1,103,388.9 PPD
Discussion in 'bit-tech Folding Team' started by Scorpuk, 4 Oct 2014.
  1. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    :D
    With the replacement of my HD7970's my new graphics cards are doing quite well. :thumb:
    2 x EVGA GeForce GTX TITAN BLACK Hydro Copper Signature :hip:
    With a little overclock and only 52°C tops:
    Unfortunately the temp probe I bought wept at the seal so had to block that port off for now. So have my Bitfenix Recon unit temp probes on the compression fitting as an indication on loop temp.
    1: On one of the memory cards
    2: On compression fittings at discharge from pump
    3 & 4: On the inside of the back plate on the Titans.
    5: CPU
    I think I may need another radiator after the GPU's so that the CPU has a fighting chance. That's with the CPU idle. :eeek:
    Still to farm my HD7970's out to another comp yet. :lol:
    EDIT: Room temperature and power usage:
    :lol:
  2. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    You bought TWO Titan's :jawdrop: - that's gotta hurt the wallet!!
  3. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    It wasnt too bad.
    Quite amazing that they produce more PPD than my 64 core Opteron. :eeek:
    Titans: 551,965
    Opterons: 423,536
    Get a good frame rate in games too.
    Star Citizen flys by now at 60FPS. :thumb:
