Other VPN - Best free service?
Discussion in 'Software' started by Impatience, 27 Jun 2014.
  1. Impatience
    Impatience Minimodder
    6 Apr 2014
    As the title says, what would you recommend as a good VPN to use? Preferably something that doesn't have a download cap..
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I used free ones for a while and I found them to be pretty rubbish, intrusive adds, or really rubbishy apps to connect the vpn - and they normally have rubbish speed. I use private internet access now https://www.privateinternetaccess.com/ which doesn't cost very much, and lets me just dial a pptp vpn, and I can saturate the vpn with whatever my line speed is.
    hotspotshield and spotflux are some free ones I've used in the past with mixed success.
  3. Impatience
    6 Apr 2014
    Just noticed that I'm not auto-subscribed to my own threads.. :duh: Cheers for the pointers! I'll have a look at them.
  4. Margo Baggins
    28 May 2010
    I really disagree with having to use an app to dial a vpn - which is why I chose privateinternetaccess, I don't understand why there is a need for a third party app when all os's have the ability to dial a vpn built in.
  5. Justify
    Justify What's a Dremel?
    24 Jul 2014
    try this one: http://expatshield.com/ its an application that lets you toggle your vpn on/off and tells you when you are connected.
