Hardware Asus Ares Review
Discussion in 'Article Discussion' started by Lizard, 27 Jul 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. memeroot
    memeroot aged and experianced
    31 Oct 2009
  3. uz1_l0v3r
    uz1_l0v3r What's a Dremel?
    22 Sep 2009
    I can think of many things that are a better place to put my cash than three graphics cards.
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    Show us Toxic or Ares in crossfire please.
  5. memeroot
    31 Oct 2009
    if nvidia or partners could get a 2 chip soluton out they'd walk this gen... well from 6 months behind....
    looking at s-islands can ati compete come christmas?
  6. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Usually im all up for ASUS crazy cards but im struggling to see the point in this tbh. Its just a stock card on steroids, at least the Mars was something new, and the dual 480 card they have floating around is an engineering feat.
    But this is just totally pointless, it would get destroyed by much cheaper dual card systems and isnt imo unique enough to justify the quite frankly rediculous pricetag.
  7. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    An addition of eyefinity results would be nice.
    Are BIT going to be doing an article comparing Surround to Eyefinity? I know the likes of HardOCP hae done this but TBH I would prefer results from more than one source.
  8. rollo
    rollo Modder
    16 May 2008
    Nobody really cares what you could buy instead
    Any person who has £1200 for 1 card isnt looking at what he can get elsewhere, he would probably buy 2 and crossfire them
  9. motas
    motas What's a Dremel?
    7 Dec 2009
    Im confused is this dual 5890 or dual 5870? I read dual 5890 chips but that would mean quad xfire in one card?
  10. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I think there may be a couple of mistakes in this article lol
    I think the spec of the Ares should read as " Graphics processor : 2 x 5870" not "2x5970".
    And the analysis page should read " was that the Toxic was quicker at resolutions of 1,680 x 1,050 and 1,920 x 1,200" not " was that the Toxic was quicker at resolutions of 1,080 x 1,050 and 1,920 x 1,200"
  11. maximus09
    maximus09 Forever n00b
    8 Jun 2009
    I would like to see a comparison with 2xGTX460s as well, Tom's Hardware tests put this battering down the GTX480. wonder if they would beat the Ares and be £700 cheaper.
    Oh and there is a mistake in this article: "which was akin to the noise likely to be produced should anyone ever try to force a hair dryer and a vacuum cleaner to mate."! This line is far too humourus for a serious review LOL
  12. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    What's the point of this card exactly? You could just take a stock 5970 and overclock its nuts off (possibly adding a waterblock to help). The chips used in the 5970 are specially binned anyway, so they're effectively guaranteed to overclock well.
    Oh, and it'd still work out £600 cheaper. Can put that money towards an i7-980X..
  13. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    Fixed. Thanks.
    We list the graphics processor specs as 2 x 5970's because while the card uses two 5870 GPU's, they don't run at 5870 speeds, so listing the card as having two 5870's could be misleading.
    This was the approach Harry took in his Sapphire Toxic review so I stuck with it for consistency and to allow the specs lists of the two cards to be easily compared.
  14. -VK-
    -VK- Lurker
    11 Oct 2007
    The point of the card? "Because we can".
    Really, nobody makes a card like this as a "sensible value for money" option :p
  15. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    Without trying to sound rude, this is completely misleading.
    Firstly, the whole point of the Ares is that it IS 2 x 5870's. That's what seperates it from the 5970's. The standard 5970's use two downclocked 5870 GPUs whereas the Ares runs them at full 5870 speed.
    I could see why you labeled them as such for the Sapphire 5970 Toxic, but I think it would be better to label tham as 2 x downclocked 5870 GPUs, not 2 x 5970 for the Toxic. This is because there isn't really a 5970 GPU, the 5970 IS 2 x 5870 GPUs so by labelling it as 2 x 5970 it confuses people to think they are quad-GPUs.
    I really suggest you change it as I was very confused by it till I looked up the specs on multiple other reviews.
  16. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    I'm surprised something like this doesn't come with a waterblock as standard or a closed liquid loop and fan such a modified Corsair H50. If you have the cash to blow on this you'd not miss an extra couple of hundred to silence it!
  17. javaman
    javaman May irritate Eyes
    10 May 2009
    At the price wouldn't the user who can afford these most likely be using water cooling and wouldn't an HD5970 with a waterblock fitted not be cheaper and out perform the Ares? Wonder if any extra can be squeezed out by removing the air cooler and adding a waterblock.
  18. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    It's way out of my league price wise but it's good for drooling over.
  19. Andersen1337
    Andersen1337 What's a Dremel?
    10 Apr 2009
    Shouldn't the specs says 2x 5870?
  20. Material
    13 Apr 2010
Tags: Add Tags
