherboard is beeing mounted All motherboards and powersuplys are now mounted view on the front with all 4 cards And a small systemcheck.. It all worked perfectly
