Displays Upgrading my monitors... need advice/recommendations
Discussion in 'Hardware' started by SchizoFrog, 23 Aug 2016.
  1. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Hi.
    I am currently building an ITX gaming PC and although it won't be the 'monster' I originally intended (was looking at a 1070) I have picked up an ASUS GTX970 Strix for a good price secondhand...
    As such I will be replacing my old and very tired twin 22" 168x1050 Samsung SyncMasters. I am looking at the Dell Ultrasharp U2414H 24" 1920x1080 but I am also considering getting a solo ultrawide instead.
    I understand that a 34" 1440 panel is too much for my 970 to handle so really I am looking at a 29" 2560x1080 and would like some recommendations on good panels for gaming.
    I would also like to ask for alternative recommendations to the U2414H.
    General opinions regarding 2x 1080 vs 1x Ultrawide would also be much appreciated.
    Thanks.
  2. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    I did grin when I imagined you gaming on a 168 high panel - how would you see anything?!
    Anyway, my more valuable input would be: if you're going to use twins, make sure the bezel is thin as possible and that they're both set at the same height/are the same screen. I have a Dell and an Acer on a desktop clamp, but the VESA mounts are obviously in slightly different positions on the back of the screens, as they don't align, making twin-screen gaming impossible.
    I picked up the Dell (a U2410) from ebay for about £80 and the Acer for about £60 and I would struggle to see any reason to pay the £x00s for a brand new screen, so that would be my first suggestion. I've not used a wider one but it does sound good - I'm used to console gaming on a 42" plasma, so a larger desktop screen would be awesome. If you need two screens for work though (am aware you did say it was a gaming PC, but you never know), you could always get a superwide effort for gaming and keep the ones you have as extras for work.
    I also prefer the 1920x1200 desktop, so that might also be worth thinking about if you use it for work a lot. Not sure if that helps any, but hope there was some value in there!
  3. SchizoFrog
    5 May 2009
    Hi ModSquid
    I should have added that when gaming I use a single 'main' monitor which is aligned directly in front of me. The matching 'secondary' monitor I manually switch off when gaming and use if for other purposes.
    I understand the benefits of going second hand but this time I wish to buy new for several reasons that don't really need explaining.
    I am not interested in the 16x10 ratio...
  4. SchizoFrog
    5 May 2009
    After doing a fair bit of research of my own, it seems that a 29" ultrawide 1080 is my best option and then the best reviewed that I have seen is the Samsung LS29E790CNS which goes for around £325-£350.
    Any opinions on this monitor or recommendations on others would be greatly appreciated.
  5. Bede
    Bede Minimodder
    30 Sep 2007
    I'm not a fan of curved monitors, but probably only because I am an old fart. The ultra-wide looks a lot better than two standard monitors to me though.
  6. SchizoFrog
    5 May 2009
    @Bede
    Can I ask if your comments are based on experience or a generalised opinion from reviews/articles etc? Just would like to know if you have actually used them...
    Personally I don't believe that I would notice the curve too much, especially on a 29" monitor but I am yet to see either flat or curved in the flesh so that is something I would like to do before I buy.
    TBH... considering everyone needs to use a monitor of some description I am surprised there aren't more articles/reviews on BT... but I have got used to the amount of gaping holes in the content.
