Scratch Build – In Progress Project Arctic, [The making of my first scratch-build] World record?! DONE!
Discussion in 'Project Logs' started by iSw3de, 28 Oct 2014.
  1. iSw3de
    iSw3de What's a Dremel?
    21 Dec 2012
    Introduction, Concept and Goals of the project.
    Hello! I am Lucas, a 17 year old guy from Sweden. Some of you might have seen my latest finished project Slenderbox (http://forums.bit-tech.net/showpost.php?p=3608127&postcount=37)
    You can read more at my website (http://www.auxiliumdesign.com/)
    This time, I step up my game, and will make a scratchbuild! :D
    But what is so special with this one? Well, probably that it will be the smallest of it's kind.
    Housing two watercooled full length GPUs, and a watercooled CPU on a mATX motherboard.
    In less than 19 Liter!
    The concept
    I have done a couple of projects, one mid-sized and one really big (Read SMH10). So I decided that before I take a break from modding, it would be nice with something small, but still powerful.
    I want something quiet, and portable to take with me to different places. As my parents are divorced I move everything in my room between the houses 6 times per year, something small would be better.
    TL;DR Small, Quiet, Powerful, Portable
    This was my first prototype, altough it is pretty big, 23 Liters, and ATX PSU.....
    I just had to go smaller, this is the final design, 19 liter only!
    Designing the case
    This is more in depth behind the scenes, for those who are interested!
    As my experience with Creo (former Pro.Engineer, CAD program) and knowledge about materials grew, I decided I wanted to design and make my own 100% aluminum case.
    First I wanted it to be below 20 Liters, but when I fell in love with XSPCs white radiators, I had to make it 22 Liters.
    I started of with some basic forms and tried to find out solutions to make it possible to bend and cut out the case.
    Steps of modeling the front of the case
    I wanted double 240 rads (40mm) to be able to cool SLI+CPU. On the front, only the vandal-switch and the fangrill will be visible. On the base there is space for double SSDs
    The rear side of the case will have 4 PCI-e slots, a nice PSU cutout and holes for PSU air.
    For those who wonder how something looks before it is bent, this is how it looks. It is about 1 meter long :)
    Contributers:
    Specifications
    Weight: >2kg
    Volume (ID): 18,3 Liter
    SLI/CF
    2x240 Radiators
    Full length GPUs (270mm)
    Hardware
    As you can see im still in the planning state, all green are bought, all yellow are decided, all red are unknown yet.
    Case: Arctic, Special edition!
    Motherboard: MSI Gaming G5 m-atx
    CPU: Intel Core i7 4790K
    GPU: 970 SLI Gigabyte Gaming G1
    PSU: Silverstone 600W SFX
    Harddrives: Two HyperX 240GB SSDs
    Fans: White E-loops
    Memory: HyperX Fury white 1866MHz 4x4
    Watercooling
    Radiators: XSPC AX240 Dual Fan Radiator - White
    Pump: Laing DDC-1T Plus
    Reservoir: Watercool DDC-Tank LT
    Coolant: Mayhems Pastel blue
    Timelplan
    Case designed 04/10-14
    Watercooling ordered 07/10-14
    Hardware Partily ordered 08/10-14
    Case produced - 22/10-14
    Case powdercoated 06/11-14
    All hardware ready 07/11-14
    Mounting 14/11-14
    Final touches 17/11-14
    Studio rigged, photo and video 18/11-14
    Showcase at Dreamhack!
  2. iSw3de
    21 Dec 2012
    Scratch Build Project Arctic, [The making of my first scratch-build] World record?
    Here is the pump! But what is that, I think it is a sticker :grr:
    Fixed it, and mounted the Reservoir, it got some machine marks, but it looks like frost to me  :hehe:
    Did a fast mockup to see if I am pleased with the dimensions e.t.c (This is with ATX PSU tho)
    Also the feet for my case came by mail today! 100% aluminium of course!
    ________________________________________________________________________________________
    Now, do you remember me telling you that Arctic is not only the computer but my whole interior?
    Well, let's do some transformation!
    This is what I had, it looks alright, but does not match the power of Arctic  ;)
    Let's put on a better monitorstand, let's give the monitorstand some wings!
    This is what you get!
    That was everything for today! Oh, almost forgot, the cliffhanger!
    Who can figure out what this means? You'll get a cookie ;)
  3. chilliewillie
    chilliewillie What's a Dremel?
    14 Apr 2014
    with what do you model?
  4. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    AutoCAD? New mod inc?
  5. iSw3de
    21 Dec 2012
    I model in Creo (Former ProEngineer), for the renderings, I use Google Sketchup
    Creo :clap: But I can model in autocad too tho :D
  6. Yukionno
    Yukionno What's a Dremel?
    9 Mar 2010
    Cutting templates for the alu to be cut & bent to?
  7. iSw3de
    21 Dec 2012
    Thanks right! Ready for some lazer and bending :clap:
  8. iSw3de
    21 Dec 2012
    After cutting this out,
    (The plastic seems to have screamed for help during the laserpenatration :waah:
    in this awesome lasercanon
    My father and I inspected the drawings to make sure the bending was done properly.
    We though this bad boy would make a great job. :hehe:
    First bends are coming out nicely
    At this time I was shivering because I just wished everything would fit right, as this is the first time I design my own case, and the first time I have made everything myself :eh:
    But wait, what might this be? :confused:
    You might be able to guess with this picture
    Any guesses? ;)
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    Compact power system, nice. :)
  10. Cheapskate
    13 May 2007
    Pretty sweet. You should do a few extra. I'm sure someone will want them.
  11. iSw3de
    21 Dec 2012
    This is something extra for my "Project Arctic room"
    I also designed a headsetstand as you might have seen on my homepage
    I assembled the case fast when I got home, with all hardware I got at the moment, not so much to look at right now, but it will be ;)
    With insperation from the Compact Splash case (which I got a lot of insperation from)
    This technique for SSD mounting is to be able to change the drives without draining the loop and take away the GPU.
    Finally a picture with the Project name on the rear side :D
    Everything for me for this time, what do you think? :D
    As this is Family-Only at the moment, you are my only input for criticism :rofl:
  12. iSw3de
    21 Dec 2012
    The watercooling
    This time I will try to post some more pictures, as some people tells me I post pretty few haha
    Some of you figured out what todays update will be about!
    I need two tho ;)
    But what is a radiator without any fittings to pair them together with?
    This time I kept using some trusty Bitspower but tried Monsoon which I am new to :)
    Really nice tools came with it, one to tighten the inner.
    and the other one to tighten around the tube!
    I really love the match with the radiator and fittings!
    Next update will be sometimes next week, by then I will mount the hardware, such as watercooling and probably motherboard and more! :panic:
  13. Ygd3n
    Ygd3n What's a Dremel?
    21 Jan 2012
    looks good lucas :D
  14. Cheapskate
    13 May 2007
    Looking good.:D
  15. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Go on Lucas, show us more!
  16. iSw3de
    21 Dec 2012
    Indeed, thanks!
    Thanks Cheapskate!
    THanks!
    More you say? More it is!
  17. iSw3de
    21 Dec 2012
    Putting it all together
    After getting the motherboard I just had to put it all together, first I had to sleep tho, and I promise you it was hard....
    But something is missing?!! :eek:
    Don't worry guys, I took it off to be able to demount the "claws". You will see what will be done with this later!
    Warranty.... What a joke :rofl:
    Meanwhile I took apart the PSU, for the same reason as for the North bridge.
    There was a design-flaw which I found out. The PCI-e cutouts is about 3-4mm to high, therefore the GPU wont be able to fit in the motherboard.
    The motherboard is also 1 mm off, therefore the I/O plate wont be able to be there in this version. Will be fixed for 2.0!
    The front with the vandal switch!
    This is the side you wont look at much hopefully haha
    How to corners look more close up!
    This is probably the picture you have all been waiting for. Everything is mounted! (Except watercooling and one fan)
  18. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Damn, the order of installation will be key in this little thing! Nice work!
  19. FAT
    FAT What's a Dremel?
    19 Mar 2013
    wow, looks impressive! Love the white and blue colour scheme!
  20. storm-83
    storm-83 Minimodder
    7 Nov 2014
    looks really cool!
    love the colorscheme
    *edit*
    subbed!
