just built a new rig today I5 with a asus GTX 570 CuII got the i5 running the SMP client and the 570 the gpu client but for the life of me i cant find the FAHlog.txt for the GPU client to add to FAHmon any ideas guys?
Given that you set them both up correctly, there should be two separate folders with the .exe and the work folder, it will be in there. If you don't have those folders then I can only assume you haven't set the clients up correctly. My guess is that you didn't give the two clients different machine numbers in the .config or they are operating in the same folder, which is bad. Without any other information we can't help you.
If you're using the systray client, the log files will be in one of the following locations: In XP: C:\Documents and Settings\<your_windows_username>\Application Data\Folding@home-gpu\ In Vista/7: C:\Users\<your_windows_username>\AppData\Roaming\Folding@home-gpu\
found it win search didnt seem to show it untill it had finished its first WU GPU seems to be doing about 15k ppd for a 570 GTX oc to 852mhz and standard memory profile (if i remember right memory speeds dont make much diffrence to the total ppd) and cpu on smt @4.1ghz is giving bizzare results atm but this could be down to the diffrent projects im getting some times its around 14kppd then droping to 3k ppd still much better than the 4k ppd i was getting on my old machine
