Case Mod - In Progress Project Deadpool: Merc with a Mouth (E-ATX In Win D Frame Mini)
Discussion in 'Project Logs' started by DBRichard, 19 Jun 2015.
  1. DBRichard
    DBRichard What's a Dremel?
    6 Apr 2014
    Hola! Me llamo piscina de la muerta!
    It's time for a new casemod and this time with my favorite Marvel character as the theme.​
    Ever since the test footage leaked I've been planning to do a casemod with Deadpool as the theme, when it was announced that they agreed to a movie and with the release date of the 12th of February 2016 I was overjoyed.
    The idea's I had where quickly put back into the freezer :brrr: due to the large amount of work I was putting into starting my own custom design company this year.
    Then in May I saw a picture of an In Win D Frame Mini in the perfect color and that's where the ball started rolling.
    Sponsors:
    - In Win
    - Avexir
    - T-Grizzly
    - Cooler Master
    Part list
    Case: In Win D Frame Mini in Anodized Red
    Motherboard: ASUS Rampage V Extreme
    CPU: Intel 5820K
    GPU('s): MSI GTX980 Ti 6G
    RAM: Avexir Blitz 1.1 DDR4 4x4Gb (16GB)
    SSD('s): 2x Samsung 850 EVO 500GB
    PSU: Cooler Master V1200
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Don't forget the Chimichangas!
  3. DBRichard
    6 Apr 2014
    The first parts came in a while ago
    In Win sent over one of their red anodized D Frame Mini cases.
    As soon as the case came in I started taking measurements to see how much space there is and what is possible, the case is made to work with a Mini-ITX motherboard but soon I found out there was a lot more space.
    I started with the design of a custom motherboard tray, the motherboard size was soon lifted to Micro ATX.
    A little while later I decided to put my old Maximus IV Extreme Z (E-ATX) in there to see if ATX would fit and....well here things changed a lot, E-ATX fits fine and I decided to make this the most extreme build in a D Frame Mini to date (correct me if I am wrong)
    But you can't design a custom tray with only images to go on so a few days after my birthday I went out and bought myself a few gifts ;)
    THe ASUS Rampage V Extreme and two Samsung 850 EVO 500GB SSD's which will be sunken into the tray.
    Quick photo of how the Rampage will be placed inside the case :D
    At this moment the motherboard tray is still in the design fase and that will take some time, here are two images of the current progression of the final version, there have been a few test versions before this design.
    The tray will be milled from 12mm thick aluminium, cables will be sunken into the backside of the tray just like the SSD's and the whole tray will be anodized red in the end to match
    This is it for now, I am hard at work to get to the next step :D
  4. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Post removed as OP doesnt want pics of other DFMs in his thread.
    Not even yellow ones.....
    :D
  5. DBRichard
    6 Apr 2014
    Request to remove due to "advertising" another mod in someone else his thread, this is considered rude on forums if not asked for.
    Thank you B Neg for removing the image, I would love to come see your build at Insomnia 55
  6. DBRichard
    6 Apr 2014
    RAM, cables and switches
    Still working on the motherboard tray but in the meanwhile I got some packages.
    First I received the DDR4 Blitz RAM from Avexir
    Looks good on the motherboard but it needs some customization so lets get the calipers
    The final parts that I needed for the tray design came in, I needed the ultra thin SATA cables from Silverstone and the switches, the other parts are a valve and a deburrer but for now those are for my other casemod
    I am finishing the tray design this week and then it will go to the CNC milling company to have it made since I do not own a CNC mill :( Will put up the final design of the tray.
    Already working on the other custom part, a radiator mount to be mounted on the side for some cooling power, for anyone thinking I could fit a radiator inside the frame, you are correct but a small radiator doesn't do it for me :p
    Got some more parts coming in this week, I hope to receive the tray somewhere near the end of this month so I can start mounting the board and all the parts.
    See you at the next update :)
  7. Icelander
    Icelander Minimodder
    3 Mar 2015
    Oh man I love the look on this Blitz series Ram
  8. DBRichard
    6 Apr 2014
    Motherboard Tray Renders
    Renders!!!
    After 4 nights of hard work, solving a lot of dilemma's and some changes in my plans I am finally done with the design of the motherboard tray .
    At the same time I gave myself a new version of my logo, looks a little nicer.
    The tray offers support for the E-ATX form factor Rampage V Extreme, cable channels for a 24 pin and 4x8 pin to supply two high end GPU's of power.
    The backside with the channels, SSD placing cut outs, clear cover on the right and a red cover on the left to do some laser engraving on.
    The frontside has the holes for the cable channels, SSD power and data cables and the mounting holes for E-ATX.
    To make this tray design perfect before having it made I had some 1:1 scale prints made to check everything, I put those on the standard tray and checked for imperfections, changed a few things to make everything work (At least I hope).
    And the other side (uncut).
    These where some quick pictures and my apologies for the smudges, the lens wasn't clean I see.
    I hope the tray is finished soon so I can continue on some other parts :) Some parts I am already working on like the radiator mounts and pump mount, I'm still ironing out the kinks on that.
    To end this update, here is a picture with the current hardware on the print, looks like it will work fine.
  9. DanielSandsFTW
    DanielSandsFTW What's a Dremel?
    23 Mar 2015
    Love the idea of hiding the cables within the motherboard tray, really good use of space.
  10. storm-83
    storm-83 Minimodder
    7 Nov 2014
    second the sentiment about the mobotray and cable management!
  11. DBRichard
    6 Apr 2014
    Thanks guys, it took a lot of time to make it perfect so it already pays of seeing people like it :)
  12. bionicgeekgrrl
    bionicgeekgrrl Minimodder
    1 Oct 2009
    Liking that motherboard tray and the routing for cables, looks like it'll end up very tidy. Look forward to seeing what humerous touches you put into this ;)
  13. DBRichard
    6 Apr 2014
    I'm gonna have some engravings on this build with some standard Deadpool stuff, since the upcoming movie is the real inspiration that I aim for it won't be too much from the comics but I'll be sure to include some :)
  14. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    This is so Badass,eagerly following :)
  15. DBRichard
    6 Apr 2014
    The card for the project came in.
    The MSI GTX980 Ti Gaming 6G is currently in my HAF Pipe system for testing (and OC'ing)
    My photography equipment will arrive later this week and then I'll make some better pictures of pretty much everything, for now I need to wait. :)
  16. DBRichard
    6 Apr 2014
    Temporary CPU and cooling
    Long time no updates but finally things are moving quicker again, the motherboard tray is being milled at the moment (by a life saver from Denmark).
    Sleeving equipment and materials will arrive somewhere next week, I do not yet have a PSU but that will of course also come in.
    Yesterday I received the CPU and cooler that I ordered, a 5820K for now cooled by a Be Quiet! Dark Rock Pro 3.
    There are two reasons for this aircooler, the first being that watercooling before Insomnia 55 would not be done well enough, the second reason is that this is the largest cooler I could get that does not cover the nice RAM :D
    Also the MSI 980 TI 6G block isn't out yet :(
    As soon as the motherboard tray and PSU get in I can start making the custom cables, the two covers for the back of the tray will be cut, some covers cut and the system will be ready to go with me to Insomnia 55.
    The next two weeks are going to be very busy
  17. DBRichard
    6 Apr 2014
    Milling the Motherboard Tray (Part 1)
    The amazing CNC work from Peter Uhrskov Berg on the custom motherboard tray for Project Deadpool, he is done with this side and will be doing the other side soon.
    Can't wait to get it in and put it on the D Frame Mini.
    This part makes the In Win D Frame mini hold an E-ATX motherboard, 2x 2,5 inch drive sunken into the tray and the ultimate cable management by using grooves for the 24-pin and up to 4x 8-pin cable to supply two GPU's.
    Here are some photo's of the part that he sent me, the other side is being done tomorrow.
    The first grooves are cut
    Remaining grooves made
    First side completed
    Tomorrow the other side is being done and then it shouldn't take too long before I get it in to fit in the D Frame Mini :clap:
  18. Icelander
    3 Mar 2015
    Sexy milling ....
  19. montymole
    montymole Rigid Tubist
    24 May 2010
    Milling porn nice
  20. exexs
    exexs What's a Dremel?
    4 Mar 2010
    wooh sexy milling for sure! Should be really expensive to do? mmh
