Other Benching: Geekbench Revisited!
Discussion in 'Hardware' started by LennyRhys, 30 Dec 2015.
  1. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Amazingly it's been 4 years since the original :clap: epic Geekbench thread :clap: and I think it'd be great to do the same thing again to get an idea of how hardware has changed in that time and also to have a bit of lighthearted fun competing with each other. :) If it really takes off then I can put a scoreboard together like Pookeyhead did the last time (and believe it or not, they're still up!).
    Geekbench 3.3.2 is free to download and you can run it in 32-bit without a licence.
    All you have to do is run the benchmark (it takes minutes, or less) and post the link to your score, preferably using URL tags so that your score is instantly readable. Please also post the main components in your system (CPU, Mobo & RAM) with some info on frequencies.
    It's up to you how hard you want to push your rig. If you want you can do a "daily settings" run and also a "suicide" run. :D
    To kick things off, here's my score. As of two weeks ago, these are my daily settings:
    Xeon X5650 @ 4.3GHz
    Gigabyte X58-USB3
    6GB Dominator GT @ 1560 9-9-9-24
    17622
  2. Guest-16
    Guest-16 Guest
    Multi score only?
    25421
    5960X @ Stock 3/3.5G
    R5E
    16GB Kingston 2133 @ CL15 (whatever SPD is)
    Mostly just run stock due to daily stability/laziness and the fact I've finally got a totally silent PC \o/
  3. Gareth Halfacree
    4 Dec 2007
    5561
    AMD A10-5800K at 3.8GHz, Gigabyte something-or-other motherboard, 16GB of RAM. I didn't close anything for the run, so I could likely claw a few points back - especially if I shut down BOINC - but let's face it, it's hardly worth it. Shame I can't afford an upgrade, really!
    EDIT:
    Ran it on the MicroServer, for giggles. 1735.
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    HT Enabled
    9383
    HT Disabled
    7771
    i7-920 @ 3.29 GHz
    EX58-UD4
    6GB RAM
    Was surprised Geekbench was so easy to run and relatively small download, some benchmarks can be a right PITA.
  5. sonicgroove
    sonicgroove Radical Atheist
    16 Mar 2011
    11623
    i5 2500k@stock
    16gb ram
    win10
  6. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Ooh good point - if I collate scores I'll also put single core performance in a different column, but no need to post here as it's easy to access via linky. :thumb:
    @Corky42, your score is very low for X58 because you've disabled HT. Any reason you don't run HT?
  7. Concrete-Coffin
    Concrete-Coffin Minimodder
    5 Apr 2010
    11301
    4.2 overclock in offset mode so its not running full pelt all the time didnt turn any programs off either
    also how do i get it to show like everyone else have no idea?
  8. Corky42
    30 Oct 2012
    No concrete reason, when i OC'ed it i read that HT can sometimes hold things back, since then I've never really switched it back on, maybe i should I'm just not sure my everyday use would benefit from HT. :confused:
    EDIT: re-run it with HT enabled and updated original post.
  9. Gareth Halfacree
    4 Dec 2007
    You need to write it like this:
    [noparse]result[/noparse]
    Where "url-of-result.example.net" is, obviously, the result URL, and "result" is the multi-core result copy-and-pasted (or memorised and typed) from said page. I've done it for you, 'cos I'm helpful like that.
  10. Vault-Tec
    30 Aug 2015
  11. Deders
    Deders Modder
    14 Nov 2010
    Not so much a suicide run but not completely stable.
    20322
    6700K @4.781GHz
    16GB DDR4@3200
    This would be what I run it at daily... (4.6GHz stable, waiting for bios to mature before I push it more.)
    19983
    For comparison this is my phone...
    3425
    These are all x64
    Edit: 32Bit @4600MHz for reference
    18658
    Vault Tec, is your ram running in quad?
    Edit: my previous i5-750@3800 with 1800MHz DDR3.
    8164
  12. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    This is run on my 24/7 settings (with the base clock at 125).
    The CPU (5960X) is actually running at 4.5ghz @ 1.31v
    16gig DDR4 @ 3000mhz
    32198
    When I get time, I will go for a suicide run
  13. Vault-Tec
    30 Aug 2015
    It is yes :) 4x4gb 2133mhz
  14. Chris_Waddle
    26 Mar 2009
    A slight overclock (with the base clock at 125).
    The CPU (5960X) is actually running at 4.625ghz @ 1.35v
    33201
  15. andreinuk
    andreinuk Minimodder
    20 May 2009
  16. Andre_B
    Andre_B Minimodder
    17 May 2009
    3064
    ThinkPad 8
    Atom Z3770 @ 1.47GHz
  17. Ljs
    Ljs Modder
    4 Sep 2009
  18. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Ran it on my Media/Lan Gaming pc just for laughs, doesn't do to bad though really.
    9547
  19. Kernel
    Kernel Likes cheese
    29 Sep 2003
    14757
    Totally stock at the minute, which is 3.7Ghz
  20. rollo
    rollo Modder
    16 May 2008
    Didn't true gamer break 30k 3 years back on his system in x64 if I remember correctly. 3 years later wonder if we will see 40k+ scores.
