Case Mod - In Progress MetallicAcid's Monolith FT03
Discussion in 'Project Logs' started by MetallicAcid, 24 May 2014.
  1. MetallicAcid
    MetallicAcid What's a Dremel?
    20 Feb 2014
    Hello guys and girls of modding and welcome to my project build log!
    The introduction
    I am about to kick off another project that I have been designing for roughly 2 months now. I have this perfect opportunity to work on this project whilst I wait for PC components to come in for my ongoing black and gold Silverstone TJ07 project. The TJ07 project has been put on hold for 2 months, so the end of July is my deadline to finish this Silverstone FT03 project. This will be my fourth project since May 2013.
    The project
    This project is primarily a simple upgrade for my personal gaming rig, to turn it more into a design capable PC with boosted CPU power and looks to kill. This PC will have an upgraded CPU coming from an i5 2500k to an i7 4770k. I will also have a fully upgraded watercooling loop which will also include the GPU this time. The radiator will be no less than an 85mm thick MONSTA Phobya 400x200mm radiator sitting on the back of the FT03 case like a backpack of sorts. lastly, this project will feature aluminium "armour" panels to give it a unique look and make the external rad tie into the overall design.
    The hardware
    Silverstone Fortress FT03
    Intel Core i7 4770K @4.8ghz 1.4v
    ASUS Gryphon mATX Z87 + Armor Kit
    Corsair Vengeance Pro 4x4GB @ 2133mhz
    Silverstone Strider ST85F-P 850W PSU
    ASUS GTX780 3GB SLI
    Phobya Xtreme 400x200x85mm radiator
    Phobya G-Silent 818 180mm fan x2
    Be Quiet! SilentWings 2, 80mm PWM x2
    Swiftech Apogee Drive II CPU/pump combo
    EK-RES X3 110 reservior
    EK-FC780 GTX Ti - Acetal+Nickel x2
    EK-FC780 GTX Ti Backplate - Black x2
    Icemodz RGB LED strips
    The Renders
    The conclusion
    So to round things up, this project is going to be (hopefully) short and sweet. The custom aluminium panels I will have CNC milled as I have learnt a CAD program and created all the necessary files. All of the hardware I already own and am currently running as of writing this first post. And lastly I have had a great time designing this project first in SketchUp and learning a professional CAD software (Autodesk Inventor). I can safely say that modding is my passion, and I really hope to make it my profession!
    The sponsors
    I would like to thank Aquatuning.se for sponsoring the following items to help make this project become more than renders and 3D models:
    Phobya Xtreme 400
    Phobya G-Silent 18 700rpm Slim black
    Vandal proof Power button 16mm White
    Alphacool bulkhead fitting G1/4 - deep black
    Phobya ATX-bridging plug (24 Pin) - black
    Thank you to Mundi at Icemodz.com, who has given the following products to make the inside of my project look as nice as it possibly could.
    1m Shakmods 4mm Dense Weave Round Cable Braid/Sleeve
    RGB LED strip x150cm
    RGB Control box and Remote x1
    Bending Cord For 12/10mm Tubing x1
    3 pin Fan Extension Cable x4
    4pin Y fan splitter Black x2
    Pre-Wired and sleeved Vandal Switch Cables x2
    Single Color LED Strip Real UV Ultraviolet x150cm
    50cm Extension cable connectors 4pins for RGB led strip lights x2
    RGB Led splitter Black x1
    1 Meter Expandable Sleeve - 4mm Snow White SKU 00020 x10m
    Lighted Vandal Switch 18-22mm Silver White Momentary 22mm x1
    Thank you to Daniel at Inet.se who has provided the project with 2x Be Quiet 80mm PWM fans, and possibly some incoming items in the near future.
    Be Quiet SilentWings 2, 80mm PWM
    Thank you to Marie at Silverstone for suppliing the project with the following items.
    Silverstone Strider ST85F-P 850w PSU
    Silverstone Short cable kit PP05
    Thank you to Karolina at Caseking.de for sponsoring some coolant and a flexible short cable kit for the Silverstone PSU.
    Mayhems Pastel Raspberry Purple coolant
    Silverstone Flexible Short cable kit PP05-E
    Thank you to Peter at EK Water Blocks which supplied the best in watercooling gear.
    EK-RES X3 110 x1
    EK-PSC Adapter 90° G1/4 Black x12
    EK-HD Adapter 10/12mm - Black x12
    EK-HD Adapter Female 10/12mm - Black x6
    The update index
    Update 1 - Aquatuning sponsors the project with watercooling
    Update 2 - Template made for top plate
    Update 3 - Corsair Vengeance Pro painted
    Update 4 - Finished the radiator brackets
    Update 5 - Icemodz has become a sponsor for this project
    Update 6 - Video tour of the completed mounted radiator and painted case
    Update 7 - Everything painted and case put back together with radiator mounted
    Update 8 - The components move from TJ08-E to FT03
    Update 9 - Inet joins as sponsor
    Update 10 - Panels milled
    Update 11 - Justin's 1st attempt at video editing
    Update 12 - Last sponsor update
    Update 13 - Water cooling installation
    Update 14 - Front panel LED installation
    Update 15 - Final photoshoot - Project complete
    Bonus update - Forbes.com "Most Incredible PC August 2014"
    Thank you for your interest in my build log, and I hope that you choose to subscribe and follow this project. Take care.
    Justin "MetallicAcid" Ohlsen
  2. MetallicAcid
    20 Feb 2014
    Final Photos
    Kind regards,
  3. Nexxo
    23 Oct 2001
    Ooh, like! Like like like like like!
    (Needs pics of work in progress though)
  4. Teelzebub
    27 Nov 2009
    Very nice work, As Nexxo said more pics needed
  5. MetallicAcid
    20 Feb 2014
    The project has started with painting the panels in a matt carbon black, and I have some unboxings of my delivery from Aquatuning.se coming soon :)
    /MA
  6. Impatience
    Impatience Minimodder
    6 Apr 2014
    Oooh.. Subbed!
  7. hanssx2
    hanssx2 Minimodder
    1 May 2014
    subd. the start looks pretty good :)
  8. MetallicAcid
    20 Feb 2014
    Thanks for joining up guys! I have a nice update coming up for you soon :D
    /Justin
  9. MetallicAcid
    20 Feb 2014
    Welcome to the first update :D
    With this update, I am very pleased to announce Aquatuning.se as a sponsor to this project. I would just like to thank Andreas for his help and hope that he enjoys following this project. The care package from Aquatuning contained the following items:
    Phobya Xtreme 400
    And here a couple of photos of what came in the care package:
    I have to say that this rad is certainly overkill - My wife just looked at the rad, shook her head and walk away. That feeling of satisfaction that overcame was simply divine! :D It is seriously heavy, and it has made me rethink the mounting method I had previously planned. It's an easy fix which involves aluminium U channel, screws, cutting, filing and painting. I will pick up the materials tomorrow and hopefully have the rad attached to the case by Tuesday night. I would do it sooner, but the latest episode of Game Of Thrones will be on tomorrow ;)
    In other news, I have repainted all of the case in a matt carbon black tone, and my does it look great! The front panel in the above picture is already sporting the new awesome blackness!
    I hope you have enjoyed this waffle-free update!
  10. MetallicAcid
    20 Feb 2014
    Hey guys!
    I don't have so much of a big update but rather that I have just finished painting the panels in a matt carbon black colour. The reason why I have done this is because the anodizing was sun damaged and started to turn a gold/pink colour. So I just gave all of the panels a nice sanding, thorough clean then a few coats of the paint, and finally a clear coat.
    They turned out very nice :)
    In other news, I went to the hardware store to get the U-profile aluminium, but the stores' personnel could not find it. I have one on back order, and it should arrive in a few days. I also ordered the ASUS Armor Kit for the Z87 Gryphon motherboard today, and that too should arrive this week.
    That is it from me for now. Take care :D
    Justin.
  11. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Really looking forward to seeing this take shape, thats one hell of a RAD.
    Subbed.
    J.
  12. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    The renders look really good! Seems like that rad was made for this mod.
    I have a FT03-Mini and I actually planned to add an external 240mm rad like that as well but then I started my scratch build.
    I'm interested to see how you will mount the rad since the side panels are only held in place by the plastic quick release fasteners afaik.
  13. Hanoverfist
    Hanoverfist Minimodder
    11 May 2014
    Great Renders... That Rad is HUGE!:eeek:
  14. MetallicAcid
    20 Feb 2014
    Thanks for joining man :)
    With the large version of the FT03, the back panel is screwed onto the frame, hence giving more support to hold more weight. :)
    Go big or go home! Once again grats on making the cover of the mag ;)
    /Justin
  15. MetallicAcid
    20 Feb 2014
    Welcome again to another update :)
    Today I would like to report on progress made with making a paper prototype of the top plate, where the tubing will go through into the PC. I do not like the original plate as I think that there is too much going on which takes away from the clean look that I am aiming for. Here is what it looks like "stock":
    Here is the first prototype that I had made and printed from SketchUp. I thought it was missing something...
    And the last prototype. This one I am most happy with. To get a start on the tube routing, I might have to make this panel by hand instead of waiting for the CNC mill to be repaired.
    And here is the associated render to show what I am aiming for. I am currently debating if I should have the front IO panel or not. I do not need it, and plan on installing a vandal switch somewhere else, so it might just go.
    I will be picking up the U-channel which came in just today at my local hardware store, so I hope to have it cut, ready to be painted with the rad installed.
    Have a good one!
  16. MetallicAcid
    20 Feb 2014
    Hey guys!
    Today's update is featuring some Corsair Vengeance Pro 2133 16GB RAM that I modified with giving it a lick of Carbon Black paint. I am planning on doing something with the stickers at a later time, like creating my own or covering them with vinyl. There isn't much more to write about, so enjoy the pics :)
    Bonus photo: A nice way to have them cure faster ;) There is plenty of warmth coming from this Dell Ultrasharp 27U11 to help with this normally long procces.
    Thanks for coming along and reading once again!
    Best regards,
  17. Sassanou
    Sassanou What's a Dremel?
    3 Sep 2011
    Subbed !!!
    And very good start !! :D
  18. MetallicAcid
    20 Feb 2014
    Hi again guys and girls! :)
    Today's update is featuring the rad brackets which I have fabricated from 40x40x4mm aluminium U-channel. They will support the radiator whilst it is hanging from the back panel of the FT03 case. The process involved drilling a whole lot of holes, then sawing the holes which are on an angle, and then to bend up the flap like it was a can of goulasch. And a lot of filing of course! :D
    My workshop this time was on my shitty little balcony. It is always nice with some fresh air, and to keep our apartment free of aluminium chips.
    In the coming pictures, I try to show how the fans+rad+ bracket is held together. I tapped holes into the aluminium profile so that when the screws go through the aluminium, then then continue into the holes of the radiator bracket, holding everything in place.
    In other news, I am just wrapping up painting the rad brackets, and will have some pictures coming up within a day or so! Thanks for once again reading my project log :)
    Best regards,
  19. MetallicAcid
    20 Feb 2014
    Thanks Mathieu! :)
    /J
  20. MetallicAcid
    20 Feb 2014
    With this update I would like to thank Icemodz.com for supplying this project with all that I could possibly need to make sure that my sleeving is beautiful and that the case has LED lighting, plus everyting else in between!
    Here come the item names and links.
    I cannot wait to get this thing put together guys!! But I can say that there is nothing more boring than watching paint dry ;)
    Best regards,
