Modding changing psu's fan with an aftermaket
Discussion in 'Modding' started by Soul_analyzer, 11 Sep 2014.
  1. Soul_analyzer
    Soul_analyzer What's a Dremel?
    26 Sep 2012
    Hello everyone, currently I am doing a case modding and I want to change my Psu's (Thermaltake toughpower 1000w) original fan [​IMG] with a bitfenix fan [​IMG]. Is this possible or will I have issues? I see the A=amber? Difference 0.70 A on the original psu's and 0.18 +_ 10 % on the bitfenix.
  2. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    A = amps = current draw at the rated voltage.
    If they're the same physical size, and have the same standard connectors, it might be worth a try. Can't tell you if it's safe or not.
  3. TheMadDutchDude
    23 Aug 2013
    Should be fine. The fan will only draw what it needs as far as I know.
  4. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Yep is no problem and should work just fine :)
  5. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    There are some concerns when replacing PSU fans. PSU fans are usually selected because they have very low starting voltages, like 3V or so. Many fans will only spin up around 5-7V, but I couldn't find any info about that replacement fan. Another issue I can see with that BitFenix is that it is only capable of roughly half the CFM of the original Yate Loon. Since most people rarely even use 50% of their PSU's capacity I'm not that concerned, but it is something to keep in mind since if you do actually ask it to supply 800W+ it may overheat and shut down depending on ambient temps.
  6. MarkVarley
    MarkVarley Minimodder
    12 Sep 2014
    I've done this a few times, never with that fan or that psu.
    Sometimes the fan is hard-wired so you may need to do some soldering.
    As shinji2k said you should pick a fan with similar or better airflow (a higher quality fan will probably achieve this quieter) and psu's that vary fan speeds should have a fan with a lie starting voltage, though you could argue that it will still start before any overheating occurs it's best practice to upgrade the fan and it's starting voltage is one facet to consider.
  7. Soul_analyzer
    26 Sep 2012
    I did bought a new fan and I think it's quite good. The http://www.nzxt.com/product/detail/92-fx-140lb-case-fan.html. But there some isues.
    The new NZXT fan has a 3 pin connector and the PSU has a 2 pin socket for the fan, so I need to cut the old fans cable and attach it to the new one. But I need to know how the wires are going to be attached, and there is no way opening the new fan, so I cant see where goes each wire. I am guessing it must be one + one - and one groung so if I attach only the + and - I'll be ok if I knew which is which. Another issue is the new NZXT fan has a speed switch (L-M-H) . I dont know cause i cant see if the speed swithes cables are attached to one of the wires I need to cut. Another method is to make a hole with my dremel to the side of the PSU and attach
    the 3 pin fan to a 3 pin socket but this way the 2pin socket of the PSU will be empty, will this cause a problem?
    Does anyone know how to open the fan so I can see the wiring inside it?
  8. MarkVarley
    12 Sep 2014
    Your old fan will have +12v and -0v, same on your new fan plus signal, colours are usually Red Black, Yellow. If they are all the same colour on your new fan you can tell by the pins, Google will provide you with a wiring diagram (I'm on my phone so can't quickly look one up).
    If your psu fan is temp controlled you can set your new fan to H, if not I'd try M but H is the safer bet.
    It should cause no problem to run your fan from outside the psu, I've done that before, it MAY reuse to play if it thinks it's fan is broken but unlikely.
  9. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Things like this have been standardized for many years. Match red to red and black to black and ignore the yellow rpm wire.
  10. phuzz
    phuzz This is a title
    28 May 2004
    If the fan cable doesn't have colours, you can tell by looking at the fan connector:
    On your PSU the red wire will be +12V and the black will be GND.
  11. phuzz
    28 May 2004
    *edit doublepost
