I'm not sure if this belongs to the Technical Support forum, but here goes: Any ideas on how to close my lunchbox? I've thought about a solution involving a bodyslam from the top rope but I prefer not eating my sandwiches with a spatula. Edit: OK, so it's a sandwich and not a sandwitch
This should work: http://www.frozencpu.com/products/7...-_Black_PE-01.html?tl=g43c241s628&id=ExILLbEx
Epic thread. Anyway, I'd suggest using something like this: http://www.monkeygoods.com/images/cg-t31_dome_lunchbox.jpg That way, you can stack it up, and it would still be able to close. You could mod yours if you can, but it's risky :O
This is what you really need! An original Macintosh Classic carry bag. This will hold the samwhiches and a couple beverages too. Of course you would lose all your accumulate B-T cool. john
to fit more/larger sandwiches eat one or more then fit the other to fill the hole where the old sandwich was that should work
If my eyes are correct, then you have 4 sandwiches, yes? What about having the sandwiches on their sides? I'll demonstrate with crude ASCII: | || || || || | instead of | = = | | = = |
Definitely the right place for the thread. I've heard Langer has access to a multi tonne press. Might help solving the problem. Probably the best thing would be to get a larger box or use two of them so even more stuff can be stuffed in.
Thanks for all the replies. NOOOO! That's what I usually do but I need 4 sandwiches this time. YEAH! That will definitely score me some masculinity points! Problems is then it would still not fit vertically and I would need some filler on the side (which is actually not a problem at all ) Phew! That's a relief. Actually it's not mine but I use it the most. Oooh, I would like to have one of those but one that takes 4 sammies at a time. ... with the added benefit of less air = less flatulence. Sounds manly enough but to keep the box intact I'll rather use some large clamps
I would substitute the sammiches for a cheesecake. Much tastier. Plus, you'll have no bother getting the lid on.
